Do steel lugged bikes go faster downhill than carbon fiber bikes?
I find that when I'm coasting down a long hill along side carbon fiber bikes also coasting, that my steel bike starts to increase speed over the carbon fiber bikes. I have to keep touching my brake so that I don't put my front wheel into their rear wheel. I don't like constantly touching the brakes down a long slope, so I eventually duck right down with my chin almost touching my stem for more wind resistance and pass a little quicker, to get it over with.
Or is something else going on, like I have less drag from my position in the saddle over them. They have dropped handle bars too, so I don't know. But then again, people with carbon bikes ride the hoods, and down a long hill I'm on the drops. But on the other hand they slam their stem down, and I have mine up somewhat. As you can see, I've been thinking about it, and maybe over thinking it. I don't like passing Cervelo bikes going down a long hill because I feel like their thinking, look at the guy with the old bike, he wants to be a champ and pass us, and the only time he can do that is going down a hill when we're taking a break and coasting.
Heavier riders go downhill faster. Bike weight + rider weight applies here... If you're the same weight but your bike is heavier - you go downhill faster. Same with wheels... heavier wheels go down faster.
If it's about weight, unless the guy on the Cervelo is a moron he knows you're passing him because you're heavier, and he also knows he'll catch you AND pass you on the uphill.
BTW as both a clydesdale and a steel-bike rider I make it a rule to pass everyone downhill. Period. In a group I work my way to the front of a peloton before a climb, usually drop to the end of the peloton at the top (hopefully not totally dropped) then stay with them (or pass them) on the down...
If you mean my assumptions were unfounded - Yes, I made some assumptions...
I assume that 1) you have similar rolling resistance and 2) your hubs are as smooth as the next guy ... then if you're heavier and even remotely aero you're simply going to go faster downhill.
I'm one of the heaviest guys in my club, and there is nobody that touches me downhill unless they can get in my draft. Even then most don't have the nerve to maintain the speed.
The truth is gravity works.
Forum Moderator
Quoted: 3091 Post(s)
Liked 6,601 Times
Wookie Jesus inspires me.
The truth is, I never said gravity didn't work, but yes... it does work.
Smoother hubs, bearings, aero dynamics of the rider and components, wheels, weight, tires, tubes, rider position, helmet, etc... Yeah, a lot of things we can look at.
Many smaller riders will grip the drops, shift forward, drop their hips/buttocks below the saddle just over the top tube and put their shoulders inside their handlebars - but I don't fit that way, so I favored the butt-back, hands on the inside/tops of the handlebar forehead to the stem approach. Heck, just ensuring your crankarms are parallel to the ground gets you another 1-2km/h in speed...
If the guys he's with are on the hoods and he's in the drops... that gives him a huge advantage alone.
Forum Moderator
Liked 6,601 Times
No, not exploded. It just sounded like an echo-y loud hollow plastic-y type of sound. Hard to describe, I guess.
Could be, I don't know. I didn't check what wheels he was riding. If he is there this Monday, I'll check.
It might be aerodynamics, I'm not sure, was wondering if there is any concrete knowledge about weight of bikes effect on going down a hill.
I'm 6'2" and weight 195lbs.
I do ride the drops down a long hill, but my stem is 2' 1/2" up from being slammed.
The carbon bikes I pass seem to have woman and shorter lighter men, but then again I'm kind of tall.
Bikes: '09 Felt F55, '84 Masi Cran Criterium, (2)'86 Schwinn Pelotons, '86 Look Equippe Hinault, '09 Globe Live 3 (dogtaxi), '94 Greg Lemond, '99 GT Pulse Kinesis
Quoted: 389 Post(s)
Liked 270 Times
Also, the weight difference between frames is a fraction of the weight difference between the engines.
自転車整備士
Bikes: '86 Moots Mountaineer, '94 Salsa Ala Carte, '94 S-Works FSR, 1983 Trek 600 & 620
To the OP...
As everyone has said there are many variables to explain why, but personally I wouldn't worry about it or let it bother you,
especially what the other riders think. Pick 'em off one by one on the descents and have fun doing it. If they pass you on
the climbs, so what? Tell them you were enjoying the scenery; life's too short to appreciate the finer things, right?
I bet you were looking for a more technical response; I went for the more 'sociological' one.
car guy, recovering
Bikes: Olympia Competizione & Special Piuma, Frejus track circa 1958, Dahon Helios, many others
Liked 7 Times
Michael Shiffer
EuroMeccanicany.com
Michael Shiffer
EuroMeccanicany.com
Riding like its 1990
the weight difference may be along the 3-5 lb range, so hubs, aero and body weight make up more. If you have empty bottles and they have two large full ones then all is equal.
if you are drafting you certainly will catch them unless you are a feather.
If you put your chin on the stem then you'll decrease wind resistance for more aero and go faster etc.
Maybe
Maybe
Quoted: 3015 Post(s)
Liked 3,804 Times
Bikes: 85 Peugeot Canyon Express, 73? Torpado, 85 Trek 400
OP - Are you passing riders in a group you are riding with or are you talking about just passing random people you come up on while riding? It isn't really clear in your post.
