Determining Chainline
Quoted: 200 Post(s)
Liked 65 Times
I have an old mountain bike which has a triple crank. Being that the chainrings need to be replaced, I am considering a 1 X setup. Measuring from the middle chainring, the chainline is 55mm. How would I calculate the needed chainline for a 1 X setup?
Thanks
Thanks
Quoted: 1083 Post(s)
Liked 687 Times
However, are you sure you're measuring correctly? A typical "old mountain bike" has a chainline of 47.5-50mm. What bicycle are we talking about, exactly? Has the bottom bracket and/or crankset ever been replaced? It's possible the wrong BB was previously installed, which resulted in an incorrect chainline for that bike. Here's a good reference.
All About Bicycle Chainline
Likes For Jeff Neese:
Liked 687 Times
If you can find specs for that bike that say otherwise, then of course go with the published specs. But I'd be really surprised if the correct chainline for that bike isn't the standard mountain triple which is 47.5-50mm. Especially a Giant, from the early 90s.
Quoted: 200 Post(s)
Liked 65 Times
Is there any reason to believe that the correct chainline for that bike isn't the industry-standard 47.5-50mm, and that somehow, somewhere a mistake was made? Is the bike stock, otherwise? Are you the one that installed the last BB?
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
Likes For daniell:
Really Old Senior Member
On paper, you want the center ring to line up perfectly with the center cog of your cassette. (presuming an odd number of cogs, else "split the difference" if an even number)
However, some of us match it to our specific needs.
For example, I tend to use my 3X9 on the middle ring and outer cogs mostly, so I use a slightly longer spindle to better match those cogs.
Likes For Bill Kapaun:
Quoted: 431 Post(s)
Liked 460 Times
If you're going to replace with external cup BB and modern 2-piece cranks then the BB length is irrelevant. Assuming it's a double crank and you want to run a single ring, most people mount the 1x chainring on the inside of the spider.
Likes For tFUnK:
Mostly harmless ™
Bikes: Heavy, with friction shifters
Quoted: 1107 Post(s)
Liked 216 Times
If you run it with a "normal" cassette (i.e. not the ones with over 40T on the largest sprocket), you could go without the 2mm offset (how far inwards you can move the front chainring also also depends on your chainstay length).
How to measure the front and rear chainline
As far as I know, Shimano 1x cranks are designed to provide the wider chainline when used with Shimano Hollowtech II bottom brackets (and, if your frame has British, or "at least" Italian thread, you should be able to source a Shimano Hollowtech II BB).
P.S.
I see going from 3x to a 1x as a step back (1x drivetrain pros and cons).
Relja
Quoted: 200 Post(s)
Liked 65 Times
Ideally, "by the book," for a 1x, you want the front chainline to be about 2 mm larger (further outwards) compared to your rear chainline.
P.S.
Relja
P.S.
Relja
Likes For daniell:
