New wheel off-center in fork
Old 07-18-11, 12:39 PM
Steve M.
Quoted: 5 Post(s)
Just picked up a pair of used wheels built on Ultegra hubs. The front wheel seems to sit a couple of mm to one side. The tire clears the fork, but just barely. Got a loose spoke the other day and the tire rubbed till I tightened it up to re-true the rim.
How to remedy this?
Thanks in advance.
Steve M.
Steve M. is offline
Old 07-18-11, 01:14 PM
bikeman715
bikeman715's Avatar
Bikes: Bike Nashbar AL-1 ,Raligh M50 , Schwinn Traveler , and others
Quoted: 85 Post(s)
You need to re-dish the wheel . Loosen the spokes on the side of the wheel that to close to the fork and tighten the other side . do 1/8 -1/4 turn each until the rim is center in fork . If you feel you can't do this yourself then take the wheel to a shop who can . Before you do this make sure the wheel is in both dropouts .
bikeman715 is offline
Old 07-18-11, 01:39 PM
MichaelW
Quoted: 19 Post(s)
Liked 7 Times in 7 Posts
If the previous owner had misaligned forks they may have padded out one side of the axle with washers. First check that the axle sits evenly in the fork then see if one side has a bunch of spacers or a thicker cone or lockring.
MichaelW is offline
Old 07-18-11, 02:06 PM
BikeWise1
30 YR Wrench
BikeWise1's Avatar
Bikes: Waterford R-33, Madone 6.5, Trek 520
Liked 3 Times in 2 Posts
Flip the wheel around and put it in backwards. If it is now closer to the other side, it's the wheel. If nothing has changed, it's the fork.
BikeWise1 is offline
Old 07-18-11, 02:10 PM
mrrabbit
mrrabbit's Avatar
Bikes: 2001 Tommasini Sintesi w/ Campagnolo Daytona 10 Speed
Quoted: 145 Post(s)
Liked 35 Times in 30 Posts
1. Check the dropout alignment. 5 minute job at the LBS.
2. Check the dish of the wheel.
As BikeWise1 hinted, if the tire/rim location changes when flipping the wheel - you have a dish problem.
All assumes of course the forks are mangled to begin with...
=8-)
5000+ wheels built since 1984...
Disclaimer:
1. I do not claim to be an expert in bicycle mechanics despite my experience.
2. I like anyone will comment in other areas.
3. I do not own the preexisting concepts of DISH and ERD.
4. I will provide information as I always have to others that I believe will help them protect themselves from unscrupulous mechanics.
5. My all time favorite book is:
Kahane, Howard. Logic and Contemporary Rhetoric: The Use of Reason in Everyday Life
mrrabbit is offline
Old 07-18-11, 02:11 PM
Looigi
Looigi's Avatar
Quoted: 14 Post(s)
Liked 13 Times in 12 Posts
Are the forks straight? As a test, flip the wheel so that the quick release lever is on the opposite side of the bike. If the wheel is now off-center toward the opposite side of the bike, it's the wheel. If it's off-center on the same side of the bike as it was, then it's the fork.
Looigi is offline
ToiletSiphon
Bicycle Mechanics
20
12-28-18 08:25 AM
wannabemekon
Bicycle Mechanics
8
05-13-17 11:30 PM
eicca
Bicycle Mechanics
14
09-08-15 10:33 PM
YonathanZ
Bicycle Mechanics
20
06-12-15 12:44 PM
veloguy
Bicycle Mechanics
3
04-19-10 03:38 PM
