SRAM Rival 1 1x11 crankset
Bikes: State 4130 Custom, Giant Trance 29
Quoted: 422 Post(s)
Liked 183 Times
I installed the new crankset onto my State 4130 frame with a GXP 68mm BB. I have found that the non drive side has 2mm of space between the crank and the frame.
I had thought this crankset should be ok on a frame with a 12x142 wheel, but am now not sure since I cannot locate any definite answer on SRAM's site. Wondering if anyone knows for sure here?
I am considering installing the 2.5mm spacers after taking BB off and reinstalling it. The drive side has 5mm space between crank and frame. Any Advise? Did I just purchase the wrong crankset?
The Crankset: https://www.sram.com/en/sram/models/fc-riv-1-a1
Thanks!
Thanks!
Quoted: 6251 Post(s)
Liked 4,851 Times
A miss is as good as a mile.
Liked 4,851 Times
If it doesn't change up your chain line in too negative a way, you can play with spacer combinations on the two sides of your BB. If you have spacers to play with.
You might see if the maker of those cranks publishes the q-factor in the spec's and compare it to the q-factor of any previous cranks you had on that frame. If you went to longer crank arms, but the q-factor remained the same between the cranks, then what you are seeing is the spread of the chain stays widening to get closer to that longer crank arm.
I can't quite remember where q-factor is measured to. Maybe another does. But it's either the inboard point where the pedal hole starts or the outboard point of that pedal hole... IIRC.
Likes For Iride01:
Quoted: 422 Post(s)
Liked 183 Times
Likes For KCT1986:
Quoted: 422 Post(s)
Liked 183 Times
Thanks, I have this past few hours researched further and found this crank will not work with the frame. I should have purchased a wide version of the Apex or Rival Crank. This Rival crankset only works with road bikes for thinner rear wheels. It is not compatible for a 12x142, even with the spacers added.
This is what happens when looking for good deals and not diving into details as much as I needed to. Unfortunately I purchased from Colorado Cycles and they will not take returns if item was removed from package and installed. BUT, I might install it onto another bike that it would fit on.
Now I'm just trying to decide what crankset I want to spend money on. I might just get the crankset from State Bikes that I know will fit the bike.
Likes For KCT1986:
