Front derailleur H-Limit Adjustment
Mad bike riding scientist
Quoted: 6222 Post(s)
Liked 4,222 Times
So this is cable problem? What’s the fix? Just tighten the barrel adjuster? In Calvin Jones’ fd adjustment, after the h-limit setup, he did fd indexing ( which i don’t see in any fd tune up tutorials) where while on the big ring, he intentionally caused movement on the derailleur via the barrel adjuster, then readjusted it until there is no more movement. Is this the fix? Cause i also thought of doing that as a possible fix.
The trim feature should work on the middle ring. It’s not a feature for the outer ring.
Stuart Black
Stuart Black
Quoted: 1110 Post(s)
Liked 1,204 Times
I guess I always assumed that the 6500 double had trim (i.e. three clicks for two rings). and the 105 and Dura Ace of that era also had trim. I guess I'm wrong?
This article on FD trim involves Shimano 10 speed:
Can someone explain the trim operation on shimano 105 — BikeRadar
FWIW, Sram 10 speed double shifters had trim (3 clicks) until, I they came out with yaw FDs then I think they might have done away with the three click trim? Really have no idea on that because I have "original" 10 speed shifters with three clicks and they work with both the original FD I have on one bike and the newer Yaw FD on the other.
Liked 1,204 Times
No much less useful. Rather than arguing why don't you just say, I know it doesn't at all help the OP with his issue, but I just thought I'd mention it in case he wasn't aware of these legacy options. FWIW, friction shifting - in my personal experience having friction shifted for the first 20 years of my cycling life - is very fussy with cassettes 9 speed and larger. Meaning difficult to do quickly and accurately without fussing with trimming the friction lever. Not talking about FD, it's as easy now as it was in the 5 speed era.
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times
My 6503 (9 speed triple) had trimming. There were 4 clicks for three rings. I can't remember if the trim was between the middle and small or middle and large (maybe both?). IIRC, my wife's Tiagra triple 9 speed also had 4 click trim.
Yes, it's true that the SRAM yaw systems no longer have trim positions. In theory, you no longer need trim positions, but it's very tricky to set up.
Yes, that’s the fix. Your cable isn’t tight enough. Be careful not to get the cable too tight or allow the derailer to move too far outboard. This can cause lag on downshifts. The outer plate should just clear the chain when in the large ring/small cog combination. Some adjustment with the barrel adjuster may be needed over time as the cable gets rid of the construction stretch. Eventually, the cable should bed in and stop stretching but it may take some time.
Liked 4,222 Times
Not unless the chain is rubbing when the cable is tight. But be careful about the tightness of the cable. It can interfere with the action of the derailer on downshifts. It’s a bit of a Goldilocks situation. It really has to be “just right”.
Stuart Black
Stuart Black
Liked 1,204 Times
I got a yaw FD for some reason (maybe when I was looking for parts for a new 10 speed build with shifters I had on hand?), but kept the old style shifters with the trim positions. I just use them that way and don't really know if the yaw works well without trim.
Sock Puppet
Liked 863 Times
I installed Force 22 shifters and derailleurs on my road bike. It took awhile, but I finally got it silent on every combo except large-large which I never use anyway.
Likes For Lombard:
cyccommute Hey man. Came back here to say it worked. After tightening the barrel adjuster that fixed the fd movement, i did have to tighten the h-limit a bit to shorten the gap between outer fd plate chain to 1mm. Did not affect shifting at all, if anything, i think it shifts a little better. Again, thanks!
Likes For iamLefty:
Liked 4,222 Times
Stuart Black
Stuart Black
Likes For cyccommute:
