What kind of road tires are you folks using these days?
Need some new tires on the tandem. Bike came with Vittoria Corsa 32's. Nice tires, yes, and I've used similar 25's on road bike, but might be after something a little more puncture proof.
Open to ideas and suggestions. Riding is on mostly nicely kept roads, so while I don't necessarily need Gatorskins...something that's a happy medium btw. those and really nice Corsa's or GP5000's would be good.
Also, as to width, should I stick with 30+? Bike is a Cannondale tandem. Am a bit of a luddite and still use 23's and 25's on my road bikes (and not least of which why that width is they won't accommodate anything wider than 25).
Bikes: Columbine, Paramount Track Bike, Colnago Super, Santana Tandems (1995 & 2007), Gary Fisher Piranha, Trek Wahoo, Bianchi Track Bike, a couple of Honda mountain bikes
Liked 209 Times
Nicely kept roads??? Wow, that would be a treat. Here in San Diego where the roads were last paved when Eisenhower was President, I run Conti GP5000 in 32mm.
I haven’t had a problems with flats even though our fully loaded weight is 400#, but I do run @95psi.
Cheers, Mike
Cheers, Mike
Likes For PromptCritical:
Well I say that lightly....
Roads are ok. It's SWFL.
Am thinking 30's or 32's and Conti also. Been on variants of them since, well, a long time...
Bikes: Time Scylon, Lynskey R350, Ritchey Breakaway, Ritchey Double Switchback, Lynskey Ridgeline, ICAN Fatbike
Liked 572 Times
Mrs. Dan and I are also running GP5000 32 mm x 700 on our Ritchey. We run tubeless at 90 PSI. Tread life has been in the 2000 to 2500 mile range.
We were running Schwalbe Marathon and when we switched to the GP5000 Mrs. Dan wanted to know what I had done to make the bike feel so much more stable in corners. Yes, it is noticeable.
Likes For DangerousDanR:
On my Cannondale R2, I use Continental Gatorskin tires for everyday riding. Continental GP 5000 for racing. 32mm for both.
700C x 28mm @ ~95+psi Schwalbe Marathon on the Raleigh Coupe used for club rides and, 26" x 2.0" @ ~60psi Schwalbe Marathon Plus on the Trek T900 being used as an urban commuter/errand runner/shopping hauler.
Bikes: 1980's Spectrum 10 sp Campagnolo Centaur, 1990 Eddy Merckx 10 sp Campagnolo Centaur, Bushnell Tandem, Co-Motion Speedster Tandem
Liked 103 Times
Has anyone used one of the new Schwalbe One iterations yet?
Bikes: CoMotion tandem, All City fixie, Cannondale road bike, fold-up bike
Liked 6 Times
I've been running Marathon plus 700 x 35 on my Co Motion Java for about 2 years now with no issues. Had problems with flats before switching over. We are about 325 lbs without gear, most of our riding is a mix between road and bike paths.
Liked 209 Times
Anyone running tubeless?
Cheers, Mike
Cheers, Mike
Only on our MTB tandem. We use TPU tubes on our "fast" road wheelset, but Slime tubes on our everyday wheelset. I'd probably use tubeless on all of our bikes, but they tend to dry out quickly during hot Colorado summers, and I don't have a lot of time these days for futzing with them.
Bikes: See user name...
I've been running tubeless GP5000 25s for about a year on the Landshark. Rims are Light Bicycle 45/55 tubeless (no rim holes). The 25s measure about 27 on the rim and there isn't a whole lot more space on at the seat and chain stays. I have been happy with them at about 90 psi. We had occasional pinch flat issues with the tubed setup (variety of tires) even running up to 115 psi.
Overall, I would recommend tubeless for a bit more comfort. It is more maintenance (previously mentioned drying out, finicky to set up sometimes), no doubt.
Likes For JSNYC:
Bikes: Merlin Road, Rivendell Road, Arvon custom tandme, Hi-Light G-7
Liked 12 Times
I have been using Continental GP 5000 AS TR 700x35 on my gravel bike. I run them at around 55PSI tubeless. Rolls well. No issues. Pricey in North America though.
Never tried them on our tandem because our tandem uses 26" wheels but if Continental ever make a wide version, I'll give them a try.
When I was riding a lot in Shenzhen, wet surface traction was a constant issue. Very very few tires has decent traction on wet pavement as I found out several times the hard way.
pan y agua
Liked 769 Times
We run 28mm Continental 5000 tubeless. At 350 lbs team weight we can run them at 85lbs, or less, with no issues.
Ride is much smoother than tubed, which would require higher pressure for the same sized tire, and we have many fewer flats.
Just as an anecdote, we were able to finish the final stage of the Ride Across Portugal, with the pack, with 2 punctures that self sealed. Running tubes we’d have to have stopped twice to fix flights and been dropped.
You could get lost and die.
You could hit a tree and die.
Likes For merlinextraligh:
just another gosling
Liked 2,003 Times
GP5000 32 mm x 700 for many years, tubed, at 95 psi. Our team weight is 295. On my single, I run GP5000 23mm, also tubed. Some of the tubes are TPU, some latex, some butyl. The weird thing is that I can't remember the last time either bike flatted and those are fast tires for sure. Used to be that fewer flats meant slower and lousy bike feel.
Results matter
Results matter
Conti Gatorskins, 32mm (I think). We don't put on a lot of miles, but very, very rarely have a flat. Rider weight about 260 lbs, for the both of us.
I'd rather be riding
Bikes: Santana Team Ti 700 S&S, Trek Madone 6, Omega Ti,Klein Palamino, Trek 510
Conti GP 4 Seasons 28mm with tubes, 95 psi. We’re 320 lb including bike. We’ve had very few punctures (hope I have not jinxed us saying this).
We run GP 5000, 32 mm, tubed, for last 5 years. When we spec'd the bike from Co-Motion, I asked them about tube vs. tubeless. Aside from the usual list of pros and cons, he said on a travel tandem, when you're deflating the tires to pack in S&S cases, some people don't like the hassle of the sealant mess or of trying to reinflate wherever you are reassembling the bike. I'm not sure if those are real-world issues, but we stayed with tubes for that reason.
Also, the GP 5000 do seem more fragile w/r/t sidewall cuts. We destroyed a couple tires on a tour last year on German MUPs with "gravel" (ie - sharp, small rocks) sections. Some say the Conti 4 Seasons is better in that respect.
