1974 Raleigh Grand Prix Rehab...Part 5...Frame Alignment
Quoted: 703 Post(s)
Liked 678 Times
I started assembling the bike today and got the derailleurs working great. When I tried to install the rear brake pads, I could not get the wheel centered in the seat stays. Checking the frame with a Park Frame Alignment Tool, I could see that the stays were off-center by 1/4". So with some scrap lumber I built this fixture to hold the frame securely while I wrenched the stays over with a 8 foot long 2x4. The fixture being attached to the floor proved to be very effective.
Quoted: 703 Post(s)
Liked 678 Times
Quoted: 3824 Post(s)
Liked 6,783 Times
Nice setup! When I've done that job, I install a couple of bottom bracket cups that I'm not terribly fond of and then place the frame in my vise, holding it by the cups.
Quoted: 703 Post(s)
Liked 678 Times
I thought of doing that but my work bench is so cluttered that it was faster (and more fun) to just build this thing.
Bikes: many
Quoted: 1457 Post(s)
Liked 1,408 Times
Interesting. I see conduit clips securing the dummy front axle. How is the bottom bracket shell secured, just the bottom bracket spindle riding in the two holes?
Quoted: 703 Post(s)
Liked 678 Times
Quoted: 703 Post(s)
Liked 678 Times
Aligning the seat and chain stays did not help. The wheel was still offset to the non-drive side by 3/8". Although not evident in the photo, I could see that the wheel was not parallel to the seat tube.
Quoted: 703 Post(s)
Liked 678 Times
I almost gave up but after giving it a day to sink in, I took some measurements and found that the non-drive side seat and chain stays were slightly longer than the other side. With the help of AutoCAD, I input the wheel radius, the axle length between the dropouts and the amount of offset. Using the "alignment" command, I was able to get the exact measurement that the axle needed to drop on the drive-side to center the wheel.
Using a fresh "flat bastard" file, I took off about 1.5mm from the inner bottom of the drive-side dropout.
*remember kiddies, files only cut on the push stroke, dragging a file across the work surface on the return stroke will only shorten the life of the file...
Likes For branko_76:
Quoted: 703 Post(s)
Liked 678 Times
Since the d.o. has no integral derailleur hanger, the hanger attached to the simplex derailleur will position the axle...
Quoted: 703 Post(s)
Liked 678 Times
The wheel is now centered and is also parallel to the seat-tube...
Well done! I have had many bikes with odd misalignments. You do what you gotta do you make them "right".
Likes For big chainring:
Quoted: 13 Post(s)
Likes For mauin1x:
feros ferio
Quoted: 1398 Post(s)
Liked 1,343 Times
I envy your amount of workshop space.
Likes For John E:
Quoted: 3842 Post(s)
Liked 3,398 Times
differing effective seat stay lengths is one of the nastier frame alignment problems to solve...
have had a couple frames come through where the unequalness could not be solved by the method you employed
on a visit to Bob Freeman on Bainbridge Island (Seattle) to receive a giro of his collezione in September 2001 he showed me his Baines/TJ Cycles Flying Gate
all of that thought/care/planning and use of the very best materials on a bespoke frameset and Trev had constructed it with dissimilar effective seat stay lengths so that the machine's stern round thing sat in there gollywompus
Likes For juvela:
Bikes: 1964 Huffy Sportsman, 1972 Fuji Newest, 1973 Schwinn Super Sport (3), 1982 Trek 412, 1983 Trek 700, 1989 Miyata 1000LT, 1991 Bianchi Boardwalk, plus others
Quoted: 585 Post(s)
Liked 704 Times
Isn’t this about the time someone comments on British manufacturing quality?
Likes For sd5782:
Bikes: 2017 Sage Skyline, 2015 Co-Motion Periscope Tandem, 2012 Soma Smoothie, 2006 Kona Jake, 1978 Richard Sachs, 1977 Peugeot UO18c, 1977 Peugeot PRN10, 1974 Allegro Schweitzermeister Model 76, 1972 Hugo Rickert Spezial, 1971 Fuji Finest
Quoted: 119 Post(s)
Liked 630 Times
The brake bridge brazed on a slant sure caught my eye
I’ve always pictured Bike Boom manufacturing to be like that movie scene in “The Court Jester” with Danny Kaye where they compress his knighthood training into one day using a process that normally takes a few months.
Likes For Sactown_Albert:
Bikes: Raleigh Super Course, Raleigh International, Raleigh Gran Sport
Quoted: 252 Post(s)
Liked 319 Times
You know, I've taken as many pokes at Bike Boom British quality as most of us. But, at the same time, I am also impressed by my three early '70s Raleighs that are in near daily use that all still look good and ride great, despite being 50 years old. I have few other material possessions that have held up so well for so long.
Likes For daka:
Quoted: 585 Post(s)
Liked 704 Times
And I will admit that I kinda have a hankering for an early International.
Quoted: 703 Post(s)
Liked 678 Times
