Is this an original Colnago?
So I have this Colnago frame. Looks to be about a 1974 as far as I can figure out. It has significant corrosion so it needs a repaint. But are these the original decals? I don't see online photos of another with a clover in the middle of the C on the downtube. And headbadge loofs different. So is this original? Thank you.
Quoted: 3464 Post(s)
Liked 2,831 Times
Rare are the single color graphics, I have a 1972, same headtube.
I will call the others plausible and maybe near the end for them as the chainstay graphics are two tone.
mine are all black.
led apparently a warriors life.
I like the way they ride
I would buy it and work to get a great color match. Then ride it. Enough of the original finish is intact.
mine are all black.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3901 Post(s)
Liked 6,508 Times
Needs a repaint.
Bikes: 1973 Colnago Super, Litespeed Classic , Automoto , Pinarello Gavia TSX,Eddy Merckx Corsa Extra,Eddy Merckx EMX-5 , 1982 Moser SL, Concorde TSX, Vitus 979 KAS. Diamant SLX,60's Meteor
Quoted: 237 Post(s)
Liked 950 Times
The bottom bracket and the Spade panto on the frame and forks say its a Colnago , 73'- 74'.
I wouldnt worry about the decals as this frame is almost 50 years old and owners are known to change things up over the decades . My 73 Super has 1983 decals on it , just because They look better .
Likes For Jicafold:
Quoted: 4521 Post(s)
Liked 6,415 Times
Edumacator
Quoted: 2467 Post(s)
Liked 3,183 Times
I am definitely with the touch up and ride crowd.
Despite the scratches, that paint color is awesome. And the decals look great on it.
1987 Crest Cannondale, 1987 Basso Gap, 1992 Rossin Performance EL, 1990ish Van Tuyl, 1985 Trek 670, 2003 Pinarello Surprise, 1990ish MBK Atlantique, 1987 Peugeot Competition, 1987 Nishiki Tri-A, 1981 Faggin, 1996 Cannondale M500, 1984 Mercian, 1982 AD SuperLeicht, 1985 Massi (model unknown), 1988 Daccordi Griffe , 1989 Fauxsin MTB, 1981 Ciocc Mockba, 1992 Bianchi Giro, 1977 Colnago Super, 1971 Raleigh International, 1998 Corratec Ap & Dun, 1991 Peugeot Slimestone
Likes For jdawginsc:
Quoted: 880 Post(s)
Liked 2,303 Times
I love the color , not sure if the decals are original or not . If it was my bike , I would seriously consider a repaint given the condition of the existing finish. I have a ‘75 that I got in a patina state . I rode it for a year and then had Franklin Frame restore the paint and decals. It doesn’t ride any better but I like it with nice paint .
Prior to sending it out, after a year of riding as is.
After repaint and a few hundred miles
Likes For Kabuki12:
Liked 2,831 Times
A fellow club member decades ago had a Super this color and basically the same graphics, on his bike, All Black, no two tone on the chainstays. I Definitely assess the graphics as Original.
‘there is a weirdness. At the top of the lower head lug of some black swiped on the shoreline, like an attempt at lug lining. ?.
‘if you want to ruin a bunch of the resale value later, suffer a bout of paintitis and paint it black.
later today I can post some images of my earlier frame with All black graphics.
Likes For repechage:
Quoted: 807 Post(s)
Liked 2,996 Times
try matching it/
base coat makes a big diff. to the finished shade.
aged to perfection
Quoted: 845 Post(s)
Liked 1,277 Times
Yes, I am in agreement with repechage surface prep, spot paint, and maybe then a bit of clear over the whole thing
I'd be looking at HOK 0802 as a starting point with maybe a dab of white to flatten it out a little.
Keep the original graphics.
The great Brian Baylis was a master at "conserving" rare bikes for which no reproduction transfers were available. I was once in his shop and he was working on a white Masi Special that was destined for Eisentraut's wife. he did a beautiful job and yes, preserved the original fade paint and decals.
/markp
/markp
NO, No, No, to a black top tube. Take a scratch-x self degrading rubbing/polishing compound to the fork. A half interested clerk at an automotive paint store should get you to a match. Various paint choices, house of color, Chromabase (was Dupont) others. Many paint stores can even make up a custom rattle can of the mixed color, I would clean the fork and dab on the color mix onto the steerer to confirm. Buy a quart of Prepsol, used to remove any contamination and wax, oil to promote adhesion. A possible strategy would be to talk to a used car manager, they all have a mobile guy or two who touches up cars and knows tricks, has the materials to get you there. Might even come to your house.
Liked 2,831 Times
Liked 2,831 Times
Well, you have to pick and choose your battles. I am concurrently working on a vintage Cannondale, Nishiki, Vitus, and carbon Trek also. There is only so much time in the day and stripping and prepping is a laborious process. Especially paint removal. Current modern-day strippers are largely underperformers.
I urge you to not ruin it.
What I am saying is that it at least is worth taking a look at.
Quoted: 880 Post(s)
Liked 2,303 Times
If you are passing it along , maybe let the next person decide what to do . If you are not riding it and it is stored indoors, I don’t see it getting worse. I rode mine many miles as it was and it pretty much held up just fine until I was ready for the respray. I just kept it clean and dry.
Liked 2,831 Times
the cost of a spray can is noticeable, but not so outrageous as to not purchase and assess at home.
as an example, paint the same color over, white, grey primer and red oxide and there will be different results.
Ferrari restorers have been known to prime the Ferrari red with a pink primer surfacer to match the original as seen on the F40.
Quoted: 175 Post(s)
Liked 452 Times
Likes For chain_whipped:
Have zero issues with brand Klean Strip, the gold can 'Premium' stripper. Lather the surface in sections, plastic wrap and don't let it dry. Move to another section and repeat. 15 minutes later, remove plastic wrap, scrape off and wire brushes. Work over a plastic sheet and its not messy.
Location: Western Riverside county, Southern California
Bikes: 07 Raleigh supercourse, 04 Specialized epic MB, Surly 1x1, Recycled Recumbents Mach 2, 63 jc Higgins racer single speed, early 60’s Armstrong roadster, KHS tandem electric conversion, GT mb electric city bike conversion.
Quoted: 14 Post(s)
Liked 21 Times
don’t paint it or do anything if it doesn’t fit and you are going to pass it on. Don’t create a headache for the new owner. Let them decide what to do without having to undo what you did.
Likes For Chain smoker:
Bikes: '53/'54 Bianchi CDM, '62ish Altenburger Cinelli Mod B, '69 Rene Herse Competition, '72 Motobecane Grand Record, '73-74 Colnago Super,, '73-74 Cinelli SC, '78ish counterfeit Confente, '82 Medici Gran Turismo, '67ish Mondia Speciale, Eddy Merckx Pro
Quoted: 90 Post(s)
Liked 268 Times
Looks reasonably similar to mine. They might be reproductions, but they would be early and pay of the history.
Err on the side of leaving it alone if you don't plan on keeping it for the long term.
Bikes: A few
Quoted: 290 Post(s)
Liked 201 Times
You will find it difficult finding an off the shelf match for Molteni Orange. I have tried several different RAL colors, mixing different shades, but no luck so far.
I chose to polish what I have, and put a couple coats of Collinite Fleet wax on it, and enjoy the battle scars
Likes For satbuilder:
