Help with a seriously stuck stem
Quoted: 5915 Post(s)
Liked 3,568 Times
I'm having fun working on a new to me 1996 bianchi volpe. The bike was in great shape when I picked it up. I rode the bike but didn't bother to check whether the stem was stuck. It is one of those deeply recessed stems. It's rounded out and frozen good and tight.
What's the best way to remove this? I figure I'll have to destroy the stem to get it out. I'm thinking of just hacksawing the stem in half. Is this a bad idea or is there a better way to do this?
Is the bolt hole stripped? If so, i would drill the head of the bolt off and drive the bolt shank down to release the quill. You shouldn't damage more than bolt.
Quoted: 18449 Post(s)
Liked 4,560 Times
There are also bolt extractors at your local hardware store that would be worth a try. Make sure you're using the right size of Allen wrench. Or, sometimes a TORX bit can be driven into an Allen wrench head.
Once you get he bolt loose, make sure you tap it down.
Try using a 50/50 mix of acetone and ATF. May have to soak for week or so.
Il faut de l'audace, encore de l'audace, toujours de l'audace
1980 3Rensho-- 1975 Raleigh Sprite 3spd
1990s Raleigh M20 MTB--2007 Windsor Hour (track)
1988 Ducati 750 F1
1988 Ducati 750 F1
jam in a Torx bit, back the quill bolt out , leave the wrench in the hex socket hit the wrench with hammer..
its recessed just not sticking up when bolt loose as it would be with most stems
looks Tig welded steel ..
Liked 3,568 Times
Yeah it's rounded out; the bolt is recessed around an inch into the stem. Drilling it out sounds like a plan. I'm OK if I damage the stem since I'm not planning on using it. Yeah and the stem does look like steel.
