Chain rubs on front derailleur plate when in Large ring upfront
Bikes: Canyon Ultimate CF SL Disc, Canyon Spectral
Quoted: 73 Post(s)
Liked 24 Times
My chain rubs on the front derailleur plate when i'm in the large ring upfront. Happens when I'm in the small cog in the back or somewhere in the middle of the cog stack.
How can I fix this?
Also, I just want to confirm that the limit screw closer to the frame is the small ring limit screw.
Bike is a 2005 Specialized allez comp double.
-Cassette10-speed, 11 - 23 teeth
CranksetFSA G-2, 39/53 teeth
Component GroupShimano Dura-Ace
How can I fix this?
Bikes: Novara Safari, CAAD9, WABI Classic, WABI Thunder
Quoted: 366 Post(s)
Liked 457 Times
YouTube "front derailleur adjustment." You'll have to move the little screws shown on the top of the derailleur in the one of the pictures.
Likes For stevel610:
Klaatu..Verata..Necktie?
Quoted: 10444 Post(s)
Liked 11,924 Times
Should Be More Popular
Quoted: 22609 Post(s)
Liked 8,932 Times
Likes For datlas:
OM boy
Bikes: a bunch
Quoted: 518 Post(s)
Liked 646 Times
You might also check the FD cage alignment. From the images it appears off a bit.
that, for sure, can be cause of rubbibg.
thx Yuri
thx Yuri
Likes For cyclezen:
Quoted: 1613 Post(s)
Liked 2,598 Times
Before you screw with the screw limits, pull on the cable and see if it moves further out. You may just need a cable adjustment.
Expired Member
Quoted: 3683 Post(s)
Liked 5,448 Times
Not that it matters but it's an Ultegra derailleur, not DA. Your H limit screw is all the way in so good chance that is the problem. Loosen it a turn and see if that resolves it. If not, start over from scratch with FD height, alignment, etc. Follow the instructions in order.
Likes For shelbyfv:
Quoted: 73 Post(s)
Liked 24 Times
The FD cage was slightly twisted. I twisted it just a hair - that solved 75% of the rub. The rest was just loosening the limit scew. Thanks guys!!
Likes For lyle.coop:
Quoted: 20810 Post(s)
Liked 9,456 Times
Man, I hope that chain is black by design.
I lube my chains the day before a ride or just after a ride with the smallest amount that I think will do the job. I choose to lube my chain well before using on the theory (possibly wrong) that the lube will have time to seep into the rollers better and let to allow any evaporative solvents to, uh... evaporate.
I also thoroughly wipe off the chain after lubing because there's no need for any lube on the exterior surfaces.
Likes For fujidon:
Advocatus Diaboli
Quoted: 4739 Post(s)
Liked 1,533 Times
Great segue to a new topic! Please tell us what chain lube we evidently should be avoiding.
Quoted: 73 Post(s)
Liked 24 Times
If it picked up that much dirt in just 150 miles, then yes, it could be your choice of lube, but I think it's more likely that it's a case of too much lube.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Likes For cxwrench:
Expired Member
Liked 5,448 Times
You may have to wipe after each ride for awhile until the excess is gone. I usually wipe the chain either before or after each ride (What Did You Do To Your Bike Today) but that could be wrong for some reason.
Likes For shelbyfv:
