Looking for a new pump
Bikes: Specialized Allez Sport Sora (now), Whistle Modod Flatbar (retired)
Quoted: 43 Post(s)
Liked 21 Times
My 7+ year old truck pump has started having problems, mostly air coming our when the head gets tilted a bit when mounted on presta valves. I thought of repairing it, but I feel like it is time to go away from the cheapos and get me a quality one.
I am mainly eyeing two pumps, the expensive Silca Pista Plus and the much less expensive Lezyne Alloy. Do you think that it is worth squeezing out my budget for the Silca? Do you recommend something else (available in EU)?
Quoted: 332 Post(s)
Liked 742 Times
Silca pumps are beautiful, and for some reason I’ve always had terrible luck with their reliability. Personally I’d pick the Lezyne, I haven’t used their floor pumps much but do have good experiences with their frame pumps and other products.
But generally I tend to recommend the $50 Topeak Joe Blow, which has worked great for me for over 10 years, with one replacement of the rubber gaskets in the head during that time.
Likes For bboy314:
Quoted: 2604 Post(s)
Liked 1,933 Times
Any reason you've skipped over the Silca Pista floor pump for the ($60 more expensive) Silca Pista Plus? I've got a 20 year old Silca, similar to the straight Pista, that I pumped my tires up with yesterday.
Unlike @bboy314, I've had much worse luck with Lezyne. Actually the pump still works fine, but the gauge quit after a couple years, and the replacement gauge was nearly the price of an entirely new pump.
Quoted: 839 Post(s)
Liked 1,063 Times
SKS Rennkompressor is another good one. Super sturdy and replacement parts are available. Mines about 10yrs old and gets used around 3 times a week and is still all original. A little pricey these days at just under $90 and if you shop around maybe cheaper but you won't have to buy another one. Don't know if it's the best pump but certainly one of the best. Rennkompressor Floor Pump – SKS USA (sks-us.com)
Likes For Crankycrank:
I don't know.
Quoted: 317 Post(s)
Liked 853 Times
^^ that looks nice.
Quoted: 3513 Post(s)
Liked 2,927 Times
I love my Silca Pista Plus with a Hiro chuck. Yes, this setup is pretty expensive (more so than when I got my setup a year or two ago), but it's the last I'll ever own. Every component is easily replaceable.
The regular aluminum chuck isn't bad. The Hiro is just so much easier to use.
And I'd rather have a leather gasket/plunger than rubber.
Likes For smd4:
Liked 2,927 Times
Quoted: 6196 Post(s)
Liked 4,811 Times
I've had my Zefal floor pump since prior to 2009. Cost me less than 10 bucks and sometime between now and then I put a 4 dollar hose/airchuck on it when the original air chuck went bad. And it gets used often.
For the price of a high quality floor pump, I could just buy a couple dozen of these cheapo's that last over ten year and be set for several lifetimes.
But if the quality of the build appeals to you then go for it.
Liked 1,933 Times
And I agree with you on the Hiro chuck. I got lucky enough to grab one on Silca's year-end clearance sale a few years back, and no other pump chuck comes close.
Quoted: 1609 Post(s)
Liked 2,216 Times
I went used on Silca pumps, Parts readily available. Had to refurbish the check valve. Over 20 years use.
P1040744 ,on Flickr
PXL_20221201_130323696
on Flickr
Also invested in Amazon.com: KUWAHARA HIRAME Pump Head Yoko with Hose Band : Clothing, Shoes & Jewelryj which is working extremely well.
P1040744 ,on Flickr
on Flickr
Likes For SJX426:
Quoted: 43 Post(s)
Liked 21 Times
Quoted: 83 Post(s)
Liked 64 Times
Over 20 years ago I bought a Blackburn Track pump. Guaranteed for life and it got a LOT of use. About 10 years ago it began to fail and they replaced it without any hassle. Fast forward - about 2 yrs ago the newer head began to leak and parts were unavailable. They offered to replace the pump again but I just asked for an entire new pump head. They stand behind their products. Good company and good products.
Likes For veloz:
aged to perfection
Quoted: 839 Post(s)
Liked 1,258 Times
find a used silca pump on ebay, order the rebuild kit and new hose, and put a Hirame pump head on it.
probably not much less than a new one when you add in shipping
but will last just about forever
PS the best silca pump is the one with the wooden handle, it is slightly larger than the Pista.
/markp
/markp
Likes For mpetry912:
Liked 1,933 Times
I need a foot on the bottom to keep the base from coming off the ground on the pump upstroke anyway, and that foot holds the pump upright. I don't need to keep it standing free for a supported group ride, nor for a shop display, so it's not a problem for me.
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1948 Post(s)
Liked 1,471 Times
Quoted: 2026 Post(s)
Liked 1,096 Times
Recreational Road Cyclist
Quoted: 257 Post(s)
Liked 252 Times
My other pump is a 1974 Rampar-branded Medai. I replaced the original hose and chuck with one of the Shrader/Presta double heads, and mainly use it to air up the car tires.
I wish I'd bought the Hirame chuck when I first learned of it, instead of waiting until I was a bit more flush. For many years I used that Silca brass bell chuck, what a pain in the keester. But it was authentic Italian...
And yeah, the Pista just wants to fall over.
Quoted: 839 Post(s)
Liked 1,063 Times
Liked 1,471 Times
Liked 2,927 Times
Quoted: 431 Post(s)
Liked 460 Times
Another vote for Lezyne. Have two pumps, an alloy one and a steel one. Had to replace the hose and chuck on the older one just recently after 12 years of service. Been happy with both of them. The threaded attachment is a huge plus for me even though it does require tightening the valves on tubes with removable cores first.
Quoted: 257 Post(s)
Liked 252 Times
Shrader chucks don't have threads, do they? The ones I am familiar with, for bikes, are pressure fit, with some kind of lever that squeezes a gasket. But really, anyone who drops this kind of money on a chuck isn't likely to be looking to attach it to s Shrader chuck. At least I'm not.
Liked 2,927 Times
Do whut?
If you’ve seen just about any Presta adapter for Schrader valves, they’re threaded.
Silca Presta Adapter
Schrader valves themselves are threaded.
If you’re dropping this kind of money on a Hiro, it’s far easier/more elegant to thread it on to the end of the hose than using a hose clamp.
Likes For smd4:
