Thoughts and experiences with aero handlebars?
commu*ist spy
I'm trying to get more aero for the next race season. right now, I'm going down a list of equipments that give me the best performance advantage vs cost.
1. speed suit (check)
2. aero helmet - lg course (check)
3. aero wheels - chinese 25x50mm (check)
4. my position is already pretty damn low and aero, I think (check)
that leaves frame/fork, which I'm not going to bother with, because i'm perfectly happy with my caad9, and the handlebar.
here's the dilemma with the handlebar. according to cervelo, handlebar accounts for 30% of the drag of the bike, which is more than the front and rear wheels combined at 0 deg yaw. this all changes when there's cross wind, but still, that's pretty significant if you ask me. on the other hand, those aero handlebars are expensive AF, and they tend to flex more than rounder aluminum handlebars.
So the argument now becomes is it worth dropping $200 on a piece of carbon that's going to be the first to hit the ground if something goes sideways? how would having a more flexy handlebar affect sprint performance? If I decide to buy some off brand handlebar from china/taiwan that are supposedly reliable based upon consumer feedback, how would those fare in the flex tests?
i already posted in the road forum, but wonder what the racers think about this.
P.S. I should mention I don't care about weight or stiffness/weight. If I wanted to save weight, there are other places where this is more easily accomplished without much compromise.
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times
Run fast tires and latex tubes?
More significant than your wheels or bars.
Otherwise, I don't think the flexier bars make that big a difference. I broke my previous sprint pr numbers 7 times last season. Never felt like my bars were a hindrance.
For 50 bucks for a knockoff generic version, though, I'd just spend another 100-150 and get real ones that are both stiffer and lighter (my pair are 40 grams lighter). I got my 3T aeronovas for like $160 from one of the British sites. Merlin just had ergosums for $130, so they run 3T sales on occasion.
Also, go for 38 or 40cm. Even if not aero. 40 cm round bar may be equal or faster than a 42cm aero bar, depending on whichever anecdote/data you happen to be reading.
Cat 2
I have some 40cm FSA Metron 4d Bars. I was given them on the carbon bike I raced two season ago and they've moved onto an older aluminum caad 10 I'm racing now a days. Realistically, they're nice but if they ever get ruined I'm going back to narrow aluminum round bars. I don't think they make that big of a difference and they can be damn slipperly if I get sweaty.
commu*ist spy
This is what I do. I'm also interested in aero carbon vs. my stock bars. I thought about pulling the trigger on monoprice's generic aerobars, but not enough data for me to feel comfortable.
**** that
Quoted: 1099 Post(s)
Liked 104 Times
I have the Zipp SL-70 aero bars, no flex noticed compared to the 3T protundo's I had before.
One nice thing about aero bars - that has nothing to do with aeroness - is resting your hands on the tops is SUPER comfy! I can never go back, if only for that reason.
Bikes: bikes
Liked 1,429 Times
Do you run Shimano or Sram? If Shimano, is the inside opening enough for both cable housings to route through?
Quoted: 1851 Post(s)
Liked 679 Times
IIRC, Zipp said the SL-70 aero bar will save about 5w. That's not a whole lot, but if you are trying to maximize all your aero capabilities, it adds up.
Anyway, I have the Easton EC-70 cause it was cheaper than the other options. (I don't pay retail.) I've had stiffer bars, but I've also had less stiff bars. Be sure to look on Online Swap Meet for used options - I've seen a lot of Specialized Aeroflys on there lately. Also, I went for the aero bars because I had an aero frame.
Nonsense
Bikes: Affirmative
Quoted: 880 Post(s)
Liked 541 Times
Love em. Love em love em love em.
I couldn't tell you if the bars make a noticeable difference in watts saved, but they're way more comfy than normal round ones. Aeronovas have a lot of different hand positions and the scoop coming into the flare to the hoods is great for getting low and narrow. If you're worried about flex, they make an alloy version, though it is pig iron heavy. Aeroflys are just shaped well and very very nice, I have a pair I'm going to install whenever it's time to service my cables. In general wing is nice.
Aero frame + bars definitely feels faster at high speeds. There's data to back it up so it's not just placebo. I'm not going to tell you to replace your frame because Caad 9 rides well enough, but if you're ever in the market for a new one don't hesitate to go aero.
Bikes: Specialized Venge
Quoted: 24 Post(s)
In regards to spending money on something that is going to be the first to hit in a crash: I crashed into a steel pole somewhere between 25-30mph in a crit and my aerofly's were the first to hit, not even a dent. My fibula and helmet on the other hand were a bit worse for wear.
Liked 679 Times
I should add, I don't think you need to worry too much about the bars being carbon. If you get a solid set, they should be able to survive many crashes, depending on severity.
For example, I've had some Easton EC90 straight bars on my mountain bike for over 10 years. They run a 25.4 clamp too. I've crashed them more times than I can count, but I have not had any issues.
Also, I am hoping Santa brings me a set of these for my track bike: https://www.3tcycling.com/road/en/bi...rs/scatto-ltd/
Resident Alien
Quoted: 349 Post(s)
Liked 10 Times
Narrower the better for aero efficiency. I run 38s in the Zipps, my track bike I run the 3T Scatto in 35s.
I would avoid the flexy knock off for crits, having a really stiff bar gives you that bit of extra control in tight situations.
commu*ist spy
Ditto. Really stiff and we'll made.
Liked 679 Times
I think the Zipps and the Eastons both flare out, so they are 40 at the shifters but 42 at the drops.
I could easily go to a 38 in that, knowing they would be 40 at the drops.
Resident Alien
Quoted: 349 Post(s)
Liked 10 Times
I wear a 42 regular jacket, so "average".
Worth noting most of the track sprinters have moved to very narrow bars, despite some of them being pretty big. After having ridden the 35s for quite a while on the track, you actually find they provide better sprint form.
commu*ist spy
i've thought about getting those actually. relatively cheap, internal routing, flat tops, aluminum durability/stiffness. seems like the perfect trade off. why do you miss carbon?
Not actually Tmonk
Bikes: road, track, mtb
Quoted: 2640 Post(s)
Liked 3,153 Times
I ride regular bars on my TCR and aero bars (bontrager carbon) on my race bike (Venge).
Everything about the Venge is faster (Frame, bars, tires, tubes, wheels, post) and is definitely noticeable at speed. Having said that the TCR is a much more comfortable bike and sees 75%+ of my total riding between all of my bikes.
"Your beauty is an aeroplane;
**** that
Liked 104 Times
But the 40's feel plenty narrow in the tops, and I'm too lazy to switch it up now.
commu*ist spy
what are the drawbacks of using handlebars that are 4 cm narrower than your shoulders? I imagine it'll be less comfortable for longer rides/races like 80+ miles. could it restrict your breathing, when you have the elbows tucked in? will it have an adverse effect on handling?
