Bike Friday Question
Quoted: 455 Post(s)
Liked 112 Times
I am going to be working on a friend's BF. Has anyone had any ex with the handle bar assembly? At first glance it "appears " that they might be 2 separate pieces? Would like a little background beforehand.
Thanks!
Thanks!
Quoted: 4210 Post(s)
Liked 3,875 Times
Most of the Fridays I've worked on have a split handle bar. The bars used little pins to help locate them within the stem and WRT to each other. Andy
AndrewRStewart
AndrewRStewart
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 336 Times
There is some bolt there where the stem grabs the handlebar and when you screw it out the two halves of the handlebar detach. Some twisting to get them out may be required. Generally it is better to ask folding bike questions at the Folding Bikes Forum.
Bikes: 1978 Bruce Gordon, 1977 Lippy, 199? Lippy tandem, Bike Friday NWT, 1982 Trek 720, 2012 Rivendell Atlantis, 1983 Bianchi Specialissima?
Quoted: 346 Post(s)
Liked 175 Times
If like mine, the handlebar is split to ease packing into a suitcase. The handlebar halves slide on and off a sleeve and the stem bolts used to tighten any handlebar are loosened for disassembly. There is a center screw that should (or need not) NOT be messed with but is for centering purposes on the sleeve. Mine is a late 90's NWT which I just packed up for upcoming tour. I have a manual I could take pictures of and send to you if you like.
Likes For L134:
Quoted: 455 Post(s)
Liked 112 Times
Would appreciate the manual!
tnorton770@yahoo.com
Quoted: 346 Post(s)
Liked 175 Times
