So what's in your tool bag?
I'm the sand paper! JK!
Sand paper for patching tubes so the glue sticks better. Twine and zip ties holding stuff together in case they break or if I have to remove broken parts and have to secure them on the rack. I often use twine to secure things on the rack because they're much lighter than bungee cords.
I also use the twine as "poor man's" substitute for a proper bike stand. If you've dealt with bikes for a very long time, you'll eventually experience that even if you lean the bike against a wall, there are times it can still fall over with surprising ease or with very little disturbance, especially when the front wheel is steered off the wall on its own or by other people passing near the bike. The twine's job is simple, tie the front wheel to the down tube to keep it from turning. It's makes bike a lot harder to fall while leaning against a wall and also prevents the bike from rolling if the ground or the floor is inclined. I sometimes do it on rides if I have to make a short stop and get off the bike.
As for patches, I've had garbage luck with any patches I try on the side of the road. However, I do have very good luck with patched tubes I do at home. In fact, most of my bikes right now are riding on tubes that have been patched at least once. I'll patch a tube two times before I replace it. I bought a can of rubber cement and just cut up an old tube to make patches. I have a Dremel with an abrasive bit and then I set an old motorcycle battery over the patch for a day until the cement cures. I have really good success with these repairs. Never had good luck with the kits, so I carry a spare tube but no patches. If I get a puncture, I'll replace the tube and then head home just in case since I only have one repair available.
Likes For VegasJen:
The Wheezing Geezer
Bikes: 1976 Fredo Speciale, Jamis Citizen 1, Ellis-Briggs FAVORI, Rivendell Clem Smith Jr.
Quoted: 414 Post(s)
Liked 920 Times
Yes, levers. The cross-shaped things also commonly used as blunt instruments, in popular imagination at least, are also known as tire irons, but are more properly referred to as lug wrenches, according to a quick google.
Quoted: 18420 Post(s)
Liked 15,564 Times
Likes For indyfabz:
Mother Nature's Son
Quoted: 853 Post(s)
Liked 1,437 Times
tool bag?
Likes For delbiker1:
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
Ya, there are strong arguments for carrying a phone when you ride, especially for females. One of the things that p!$$ me off and I just don't understand is why I can't have a second (or third) phone that works on my primary number. I would be much more receptive to getting a cheap, throw-away phone if I could just put it on the same number But that's a whole cell phone service can of worms there.
Personally, I have had to walk home once because I ran out of CO2, and once because the pump seal blew (cheap pump). Another good reason for carrying both (and not going cheap on the pump).
The biggest reason to have a pump over CO2 is that you can only have as many flats as your CO2 will fill. Since it's also a pain to use a tiny pump, it makes a good argument for carrying both. 2 CO2 to facilitate fast flat changes, and a pump to at least get you back rolling again should you be horribly unlucky. Switching to tubeless is also an option, but blowouts can still happen.
It's like riding a bicycle
Bikes: Masi, Giant TCR, Eisentraut (retired), Jamis Aurora Elite, Zullo, Cannondale, 84 & 93 Stumpjumpers, Waterford, Tern D8, Bianchi, Gunner Roadie, Serotta, Serotta Duette, was gifted a Diamond Back
Quoted: 305 Post(s)
Liked 2,038 Times
Tire irons is the old phrase for tire levers. My favorite is the VAR tire tool.
Roadie
Quoted: 23 Post(s)
Liked 57 Times
I carry two CO2 and a small hand pump. The kind that attaches to the bottle cage. It's like a little fire extinguisher that gives peace of mind, and allows me to help another rider without going into my cartridge "stash." Make sure to have a presta/shrader converter (chuck?) too. The only time I needed roadside assistance was a broken rear skewer. Fortunately close to home.
Likes For Pinelander:
Quoted: 6196 Post(s)
Liked 4,810 Times
In addition to what the OP carries, less one CO2 cartridge, I have a pair of latex gloves and my house key. The house key is the only thing that's been used in the last 18 months or so. Not sure if it's even worth carrying for local 2 - 3 hour rides. But I guess the Boy Scout pledges I made long ago require me to Be Prepared!
Quoted: 6972 Post(s)
Liked 10,968 Times
Also, a pump is often preferable for tubeless tires. I once had a puncture that didn't quite seal, so I plugged it and pumped it back up. A CO2 cartridge would've been overkill.
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
Agreed. Haven't had to use a cartridge since going tubeless (including 2 flats so far), but I'm considering keeping my CO2 handy in case a tire goes completely flat and needs to be seated again. Even then, a tube could solve that problem.
Likes For urbanknight:
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
You have a warrant?
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,994 Times
I like the idea of the nitrile gloves. I always wear riding gloves when I'm out but I don't like getting them funky with grease or road grime. I should put some nitriles in my pouches. Thanks for that.
For those of you that carry pumps, is there a reason you prefer a pump over a C02 inflator?
What's the sand paper and twine for?
A pump doesn't run out of air yes it can break but so can anything. When I am out of C02 cartridges I am out of air, plus CO2 is a smaller molecule so it will escape from tube and tire faster. Plus pumps can last a long long time vs CO2 being a disposable item.
Liked 15,564 Times
Not all tire-rim combinations play nice with tubes. Twice Ive had to put a tube in my Schwalbe Pro 1 25c tires. Both times the tire would not seat properly around the valve stem area. There isnt enough room to accommodate the extra material where the valve stem is attached to the tube. Had to limp home both times with a little hop in the tire.
Likes For indyfabz:
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
Liked 15,564 Times
Likes For indyfabz:
One bike's tool bag has a CO2 inflator, the other two share a Pro Bike Tool mini pump. Each has a multi-tool. My old racing bike has a 5.5 mm or 7/32" Allen key for its seat bolt in the tool bag, plus an 8/10 mm wrench for its old-fashioned nuts. I'm relying on sealant for it at present, but carry spare tubes and tire irons on the other two.
Tool-kit lite
For myself, I add my asthma tooter, a handkerchief, and a mask, these days.
Tool-kit lite
Quoted: 2333 Post(s)
Liked 2,097 Times
In addition to the typical stuff
1. Spare cleat and hardware
2. Small tube of superglue
3. Assortment of zipties
4. Spare valve core and tool
5. Real boot cut from old tire
6. Dynaplugs
7. Spare batteries
8. small single use eye drops
9. Derriere lube
10. Pain medicine
6. Dynaplugs
7. Spare batteries
9. Derriere lube
10. Pain medicine
Old fart
Quoted: 3590 Post(s)
Liked 3,400 Times
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
What model of tire was that? I just ditched my Open Corsas because something similar happened at about 300 miles. It sealed enough to get home by pumping it back up every hour, but there was a sealant booger sticking out of the gash and a slight bulge in the tire the whole way. To be fair, I think I messed up trying to insert the bacon strip, but even if successful, all signs point to replacing the tire when you get home anyway.
Liked 15,564 Times
Likes For indyfabz:
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2584 Post(s)
Liked 5,642 Times
VegasJen, you may want to buy a cheap burner phone to carry with you for safety. Besides being harassed and needing to call 911, in the event you crash and can’t be seen or need immediate help, you can call 911. You may be able to program your real phone to forward to your burner as well. I’m a dude and always carry a phone in my back jersey pockets (25 years) and have never had a phone eject, even while doing some rugged mountain biking.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Liked 2,097 Times
A pump is lighter than two cartridges and inflator attachment, plus it has a gage on it. And, when you flat you do not have to ride home if you only have one spare, no patches, and only one CO2 cartridge. In the rain, cold and/or darkness, CO2 is a nice luxury.
Quoted: 2700 Post(s)
Liked 486 Times
I just carry weed and stuff to smoke it with in my saddlebag. No room for tools
Some people like pumps because they are reusable. Also there is something cathartic about sitting on the side of the road for 3 minutes trying to get a tire hard enough with a dinky little pump
