Alternatives to electrical tape when securing bar tape post-wrap
Dear all,
when finishing the bar tape wrap, I use electrical tape. The ever-long problem is that it creeps, eventually in hot sun it may also melt, or dust gets under the end and it begins to slowly unravel. It also gets old (that tape you bought 5 years ago is probably either too fragile, or dry). It is unpleasant also because my hands, when riding on tops of bars, may grip the place where electrical tape finishes, and pull it off.
What are the best alternatives, maybe there is a different tape type I can try? Is there some sort of plastic piece that can sort of clamp and hold the bar tape from unwinding and feel good on the hands?
Surely someone has encountered similar problems, if you got a link to an old discussion, please post here. I couldn't really find anything.
thank you
thank you
Quoted: 3428 Post(s)
Liked 5,642 Times
Self-Fusing Silicone Tape.
blah blah blah
Quoted: 5 Post(s)
You can wrap from the center of the bars down to the end and then secure the tape with the bar end plugs.
Alternatively, if you must take from the bar ends up to the center, you could use heat shrink material to hold the ends.
Fred E Fenders
Bikes: Jamis Aurora Elite
Hemp Twine that can be wrapped and pulled under itself to finish off. Classic look.
F Thomas
"Life is like riding a bicycle. To keep your balance, you must keep moving."
Albert Einstein (1879-1955)
F Thomas
Bikes: '17 Access Old Turnpike Gravel bike, '14 Trek 1.1, '13 Cannondale CAAD 10, '98 CAD 2, R300
Quoted: 1571 Post(s)
Liked 12 Times
I searched around (mostly YouTube videos) to learn why we now go plug-to-center... wrapping from the inside-to-the-outside (Clockwise on the right, counter clockwise on the left). Apparently the consensus is the new way slips less both on the bar as well as in the hands.
I never get more than two years out of a set of handlebar tape. So I don't have to worry about age affecting the electrical tape. But even if the electrical tape was damaged.... just wrap on a new piece of electrical tape.
Back in the old days when we wrapped our cloth or plastic handlebar tape center-to-plug.... my handlebars were steel. Steel handlebars held up well. Now-a-days handlebars are lightweight aluminum or carbon fiber. I know it's currently somewhat trendy to have ratty, worn, and dirty handlebar tape. But it's best to inspect the new handlebars! So ride hard and lots so that handlebar tape can look cool early in the season. But replace the tape regularly and inspect those bars.
Interocitor Command
EDIT: I just checked some 1" heat shrink I had on hand and although it's enough to go around the bar and tape near the plugs, I'll probably need 1.5" shrink to go around the bar, shifter cable and tape on the tops.
Quoted: 4895 Post(s)
Liked 4,067 Times
I use quality electrical tape, wrap my bars so the tape is coming back as it goes over the top of the bar, wrap the electrical tape in the same direction and end the tape just before the brake/gear housing. That way, my fingers rarely touch the ends and when they do they are tending to smooth them out. I find the electrical tape usually lasts unto I replace the tape or make changes.
Ben
