Vinyl Wrap for Lugged Steel Frame?
Old 11-21-23, 08:32 AM
ACHiPo
Bikes: Trek 903, BMC Amp X 02, Criterion Pro Tour
Quoted: 43 Post(s)
Liked 40 Times in 24 Posts
Looking for guidance wrapping a chrome lugged frame. Ideally the main triangle will be “kandy “ or chromevelato with transparent/translucent wrap. The head tube I plan to have white/pearl, with chrome stays and lugs.
I’ve found videos on wrapping carbon frames, which seems much more difficult. Trying to decide if I can DIY or turn it over to pros, and if so, which pros?
ACHiPo is offline
Old 11-21-23, 11:20 AM
randyjawa
randyjawa's Avatar
Quoted: 1372 Post(s)
Liked 1,752 Times in 939 Posts
Get yourself a botttle of Liquid Mask, sold in art supply stores. With a small brush, coat the chrome exactly where you don't want paint to stick. I usually do a couple of coats to be sure (belt and suspenders kinda guy)...
Works well, very forgiving and turns out OK in my book....
randyjawa is offline
Old 11-21-23, 12:51 PM
ACHiPo
Quoted: 43 Post(s)
I’m not too worried about masking the lugs, rather how do you get paint to stick to chrome? Wrap seems like it would stick better than paint?
ACHiPo is offline
Old 11-22-23, 09:25 AM
RustyJames
Quoted: 566 Post(s)
Liked 1,052 Times in 545 Posts
I would think that getting a clean seam around a tube would be tricky but maybe a pro has a workaround.
I’ve seen some wraps on cars that were stunning and others that were….unfortunate.
RustyJames is offline
Old 11-22-23, 10:18 AM
ACHiPo
Quoted: 43 Post(s)
Rusty,
Agreed! I found a product from 3M that you lay down under the film then it cuts a clean line where the wrapped film overlaps to make a clean seam. No idea how visible it will be. That’s why I’m asking others for their experience.
https://multimedia.3m.com/mws/media/...ulletin_R3.pdf
The videos I’ve seen of more complex carbon fiber frame wraps look pretty clean.
ACHiPo is offline
Old 11-23-23, 08:06 AM
ACHiPo
Quoted: 43 Post(s)
I found another clip, this time of wrapping a carbon fork without using the knife less tape. I wish they’d zoomed into the seams, but from a few feet away it looks good.
ACHiPo is offline
Old 11-23-23, 08:19 AM
brewerkz
Bikes: '85 Schwinn Madison, '46 Higgins Ultralite, 1950s Wally Green, '85 Trek 660, '82 3Rensho Export, '90 Trek 970, '91 Schwinn Paramount, '78 Dawes, '78 Trek 730
Quoted: 77 Post(s)
Liked 263 Times in 108 Posts
If you go DIY, I would guess it may take a few tries. First time your figuring it out, 2nd time you learn from your mistakes.
If you go PRO, I would think a shop that does motorcycles would be the best bet.
brewerkz is offline
Likes For brewerkz:
Old 11-23-23, 08:51 AM
ACHiPo
Quoted: 43 Post(s)
Originally Posted by brewerkz
If you go DIY, I would guess it make take a few tries. First time your figuring it out, 2nd time you learn from your mistakes.
Both good recommendations. Thanks. One of the frustrating things of DIY is the audacity to think that I can do in one try what it takes pros years of practice to learn and they still use a mock up!
The knife less tape is pretty expensive and only comes in large quantities. The film is pretty cheap in lugged tube sizes (48” x 12” should be enough to do a single top, down, or seat tube and go for $6, so even with a few practice pieces I should be able to keep it under $100. They also sell 12” x 12” pieces which should be enough for 2-3 goes at a head tube)
ACHiPo is offline
Old 11-23-23, 12:03 PM
brewerkz
Quoted: 77 Post(s)
I am curious how this comes out....I would like to give it a try as well.
brewerkz is offline
Old 11-23-23, 12:13 PM
ACHiPo
Quoted: 43 Post(s)
I will post my progress when I get around to it. I have many more projects/interests than time, so it’s all about motivation and priorities.
ACHiPo is offline
