Most accurate way to set Heart rate zones?
Curmudgeon
Bikes: Specialized Diverge Comp
Quoted: 157 Post(s)
Liked 32 Times
Zwift and Strava have always provided different heartrate zones for me. I know of a different tool or technology to measure HR.
What is the most accurate way to set HR zones?
This is going to be subjective as no two people are alike. The couch potatoe that is 30 lbs overweight is not the same as someone who is fit and does aerobic exercises on a regular basis.
There have been studies that show the maximum benefit for athletes is at 80% of their max heart rate (per the usual calculation). I use that to maintain a certain level of intensity on rides but nothing more.
Habitual User
Quoted: 4946 Post(s)
Liked 8,087 Times
2. Know your body really well.
Likes For Eric F:
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2582 Post(s)
Liked 5,639 Times
The online free calculators are pretty much garbage. This is based on using age based formulas that don’t reflect individual differences. Zwift at least knows your maximum, at least if you have done a FTP test or have really pushed yourself to the max, and can back calculate your zones from there. Still can’t figure out how to add the max to Strava but it seems to know from Zwift. Eric’s lab test might be the best measure of calculating zones.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Likes For rsbob:
Quoted: 241 Post(s)
Liked 454 Times
Most are reasonably accurate for the average person.
More important is tracking your max heart rate. Zone tracking is determined by the max heart rate a person inputs when using a zone method.
Your max heart rate will change as you become more or less "heart fit"...the fitter you become aerobically/anaerobically the higher your max heart rate will be and as you achieve new heights you have to adjust your zone tracking system to indicate the new max heart rate.
As an example my current max heart rate is 182bpm measured last year during a hill climb race with a friend during a training session. I use TrainingPeaks 5 zone system...they offer a wide variety of zone systems and I prefer the 5 zone for no particular reason. My zone 1 is 123-132bpm, zone 2 is 133-142bpm, etc. I can be just tooling along doing a zone 2 pace while someone less heart fit may be in zone 3 at that target heart rate...fitness rules.
I use the 5 zone system because I feel a 10bpm range between zones is very manageable and easy to use. More zones mean a more narrow range and imo becomes clumsy, less zones is too wide a range...again just my opinion.
I also view the tracking data on my Garmin edge device and Strava and find them similar enough to TP.
The old method of subtracting your age from 220bpm is an inaccurate method and imo is used for the average person who is barely fit. I'm 67 so subtracting my age from 220 means my max bpm is 153 lol. That is zone 3 for me lol. My time trial cruising pace is 165bpm for an hour or more thus blowing up that silly method.
How do you monitor your heart rate during a workout? Have you determined what your max heart rate is at this time? Have you tried?
Most important is to be aware of your system medically before pushing too hard. Are you heart healthy? Are you fit or just starting out? Do you use a journal to record, track and monitor your condition, changes, how you feel, etc?
Good luck and "Ride On"...
Quoted: 6193 Post(s)
Liked 4,809 Times
I set up my zones by lactate threshold hr. https://www.trainingpeaks.com/learn/...setting-zones/
However you should probably use the method that is suggested by the HR training program you are going to use. Though I'd also recommend you use one that goes by LTHR if you don't have a PM to use power based training.
Likes For Iride01:
Quoted: 1949 Post(s)
Liked 2,010 Times
Pay $ for a lab workout to find LT and stuff like that. And then pay $ again after a couple months of disciplined training. OR, use a time trial method as described by coaches in the pre-power meter days: like Joe Friel or Chris Carmichael. There must be others but I had good results with those two. Carmichael's zones are narrower which makes sense when you monitor your HR for a while and make note of the range in perceived effort within the boundaries of most HR zone training systems.
Likes For Classtime:
Curmudgeon
Quoted: 157 Post(s)
Liked 32 Times
Curmudgeon
Quoted: 157 Post(s)
Liked 32 Times
I also had a Wahoo Systm account for a year+ and their 4D annalysis was very detailed but, again, provided different zones that Zwift and Strava. Three different plateforms and three different zone ranges; thats what prompted me to ask in this forum. Thanks all for your input so far.
Grupetto Bob
Liked 5,639 Times
I found this tool corresponds works well for me and corresponds with what Garmin calculates for me: https://www.myprocoach.net/calculators/hr-zones/. I use it on my trainer as well
Likes For rsbob:
Habitual User
Liked 8,087 Times
just another gosling
Quoted: 3889 Post(s)
Liked 1,938 Times
I like to use lactate threshold, but don't want to fly somewhere to get the lab workup or buy a meter and stop every few minutes to measure. So I go by breathing, testing myself on my rollers to find VT1 and VT2. Lactate threshold should be just a couple beats below VT2, and VT1 is the break between slow and deep breathing and more rapid and deep breathing. So I put my guess at LT into the TrainingPeaks calculator to see zones. Then I modify the Z2-3 junction according to my VT1 HR. I never used MHR, which doesn't seem to have a whole lot to do with one's lactate levels. Maybe it does statistically but not so much individually. Zones are really all about lactate levels. The three-zone system is even simpler with the upper and lower breakpoint of Z2 being VT1 and VT2 absent actual lactate testing.
I find that training will modify the location of these breakpoints, so I modify my zones from time to time as seems appropriate..
Results matter
Results matter
Likes For Carbonfiberboy:
Those stupid 'heart rate' charts have confused a countless number of people.
Curmudgeon
Quoted: 157 Post(s)
Liked 32 Times
I just completed Wahoo Systm's 4DP FTP test. The results are just slightly lower than what I currently had for my cTHR and HR zones. My summation is; since I am only looking for fitness and overall better health, but am not racing or competing, all three of these platforms are within a reasonable relative range and thus the margin of error is not too signifigant. I will accept some ambiguity.
Likes For rbrides:
Liked 4,809 Times
If you are doing a FTP test, then you must have a PM. My power zones and HR zones don't match at all. They aren't supposed too IMO. I'm not to worried about the ambiguity between them. I'm just riding for overall heath and cardiovascular fitness too. So I don't even use a set training program. I just go for a ride and know there needs to be some easy elements and hard elements mixed in.
Cycling IMO, doesn't do much for for some of the other fitness needs we old people have. And it's notable to me that cycling and walking don't work all the same muscles and those they do aren't worked the same way. So walking is important too. So it's probably important to do some other things too that involve more strength training just to maintain the muscle mass. Particularly the upper body since cycling, at least for me, does nothing for my upper body... other than lungs and heart.
Likes For Iride01:
Curmudgeon
Quoted: 157 Post(s)
Liked 32 Times
Quoted: 4408 Post(s)
Liked 4,861 Times
I agree max heart rate formulas are pretty useless as there is way too much variation across individuals. My max HR would be out by nearly 30 bpm using 220-age. So a worthless formula for me.
Quoted: 241 Post(s)
Liked 454 Times
Your max heart rate is pretty much fixed and then slowly declines with age. Staying fit reduces this decline to some extent, but it is what it is. Your resting and threshold heart rates are more trainable. The fitter you get, the lower your resting heart rate and higher your threshold heart rate goes. Max heartrate is not trainable and varies enormously across individuals, regardless of their fitness level.
I do ride with people who have a lower max heart rate than I do but are as fit or fitter, some less, than I.
I do not know the science behind any of this, only what I read in non-scientific articles, etc. or am aware of based on personal experience and what those around me tell me.
Bikes: Bicycles? Yup.
Quoted: 481 Post(s)
Liked 1,585 Times
Yeah. These Olympic style measuring and training tools don't apply when 10 minutes of pedaling blows up the rider. When I started cycling for fitness I couldn't finish a regular FTP test.
Likes For BTinNYC:
Quoted: 821 Post(s)
Liked 1,655 Times
Stress test at a doctors office while heart activity is being closely monitored is, IMHO, the most accurate way. Either you'll tell the doctor "I've had it" or the doctor will see something on the EKG and tell you to stop. You'll find your maximum HR and figure out your zones from there.
I've had a few stress tests done since my heart attack, know my limit, and set an alarm on my Edge 1030+ when I get to it.
Likes For Bald Paul:
Quoted: 2604 Post(s)
Liked 1,933 Times
Likes For pdlamb:
Bikes: Shmikes
Quoted: 10167 Post(s)
Liked 5,862 Times
Yeah, most labs target 85% of estimated max HR for stress tests and they use one of the known-inaccurate tables for the estimate. The goal is to challenge the coronary circulation enough to spot actionable issues with blood supply, not to max anything out.
Likes For MoAlpha:
Yeah, it seemed a little ridiculous to me when I did a stress test. My MHR is way above what the "know-inaccurate tables predict" so basing the test off of 85% of that low number results in a test at a really easy effort. I may be wrong, but it didn't seem like enough effort to stress the system much at all. I wasn't even fully warmed up yet. The doc seemed to think it was an impressive test for a middle aged guy (that was decades ago, I am well past middle aged now).
Likes For staehpj1:
