Another headset question
Bikes: 1983 Univega Super Strada, 1986 Panasonic DX5000, 1984 Fuji Team 85 Univega Gran Turismo, 1984 Lotus Unique, 1987 Centurion Expert, 1987 Centurion Ironman Master,
Quoted: 677 Post(s)
Liked 460 Times
The bearings in my 87 Ironman has caged bearings that I want to replace with loose bearings. The caged bearings have a thin plastic ring that sits on top of the bearings. I'm wondering if I put this ring back on top of the loose bearings?
Quoted: 1372 Post(s)
Liked 1,751 Times
Often times just googleing what you want, in this case "sealed bicycle headset schematics" and you should get lots of information...
Quoted: 677 Post(s)
Liked 460 Times
Quoted: 283 Post(s)
Liked 262 Times
The seal should be independent of the bearing balls. Bearing contact is steel balls between 2 steel races. Seal fills gap between outer parts of races to keep crap from getting into bearing contact area. Going sans retainers just means more loose balls, not too many though. Without seeing your actual parts I could be wrong. Possible your headset may use the ‘squarish bottom’ of the retainer as support for a seal, can’t tell from here, wouldn’t think so.
Stop reading my posts!
Quoted: 1443 Post(s)
Liked 1,062 Times
yep, typically the plastic "seals" both on top or bottom don't make contact with any bearings whether or not there are caged retainers. You should be fine to replace the caged bearings with the same SIZE balls but fill the entire cup raceway with as many balls as fit and then remove one. Helps to use a grease with some "stickiness" so the balls stay in place until everything is back together.
Likes For unworthy1:
Bikes: 1990 Marinoni Special, 1986 Proctor Custom, 1989 Kuwahara Caravan, Singular Firebird Stainless, Niner RIP9, Sekine SHT
Quoted: 7 Post(s)
Liked 15 Times
Yup, this is my experience also.
