How Does Chain Length Affect SI?
Bikes: Hetchins, Dawes, Raleigh, Holdsworth, Standard Cycle Co, and others
Quoted: 34 Post(s)
Liked 6 Times
I have been scratch building a road bike using a Trek compact frame,and mostly Shimano 105 components. Mostly I build older vintege bikes, so its not often I touch 10 speed gears.
Normally I measure new chain length using big to big +2 links, but I had read that for 10 speeds you should use small to small and thread the chain through the derailleur, so I used that method.
However, when I cam to set up the SI, I could not get it to work. The derailleur did not seem to be indexing and would not reach the two largest cogs. I adjusted the angle in case the derailleur was hitting the cogs, I double checked parts numbers in case I had a non 10 speed, changed the outer cables, as I had been a bit tight - no change.
The only change I had made was to measure the chain. So I split the chain, re-measured my normal way and there was a 4 link difference (too long). I rechecked the new way, and I appeared tom have that correct. I had images to check against as well as instructions.
As soon as I shortened the chain, everything worked, but I cannot get my head around how this impacted on the SI. Nothing else was changed.
Can anyone provide an explanation.
Quoted: 4412 Post(s)
Liked 1,567 Times
What's an SI?
What??? Only 2 wheels?
Quoted: 1222 Post(s)
Liked 645 Times
By "10 speeds" do you mean 2x5 gearing, a.k.a. 10-speed bicycle, or that newfangled system where they name them based on the number of sprockets on the rear? Either way, I would think the danger of breaking the RD when you shift to larger sprockets or chainring would be the same as on any other gear combination.
Real cyclists use toe clips.
jimmuller
jimmuller
Quoted: 1609 Post(s)
Liked 2,216 Times
Cannot reason why chain length would impact shifting unless the limits of the RD are reached. Even then, it doesn't make sense to me. I challenge the "Nothing else was changed." Maybe not knowingly.
Liked 1,567 Times
If you make the chain longer, you're going to have less A tension opposing B tension, so you may need to let some B tension off by backing off the B screw. But that's just on some derailleurs, not SRAM, for instance.
Chain length can affect shifting and the big/BIG +2 method is not always optimal. Sometimes the shimano small/BIG vertical jockey wheels method works better.
Sorry to state the obvious but did you check your limit screws? I usually set these up first, as in the old friction shift days. Pull on the cable manually to shift. Will it reach those cogs then?
I don't know what SI is either. Do you mean STI? Indexing?
Liked 1,567 Times
AFA the why, I don't know and don't frankly care. There are a lot of aspects of bike mechanics where experience trumps theory. This is one.
Liked 1,567 Times
Chain length, even a link or two, will affect the wrap and the position of the jockey cage. It's kind of hard to describe, but a chain will often shift better with a link added or removed. There's always an optimum, despite the fact that often times a range of chain lengths will actually work. It's mostly in the smaller cogs in back that the differences are obvious.
You've got some adjustment with the B screw of course, but it isn't everything. Chain length matters more IME. I suppose we'll have to agree to disagree.
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
The SI is the most important parameter with modern drivetrains. It boggles my mind that people who would step into this discussion do not know what it means.
Liked 1,567 Times
ambulatory senior
Quoted: 1955 Post(s)
Liked 3,662 Times
If you know what SI means, why not tell us? Not a common or C&V acronym.
I've adjusted many thousands of derailleurs and drivetrains without knowing, so apparently it's not as important as you think.
My knowledge of BSA is clearly lacking. I'll need to take a TO from this BDT. CUL.
don't try this at home.
Quoted: 974 Post(s)
Liked 512 Times
However, when I came to set up the SI, I could not get it to work. The derailleur did not seem to be indexing and would not reach the two largest cogs. I adjusted the angle in case the derailleur was hitting the cogs, I double checked parts numbers in case I had a non 10 speed, changed the outer cables, as I had been a bit tight - no change.
That's interesting that the shifting was so bad and improved so much. I've never had that happen to me, and my previous bike came with a too-long chain.
(From the context: "SI" shift indexing? I've never heard that term...)
Liked 1,296 Times
I commented on the SI term as a hoax to elicit some explanation from the OP, but thinking about it I may have been right.
I seem to recall from a seminar at Interbike many years ago an in-house quantitative term used to describe the performance of shifting performance/robustness that related to how much of an adjustment range would still give acceptable performance.
That term just may have been the "selectivity index".
But it seems that the OP is going to let us toss this one around for a while.
It seems the OP is referring to indexing, but we don't really know.
There have been a few silly in-house terms introduced at Interbike over the years. I still think Q factor is kind of dumb. Chosen cuz it sounds serious I guess. Q factor means something very specific in engineering/science, and it is not pedal to pedal width.
Old fart
Quoted: 3591 Post(s)
Liked 3,401 Times
Bikes: yes
Quoted: 1281 Post(s)
Liked 643 Times
It's a metaphor. How do the chains (of capitalism) affect the Solomon Islands (SI)? OP is trying to start a discussion regarding how the economic imperialism of western nations contributed to the widespread economic, political and social instability experienced by many former colonial possession upon gaining Independence, which is illustrated by the ethnic violence between the Guales and Malaitans in the late 1990s, and how modern day expansion of Chinese business interests continues to contribute to the instability in the region.
When OP refers to splitting the chain, and then shortening it, he is referring to the frequent need for deployment of Australian and New Zealand troops to the region to quell simmering ethnic tensions. Yes, it solves the immediate problem, but fails to address the underlying conditions leading to the problems in the first place.
Quoted: 1858 Post(s)
Liked 664 Times
My state of bogglement remains unabated. But now I have an enlightened insight - it is just one of many forms of BS.
Liked 645 Times
I'm starting wonder about the Tr0LL factor w.r.t. SI. And it isn't even April.
In the old days before chain pins were supposedly peened we just pushed the pins back into place with ye ol' chain tool, and they worked just fine. I figure that if a pin has as much or more friction in the side plate now as it did then then it ought to work. My experience with new 8-spd chains like the SRAM PC870 and KMC (Is that what it is? I fergit 'xactly...) is that they do take a lot more force to push the pin out and a fair amount to push it back in too. So it should work as well or better than in the old days. So I've treated them the way I always did (which cussing at the extra effort it takes). The only time I've had a chain break was when a quick-link came apart.
jimmuller
jimmuller
Liked 1,567 Times
Quoted: 1163 Post(s)
Liked 442 Times
In my business “SI” is an acronym for “suicidal ideation” - we use it all the time. I wonder if the OP was talking about “STI” or “Shimano Total Integration”. Shimano STI is so dominant in the market that the acronym STI is something I understand, “SI” not so much.
