3 Speed Shifter
30mi/day commuter
3 Speed Shifter
I have a genuine Sturmy 3-speed shifter but when I shift to 3rd gear I have to push into the shifter and up on the lever. Is this normal or are they usually quite smooth?
Also I hear a click when im shifting from 2nd to first on the shifter but I cant see anything happening. Does the click mean its working?
How do I go about fixing these shifters? Where can I buy good cheap 3 speed shifters? I know Harris Cyclery has genuine ones for 20USD.
Sorry I filmed the shifter but youtube wont accept my video
![Frown](images/smilies/frown.gif)
Liked 2,631 Times
Maybe the shifter needs lubrication. Drop in some oil, any kind.
Or maybe the cable needs lubrication.
Or maybe the clutch spring is weak, inside the hub. That would require an overhaul. We can walk you through that, though it's unlikely to be necessary.
Mine hangs up between second and third, too. I can say for sure that the problem is in the shifter itself, because it does the same thing on another hub. I'm hoping that the problem will go away as the shifter wears in. It's a seventies shifter, but it's NOS. The cable is new. Lubrication doesn't help.
30mi/day commuter
Rustbelt Rider
Liked 372 Times
New Old Stock, meaning it's old but it has never been used.
Bikes: 198? Raleigh Technium 480, 1970 Raleigh Sports, Motobecane Nomade Sprint
I have the same issue with my shifter. Mine also doesn't want to stay in 1st or 2nd gear either. It will just slip into neutral position or to 3rd gear randomly while I ride. Very annoying. It has a new cable and the shifter has been oiled as well.
Great State of Varmint
Shift to 3rd gear - feel the cable where it's coming from the hub to the adjusting bolt. Is it stiff/tight? If yes - you should re-install same.
Loosen the cable at the anchor bolt closest to the hub. Now unscrew the thin rod that's screwed into the hub itself. Give it a few drops of oil. Screw it back into the hub all the way. Now back it off by 1/2 turn. Got that? 1/2 turn.
Now re-attach the cable into the nut/screw that holds it in place to the rod & chain. Make sure the shifter is set to 3rd gear. And the cable isn't tight - but not loose either. You can easily move it side-to-side with your finger. But no slop either. Tighten the anchor-bolt so the cable doesn't slip as you adjust the barrel-adjuster that's directly between the place the cable exits the hub and ahead of the anchor-bolt. It's the gnarly looking barrel and the gnarly nut. Visualize. Read & look at the area. You'll get it.
Now shift the SA shifter to second gear. See where the rod & chain are in the little window where the rod & chain exit the interior hub? Do you? Good! Now in the second gear you should see, in the center of that little window, the straight rod and the chain near the middle off the window. Like this: ooo===. 1/2 and 1/2. With the anchor bolt torqued down (don't go nuts here, King Kong), shift it to 1st gear. Did it work? 1st is easier to pedal from a stop (apply brake)? Now try 2nd. Harder than 1st? Shift to 3rd. Harder than 2nd to pedal?
If not - adjust the gnarly barrel-adjuster a turn clockwise. Get all 3 gears? No? Try the counterclockwise 2 turns. Got it yet? You'll get it. Just keep an eye on that little window and the: ooo===.
You'll get it. Once you have the right adjustment so you have 3 distinct gears - screw the gnarly nut onto the barrel-adjuster and tighten it. This should maintain your adjustment fine for a long time.
I love 3-speeds!
By the by - it should NOT be a struggle to shift in either direction. Fix same by above directions.
I love 3-speeds!
Freewheel Medic
Liked 2,260 Times
Panther,
I need a set of those wonderful instructions for my 4 Speed SA-FW hub. Do you have any experience with one additional gear?
I'm cutting and pasting the above into a permanent little file in my Palm! Thank you.
Bob
Bob
https://www.users.globalnet.co.uk/~ha...samaintind.htm
On p. 4 of that pdf is the section "Hub Gear Indicator Adjustment," which has some clear descriptions and drawings for setting up the indicator on 3- and 4-speed hubs.
For the FW, you put the trigger in 2nd gear and adjust the pull so that the rod on the non-drive side is flush with the axle end. I sometimes have to make this adjustment with the left-side nut removed so I can get a clear look at that axle end.
Neal
Freewheel Medic
Liked 2,260 Times
Dirt Drop & Neal,
Thanks for the additional tips. I set up the FW today for the first time on my Schwinn pre-war New World. Unfortunately the driveway is covered in ice and a light snow has been falling, so no test rides. Seems to shift fine in the stand. I might have to take it to the church fellowship hall for a test ride tomorrow.
Bob
Bob
30mi/day commuter
To work a sturmy archer 3 speed hub do i need to use a Sturmy shifter? I have another 3 speed shifter which I would like to use just because it works.
I wont give up fixing the other one as I have 2 shifters and two 3-speed wheels.. .but I would like to get 1 bike working first.
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Liked 16 Times
Aaron
![Smilie](images/smilies/smile.gif)
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"_krazygluon
Elitest Murray Owner
Bikes: 1972 Columbia Tourist Expert III, Columbia Roadster
30mi/day commuter
damn i realized this is really a shimano shifter ![Frown](images/smilies/frown.gif)
I really like the idea of vintage 3 speeds but they are so much work.. spokes were seized, cable adjustments, special shifters, odd numbers of holes on the hub, special cables... everything i go to do takes me so long
Liked 2,631 Times
I think you're having worse-than-normal luck. Mechanically, they're pretty good bikes. Yours must have seen some serious neglect or abuse.
To many of us part of the the allure is that they are so challenging to work on. A friend bought one to learn to work on bikes. I told her "That's like learning to kayak with a November crossing of Lake Superior."
Liked 2,631 Times
I don't agree! I'll bet you're familiar with derailleur bikes and unfamiliar with IGH bikes, so you're not comparing them fairly. If you were equally unfamiliar with both types of systems, you'd find the IGH much simpler.
Seized spokes are merely from age and neglect. It has nothing to do with the type of bike.
Liked 16 Times
![Thumbs Up](images/smilies/thumb.gif)
Yup I have a 5 speed that I am getting ready to attack, the chain is rusted to the rear cog, and god only knows the last time a spoke was turned...damned derailleur bikes
![Wink](images/smilies/wink.gif)
![lol](images/smilies/lol.gif)
Bike is a bike, some are in better shape than others, some are built with better quality equipment than others, they can all be a PITA to work on if they were abused.
Aaron
30mi/day commuter
Well the real problem with the seized spokes is that this hub has i think 40-holes in it and I dont have easy/cheap access to a rim with that many holes.
If I could use a normal rim (without doing strange lacing) I would just build up a new wheel quickly... but I cant.
Since the technology is old most parts must be specifically bought as "vintage" parts which makes them more expensive and usually they have to be shipped.
Liked 2,631 Times
You can get this rim for 25 bucks. It's a good rim. No high tech anything, though it's nicer than the old rim. I recently built a pair of wheels with these rims. Very nice.
30mi/day commuter
well now I feel silly. I had only looked through Canadian sites to try to keep shipping costs down.
Even then... its 50USD of shipping for 50USD of rim.
Should have looked for that though
Liked 2,631 Times
Jeez, maybe you should visit Niagara Cycles and cycle back home to Toronto!
