Wellgo quick release pedal holder?
I've a Wellgo quick release pedals. I'm looking for pedal holder specific for Wellgo. The pedal holder that's selling on Aliexpress/ebay are for the MKS style. Apparently the Wellgo has different style.
https://www.aliexpress.com/item/4000...rch-mainSearch
Quoted: 381 Post(s)
Liked 145 Times
Google search these two parts.
https://en.wellgopedal.com/products_detail_11_497.htm
https://en.wellgopedal.com/products_detail_11_498.htm
I'm looking for a holder like this to hold the Wellgo pedal when the pedals are unattached from the crank.
Apparently Wellgo doesn't make them, if you know where can find such holder please share. Thanks you very much.
Did you check Aliexpress? Lots of models, here is one sample: https://a.aliexpress.com/_v6l0TZ
Not sure if people here understand exactly what I'm looking for. I'm looking for pedal holder SPECIFIC for Wellgo QR pedals. It doesn't exist anywhere AFAIK. Nothing on Ali/Ebay/Amazon etc....
This one says it's suitable for Wellgo.
https://shopee.com.my/Qr-Pedal-Holde...533.9814632283
Alternatively you can try magnetic holders like this:
https://m.novdesignstore.com/product...dals-black/48/
It says for MKS but technically should accommodate any quick release pedal of same stem diameter.
Likes For CEBEP:
QRD shaft length
I see there is another seller offering the same item for 37.9 RM on Shopee. Here's the link: Pedal QR Holder. Place pedal bracket quick release rellease Li Kinds Of wellgo And Sejenis | Shopee Malaysia
There's a review from Simon Chung 86 in this listing which says the item is only suitable for the short shaft version of the pedal with push button release. I assume he's referring to Wellgo QRDII quick release pedals and that the pull release (long shaft) version he mentions is the older QRD version. From an email exchange I had with Bob Forgrave at Flatbike.com about the difference between QRD and QRDII latches in November 2020, I thought that QRD and QRDII pedal shafts were identical:
"Hi, Andrew. You're completely right about three things: QRDII is an improvement, it's backward compatible with QRD, and there's a worldwide supply issue."
Can anyone clarify if there are two different lengths of pedal shaft out there? Maybe some Wellgo copies with short shafts??
My QRD-C241's have shaft length to the underside of the first flange of about 15.2mm.
Shaft length of my QRD C241's
