little brake adjustment lever/thumbwheel name? Replaceable?
Bikes: Trek Madone 5.2 SL 2007, Look KG386, R022 Re-framed Azzurri Primo, Felt Z5, Trek F7.3 FX
Quoted: 404 Post(s)
Liked 85 Times
Please would someone tell me the official name for little brake adjustment lever, that you open to take your wheel off, or for minor adjustments of brake tension on the road?
Are these things purchasable as Shimano (rear BR5800)? I broke the lever off mine because it got stiff and I used pliers on it. Now I can't turn it without pliers. On auctions Japan there are only spare pairs of brakes that I can see and they start at about 40USD second-hand for a set, or a new rear BR-R7000 (105) brake which is about the same price.
I think you refer to the brake caliper’s quick release lever.
Bikes: 2016 Trek Emonda S6 frameset, custom build (road). 1995 Dawes Genesis Reynolds 531 Competition frameset, custom build (road). 1996 Orange C16R frameset, custom build (retro MTB). Coyote Dual hard-tail, custom build (MTB).
Quoted: 61 Post(s)
Liked 76 Times
This perhaps
just another gosling
Quoted: 3889 Post(s)
Liked 1,939 Times
I've never seen them for sale separately.
Results matter
Results matter
Quoted: 1529 Post(s)
Liked 718 Times
I think on 105 and below, they're riveted on. You could probably grind off the rivet and fit one from an Ultegra or Dura-Ace brake of suitable vintage, but in almost all cases you'd be better off just chucking another brake on (unless of course you found a busted brake of the right sort).
Quoted: 404 Post(s)
Liked 85 Times
Thank you. Spot on, as demonstrated by Bob's picture.
Thank you very much yes that. So it is not for adjustment. I read elsewhere that fully open and fully closed are safe but that midway positions may result in braking failure.
Thank you.
Thank you. I trust and believe you are entirely right.
Drat. It seems like I am going to have to pay 40USD for a new brake, or about that for a second hand pair.
At the moment I am making do with a "dangerous" midway position where I can just about push the tire through the pads.
Thank you.
Zoom zoom zoom zoom bonk
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Fuji Tahoe, Scott Sub 35, Kona Rove, Trek Verve+2
Quoted: 551 Post(s)
Liked 722 Times
Well, I do use mine for adjustment. Oops.
If it seized that badly what condition is the rest of the calliper in?
Liked 718 Times
Pretty sure the Shimano QRs work fine as an adjustment; put one halfway open and reef on the brake lever, and you won't budge it. Clever design.
If it's the tear brake, I'd just use the barrel adjuster for a slow release and forget about it. If it's the front brake, you can just swap the arm over, only the spindle is different. (Your front wheel comes off more often, right?)
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1325 Post(s)
Liked 1,306 Times
^ This.
If it's seized or that tight then you've let it get far to dirty/corroded. When anything like that comes into the shop I yank the caliper from the frame and soak it. Then I blow it out with compressed air and lube up everything that is supposed to be able to move.
That's all being paid for at my shop rate.
Even if you could find the part - I'm going to go out on a limb and suggest you need a new caliper and by the time you get done messing with the current one you would most likely have been better off just buying a new one.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
Quoted: 61 Post(s)
Liked 76 Times
Quoted: 61 Post(s)
Liked 76 Times
Likes For Bob the Mech:
Pizzaiolo Americano
Thank you.
Thank you.
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
That was copied from Campagnolo's original Record caliper from 1969. It was intended to be used to open the caliper for wheel removal or as a short-term fix for a badly out-of-true wheel until your team car could provide a replacement, not as a long term adjustment that's what the barrel adjuster is for. Everybody started using it when Campagnolo's patent lapsed.
Likes For JohnDThompson:
Quoted: 404 Post(s)
Liked 85 Times
It must be nice to have a "bike room." Our tool shed is for everything.
Thanks for letting me know that the halfway position is okay. I am not sure of the condition of the rear brake other than that it works okay. I guess it needs taking apart and cleaning.
There is also a set of dual pivot R7000 73usd all in. They look nice.
I bought a dual pivot R7000 rear only for 40USD from Amazon Japan.
Thank you for everyone's advice.
The R7000 rear brake is now on the bike and I am imagining I detect a performance improvement.
Likes For timtak:
