Help me bulletproof my daily driver
I have a Mongoose Envoy cargo bike that I converted to electric with a Bafang mid drive. This bike is awesome. It's fast and has more rugged than a regular bike which I need with my weight. But last few days I've been getting flats.
I ordered some new tubes but they didn't last. I noticed the tire had some of the bead torn off so I want to replace both front and rear tires with something better. I don't care about weight because the motor has more than enough power to make up for it.
I'm looking at tire inserts, slime and thicker tubes as well. Whatever works. Also I find that the wheels are very skinny compared to the width of the tire.
Anyway what's the best choice for a 250 pound rider?
Clark W. Griswold
Quoted: 4405 Post(s)
Liked 4,046 Times
Schwalbe Big Apples and Tannus inserts and normal tubes, keep them properly inflated and that should work not bulletproof but I am assuming you aren't actually trying to dodge bullets.
The bike was set up to look like a cargo bike but doesn't seem to be a well spec'd machine but maybe better than most of the Mongeese out there from Wally-Mart and such but not how I would do a modern cargo bike. So the narrow wheels and things like that are sensible as they probably found what was super cheap. They didn't even spec a 36h or 40h wheel for the back on a cargo bike which is a really poor choice on their part but sometimes these companies know their customers want to look the part without the performance of the part.
Quoted: 569 Post(s)
Liked 660 Times
As usual, I suggest Schwalbe Marathon Plus tires, and I think you bike has 26x 2.35' tires, and the Marathons have up to 26x2.0"
If you want REALLY bullet proof, go with the marathons.
(I didn't know the Envoy has a motor. *the more you know)
Likes For CrimsonEclipse:
Quoted: 552 Post(s)
Liked 419 Times
That's why you are swapping tubes every other week.
Not sure why anyone would want to ride with old totally finished crap tyres. Each their own.
A good brand new tyre is a lot cheaper than a lifetime supply of tubes and slime.
Likes For soyabean:
I don't think it does, and unless I missed it the webpage the Envoy page the OP linked doesn't mention one.
The OP said he "converted to electric with a Bafang mid drive". From a very cursory check on Amazon and elsewhere, I believe those Bafang kits include a motor that's added to a bike without one.
Not at all familiar with eBikes or conversions, so I could be wrong
Likes For Hondo6:
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 741 Times
I usually avoid inserts and slime.
and now you know, i hope.
https://www.huskybicycles.com/with-3-speed-hub.html
Method to My Madness
Quoted: 1972 Post(s)
Liked 1,495 Times
Likes For SoSmellyAir:
Quoted: 552 Post(s)
Liked 419 Times
My suggestion is to take the profits and buy a brand new BSO bike with that.
Win!
Quoted: 569 Post(s)
Liked 660 Times
I was focused on the tire problem and overlooked the electric conversion.
Yeesh!
Quoted: 552 Post(s)
Liked 419 Times
That's right. It appears to be retailed exclusively by the amazons.
I would have just bought a real ebike instead of converting.
This is my bike. I changed the handlebars and took off the rack that supports the saddlebags because I never use them. The conversion is a work in progress. I need to remove the motor and reroute the derailleur cable which passes under the bottom bracket.
The rims are really skinny so before I buy new tires and inserts I'd like to get a wider rim and if possible maybe mount wider tires as well. And ideally I'd rather have an internal hub. I had a couple of bikes with internal gears and loved them. I don't need a lot of gears since we don't have a lot of hills here and I don't need to go that fast.
Another issue I have is this pin that came with my trailer. It's supposed to be mounted on the rear axle but in the 3 o'clock position. I had to twist it around a little because it's not a regular frame. It's ok like this the trailer end of the hitch has a lot of play in it. But I'm worried the quick release skewer isn't long enough. I keep taking it off to check but so far I've been using this new trailer for a few weeks and everything looks fine.
Likes For homeless in ca.:
If I ruin this bike I can remove the motor and put it on another bike. I can build another bike using the same conversion kit and use the two batteries I already own to power it. Can't do that with store bought bikes.
Liked 741 Times
you should find an all steel internal cam QR from a mid 95 and up MTB... they're around 145mm from cam face to the end.
Co-Ops usually keep double handfuls of them around.
just remember, if you Over-tighten a QR, it also Over-Tightens the Hub Bearings... QR hubs should have a Tiny bit of play in the axle when out of the bike
does the longer wheelbase help when towing a trailer?
have you weighed it when fully loaded?
Likes For maddog34:
Quoted: 668 Post(s)
Liked 529 Times
Not a bad looking bike. Love my Bafang mid drive as well.
As for tires, the Swalbe Marathons are probably one of the most puncture resistant tires out there, but they are over the top heavy. They really slow down a bike. tire inserts are the same, effective and noticeably slow a bike as well. Sounds like any new tire is going to be a step up from what you have. Just get a good set of new tires, most manufactures rate their tires by puncture resistance, and see if that solves your problem. I've run marathons, they stand up to goat heads like no tomorrow, but they literally take the joy out of riding.
Lots of articles on line about internal hubs and mid drives. I would be a little careful about sending all the torque through an internal hub. Your external derailleur will service you well with that set up.
As for skewers, I have bolt on ones on my Ebike
Amazon.com: Delta Axlerodz Bolt On Bicycle Skewers (1 Pair),extra large : Everything Else
Ordered a pair of Schwalbe pick-up tires, new tubes and liners.
I didn't get the Marathons because I don't want a smaller tire. Reviews said the pick up tire is good for heavy bikes and puncture resistant.
Quoted: 514 Post(s)
Liked 455 Times
This one has Schwalbe Crazy Bob 2.35 tyres on Rhyno Lite 559x22 rims. That bike is broadly the same spec as yours, except without the stretched rear end (it's an old aluminium frame, jump bike steel fork, mid-drive).
Bikes: a couple
Quoted: 563 Post(s)
Liked 863 Times
Go tubeless.
The new tires arrived but I wasn't able to mount them on the skinny rims they are much thicker and stiffer. I put slime in the tubes and they're holding but I need new rims asap.
Clark W. Griswold
Liked 4,046 Times
I'll tell you what I rally want. I want to fit the biggest, widest wheels and tires on my bike with a 3-speed internal hub. Something like this...
Either the Heavy Duty or Extreme. It is super low maintenance (nothing to do in the hub) and can be shifted most anytime though is best while pedaling. Even more so if you are trying to run it as an e-bike as those hubs are designed with e-bikes in mind whereas those old 3 speeds are designed for light duty casual riding generally.
In terms of new wheels, I would not spend much money on the current bike I get the situation but get a proper cargo e-bike and you will be much happier it will be set up haul cargo. However if you really want to keep this going find a good wheel builder and explain to them what you are carrying and where you are riding and all of that and have them build you a set. Maybe not cheap but also not cheap and will be good and reliable.
