Unknown Sekine please help identify
Quoted: 33 Post(s)
Liked 7 Times
Looks all original, was wondering if it's worth buying, any idea what frame and rim material and if the rest of the components are worth it?
Car free since 2018
Bikes: Mostly japanese ones
Quoted: 259 Post(s)
Liked 270 Times
Depends on how much they're asking for it. Not sure what model it is but it seems to be the more common lower end one. The higher up models are champion 5, and this isn't one of them. The better ones have chrome on the chainstays, if I'm not mistaken.
Quoted: 4722 Post(s)
Liked 3,044 Times
The subject bicycle appears to be a Sekine RM-30 from the very early 1980s. It is an upper, entry level model. The frame is hi-tensile steel and the rims are steel. The brakes appear to be Shimano Tourney, while the crankset appears to be a Shimano Selecta T. The derailleurs are a bit harder to identify, either Tourney or Altus ST but the shift levers look like Altus. During this era, it was rare to get aluminum rims on hubs with nutted axles.
Liked 3,044 Times
Tange #5 was plain gauge CrMo. I've never seen it used on a Sekine from the era when they had their Canadian factory. The ones with half chromed stays from the mid-1970s used double butted CrMo and are either Tange #3 or #2.
Quoted: 33 Post(s)
Liked 7 Times
Thank you so much for the responses guys, I find Sekine bikes to be among the least documented vintage bikes despite an apparent popularity. I tried to go through some online posts, I found this https://cycle.haus/mytenspeeds/Featu...y_Canadian.htm, now with the exception of the crank which as mentioned by T-mar is a Shimano Selecta T, the SEKINE SHC 271appears to be identical to the subject bicycle in the saddle, chrome pattern, shifters and brake levers, brakes and even rim reflectors!
Edit, both are also are NOT quick release axels
Car free since 2018
Quoted: 259 Post(s)
Liked 270 Times
Well, I'll defer to what T-Mar says. All the Sekines I've seen advertised were a little too big for me so I never went to see them.
ambulatory senior
Quoted: 1957 Post(s)
Liked 3,664 Times
Poor pic of my girlfriend's sekine but it is straight guage chromolly with no derailleur hanger. Sort of an Asian supercourse to my mind. I try to build her better bikes but she won't have anything else. Frankly it's a very nice ride.
Likes For 52telecaster:
Liked 3,044 Times
This one, identified as an SHC, is actually a slightly earlier version of the RM-30, circa 1978-1979.
Quoted: 33 Post(s)
Liked 7 Times
thx T-mar, any idea where I can find more info on the RM-30? specs, sizing, etc? the rims look so shiny and not rusted in any way, I hope they are not steal! I might go see it soon, if I like it, it will be my new commuter
Liked 3,044 Times
If the rims are OEM, then they are steel. They look like steel and the given the nutted axles, they most likely are steel. Male Sekine models were typically offered in 21", 23" and 25" frame sizes. Sometimes, you'd get a popular, upper entry level model offered in 27". The subject bicycle appears to be 25".
That combo describes perhaps the best-riding frame I've ever owned.
Liked 3,044 Times
That looks like a rebuilt Sekine SHR, circa 1972, before the Canadian factory opened and when they were being distributed in the USA by Beacon Cycle. I assume it originally was equipped with SunTour derailleurs?
