Rack, SKS fenders, and disc brakes
Bikes: Electra Loft 7i, Fuji Crosstown 2.5, Gravity Liberty FB, Schwinn Voyageur
Quoted: 57 Post(s)
Liked 8 Times
I've been riding my Liberty FB to work for a couple of years, and recently decided to add SKS Longboard fenders. I took the rack off to make installing the rear fender easier, only to realize after installing the fender that the rack won't fit over the spacer for the disc brake caliper. I've already cut the rear fender stays to fit, so now I'm stuck. The rack is a Topeak Super Tourist for disc brakes, and has clearance built into the rack for the brake caliper.
Any suggestions? I'm thinking that my cheapest option would be to see if SKS sells spare fender stays, and possibly bend 1 side to get over the caliper.
Bikes: 2005 Gazelle Golfo, 1935 Raleigh Sport, 1970 Robin Hood sport, 1974 Schwinn Continental, 1984 Ross MTB/porteur, 2013 Flying Piegon path racer, 2014 Gazelle Toer Populair T8
Quoted: 396 Post(s)
Liked 8 Times
SKS fender stay kits are widely available from sources such as Niagara, Ebay, Amazon, and many other.
Did I catch a niner?
Bikes: Vassago Fisticuff/Surly Ogre/Surly Pugsley/Surly Pugsley 29+
Quoted: 9 Post(s)
Save up to 60% off new Flat Bar Road Bikes - Gravity Liberty FB | Save up to 60% off new road bikes
Is this the bike you have?
I would mount the fender to the top bolt of your disc and not to the hole underneath the disc caliper and leave the drive-side alone.
Quoted: 57 Post(s)
Liked 8 Times
I had no idea until I searched for it on Amazon. I was hoping. It looked like SKS did on their web site, but that page was in German, and for whatever reason Google wouldn't translate it.
Quoted: 57 Post(s)
Liked 8 Times
Thanks, guys!!
afraid of whales
Quoted: 347 Post(s)
Liked 5 Times
Or use the spacer the fenders came with and space the strut out away from the caliper. Use the standard fender threaded hole in the dropout.
Bikes: 2011 Felt Z85 (road/commuter), 2006 Marin Pine Mountain (utility/commuter E-bike), 1995 KHS Alite 1000 (gravel grinder)
Quoted: 676 Post(s)
Liked 13 Times
My utility bike has a rack, fenders and disc brakes. On the rear, the fender/rack mounts are up above the caliper so no problems there.
On the front, I had to use a combination of spacers and bending the stay in a somewhat odd way to make the left side stay fit, without touching the brake caliper (mechanical with moving torque arm to actuate the pads). But it wasn't terribly difficult to get everything mounted up.
Quoted: 676 Post(s)
Liked 13 Times
Actually I said wrong above. My rear rack/fender mounts are above the dropouts, not above the disc calipers. I do use the Topeak Disc Explorer rack to ensure that it clears everything. My fender stays are mounted on the same bolts (only one set in back) as the rack, in between the frame and the rack leg base.
Quoted: 57 Post(s)
Liked 8 Times
no sense of the flexibility of the material? it happens when you have no mechanical back ground, take the bike to a Bike Shop , let them see the project.
Obviously I cannot.
Turn the job over.. pay em a few bux..
Obviously I cannot.
Quoted: 57 Post(s)
Liked 8 Times
LOL!!
Did you fall off of your bike on the way home from the pub last night, Bob?
