How to diagnose/troubleshoot/fix Favero Assioma Duo PM?
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4392 Post(s)
Liked 3,016 Times
With the Favero Assioma Duo PM pedals, it's the left pedal that does all the communications with the app and the headset. If the left pedal stops working, the system is 100% non-functional.
And my left pedal seems to have died. It doesn't communicate, the lights don't come on, etc. When the USB charging magnetic clamp is attached....nothing. The problem is not with the charging clamp b/c the same clamp connects fine to the other pedal. I've examined the electrical contacts on the left pedal that should help it connect to the clamp, and they look clean and otherwise OK.
Apart from contacting FA customer service (which I've done), does anybody know anything else that can be done to diagnose or troubleshoot? The manual doesn't seem to have much relevant information.
Pedals are 3 years old.
Liked 3,016 Times
And wouldn't you know it, my HRM strap just broke (metal snap detached from strap). Easy to replace, but I'm going to be riding with less data for a little while. That's probably good for me.
If you do a Bluetooth scan can you see the right pedal?
If you can see the right pedal my app may be able to use that pedal and give you power information. I would be glad to have you try it. You need an Android phone to run the app.
PM me or contact me on my website.
Chuck
https://cykelstrom.com
Chuck
Liked 3,016 Times
Chuck
Chuck
