Locking skewer, or convert to bolt on?
This question is about the holding power of a locking skewer to that of a bolt on solid axel. I'm riding SS and the torque is proving too great for my Deore hub's stock QR (wheel is pulled out of alignment every ride) . Is the Locking Skewer strong enough to hold my wheel in place, or should I change the axel completely? No tensioners please
Bikes: rocky mountain SLAYER!!!! trek, voodoo, surly, spot, bianchi, ibis
for singlespeed, i would go with a bolt on.
also, i would only post the question once.
Frozen in carbonite
Bikes: '85 Full Cycle Cycle.
I would try a tensioner (of the Surly Tugnut variety). If you are still opposed to it, try a locking skewer of the Allen Keyes variety. They're cheap and will probably work. Don't use the proprietary, Pinheads style. That won't work. As a last resort, swap the axle. It will definitely work but is the most costly solution.
I have a bike with horizontal dropouts and a skewer holds the wheel fine. Are you tightening it correctly? Is the skewer an internal or external cam - check https://sheldonbrown.com/skewers.html
Still kicking.
It's a temp fix with the external cam quick release, same with the locking skewer.
Either convert the hub to bolt on or use a tensioner and locking skewer for the time being, and save up for a proper bolt on SS wheel.
Appreciate the old bikes more than the new.
Thanks for the replies guys.
sk0tt, it's an internal cam tightened as hard as you would want it to go.
When I say it gets pulled out of alignment, I should say that it is getting pulled just enough to where the disc starts rubbing (too much) and I lose chain tension.
I've heard that Deore hubs are easy to convert and this is only 9.99. If I can use the existing axel's cones it should be the simplest (least moving parts) solution, but I'll avoid doing that if a hex skewer will give me enough strength.
Another question is about the axel dimensions, what is the 1 referring to in 10x1x174?
Frozen in carbonite
