BIM 39 Ideale 39 leather saddle dry small surface cracks any fixes? pics
Bikes: Vintage Raleigh Super Grand Prix (Made in England)
This saddle came on A bike I recently purchased the leather is very hard and stiff and after reading online about leather saddles I looked closer and saw that it has some surface damage. Is there a way to prevent more damage? Should I apply leather conditioner and if so what kind. I don't want to ruin the seat by making it too soft I just want to moisturize it to prevent further damage. The photos were too large to upload here so I put them on Photobucket here is a link. https://s832.photobucket.com/albums/z...ther%20saddle/
Thanks
Thanks
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
That doesn't look too bad. I'd rub a little bit of Brooks Proofide into the surface and let it sit in the sun for a while. The fibers seem to soak the stuff up a little better when they're warm. After that, you should be good to go. To keep it from getting worse, don't let it get wet; don't leave it out in the dew or, worse, rain.
Hopelessly addicted...
Bikes: 1949 Hercules Kestrel, 1950 Norman Rapide, 1970 Schwinn Collegiate, 1972 Peugeot UE-8, 1976 Raleigh Sports, 1977 Raleigh Sports, 1977 Jack Taylor Tandem, 1984 Davidson Tandem, 2010 Bilenky "BQ" 650B Constructeur Tandem, 2011 Linus Mixte
Liked 10 Times
^ +1 The BIM 39 I have is considerably dryer than that one. Still I think it can be saved.
On a side note, have you ridden an Ideale saddle before and how did you like it compared to a Brooks, assuming you've ridden either brand?
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 70 Post(s)
Liked 15 Times
I have one worse shape than that, it is on one of my semi daily riders. Proofide it and ride it.
In answer to Ideale vs Brooks. I prefer Brooks. The Ideale seem to be made from a thicker leather and never seem to reach the same comfort level as the Brooks do for me.
Aaron
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"_krazygluon
Stop reading my posts!
Quoted: 1444 Post(s)
Liked 1,065 Times
I'm sure there are fine points to consider, and technique and timing involved...after all, we've all been taught that rain is the worst thing for leather, hence the application of waxy treatments like Proofide.
But, if I understand the theory: when there's nearly zero moisture left in the fibers, applying a waxy grease to seal it in (prevent further evaporation) won't be effective unless you have some moisture to seal in it.
I think the crucial thing is to allow for careful drying of the soaked saddle (NO heat, plenty of air circulation, no mold allowed) before you apply (a small amount of) Proofide, or the dubbin of your choice.
Do more research before you proceed with the bucket solution, I haven't done it myself...and we'd hate to see a good Ideale ruined!
This is my first leather saddle. I haven't ridden on a brooks before. So i'll get some Brooks proofide to put on it. If I apply a little bit it will keep it from getting more small tears?
multimodal commuter
Liked 574 Times
This may be a dangerous reply, but according to at least one expert (Tony C.) on the restoration of all-leather bicycle saddles, the best thing for a dried out example like this is a soak in a bucket of water .
Instead of soaking in water for a few hours the trick i do when a saddle is deformed is to dunk it in near boiling water.
Within five minutes it is very pliable and once pushed into shape it tends to stay like that and doesn't need tying up which can cause indents!
I then rub olive oil into the saddle , I read that a lot of horse riders use olive oil instead of proofhide.
Old fart
Quoted: 3594 Post(s)
Liked 3,404 Times
That looks like superficial damage. Apply some Proofide or SnoSeal and enjoy. I have a 1967 Brooks Pro that looks far worse than that and is still going strong:
multimodal commuter
Liked 574 Times
Oh, I really wouldn't do that. This will inevitably cook the leather, making it harder (which may be good) and brittle (not so much). I realize there are certain circumstances where such extreme measures may seem called for, such as when a saddle has lost its shape and become much too soft. If you have a totally useless saddle and a crazy gamble like near-boiling water will either make it better or worse, then what the heck. But Hayden's saddle appears to be in pretty good shape. There's no reason for extreme measures at this point.
Bikes: Many
Quoted: 5 Post(s)
Liked 10 Times
This is a great topic. My first "project" saddle was a very old B-17 champion narrow (first made around 1910). It was extremely weathered and beat, completely dry.. I figured it would never be usable but we will see. I first soaked it in warm water for several hours (changing water often) until it was completely compliant. I packed it with newspaper and wrapped it with worn out toe straps. I let it sit for a day and changed the paper (it's damp here in the NE) and let it dry two more days.
When it was dry the shape was correct but it looked "parched". I got impatient or something and used a reduced wax (butchers bowling alley wax) and it made it pretty weird and dry but allowed me to polish the finish a bit and bring back some of the effect of the original tan.
I then applied olive oil with a little bit of petroleum based "way" oil (motor oil for industrial machines). I had it pretty good but went a bit too far on the oiling, it's oily to the touch. I am sort of in limbo on what my next step should be. It's been stuffed with newspaper for about a year at this point.
I am thinking of another warm water bath with saddle soap this time, a good drying cycle and following with some type of greasy wax. I have a tallow/carnuba/Bee's wax mix at the shop ( we call it "Jean Claude sauce" after the old Frenchman who brews the stuff) that may work. Wax seems to draw out oil.
I am wondering if I should wash the oil out and treat it with tung oil or linseed oil. It will give it that final "museum" look and forget about it ever being a rider.
I think that is an urban myth about olive oil going rancid in leather.
Many many people use it and have used it for years.
Liked 1,065 Times
One thing to keep in mind with all things relating to care/feeding equestrian saddles and how that may/not apply to leather (suspended membrane, weight-bearing) bicycle saddles: they aren't constructed the same nor do they functionally perform the same. A horse saddle has a relatively solid (wooden) form over which leather is stretched and sewn or laced.
The leather of a cycle saddle is suspended in air, held under tension with some rivets to an open metal frame.
Back to the 'bucket dump": IIRC Tony C. was not discussing this as a method of re-shaping a misshapen saddle, but to re-hydrate a very dried out one...I'd certainly use water if I had a saddle needing re-moulding, and I'll repeat my caution to do research before trying this "extreme" measure on a saddle you value.
The lower edges had curled up and was unrideable in that state.
This was the way that worked so that i could reshape it.
But i shall bare in mind what you have said about making the leather go hard!
I just read online that soaking leather in hot water for a long time can make it as hard as wood.
Cheers
Quoted: 443 Post(s)
Liked 28 Times
BIM saddles were supposedly made by Ideale, but they were of lower quality. Mine has thin leather and the frame is rather cheap looking. The thin leather makes it comfortable, though.
multimodal commuter
Liked 574 Times
I'm curious whether there's any difference between the BIM 39 and the Ideale 39; clearly they have not just the same model number but the same frame, same rivets, same "croupon garanti" stamp. The same frame and rivets, incidentally, were used on a other saddles bearing names like Welcome, Norex, and no doubt others as well. In comparison to a Brooks saddle, these ones are remarkably small.
I found 2 old B17 saddles that were as dry as beef jerky.
The 1st one I soaked in vegetable oil then punched holes at the bottom and restrung, it worked but took forever for all the vegetable oil to leech out and ruined a few shorts along the way.
The 2nd one I soaked in water overnight, punched holes at the bottom and restrung, after it dried I applied sno-seal and let it dry, they both worked but the 2nd saddle seems to be a lot newer.
I still ride both saddles and they are just like new, Love the hard leather saddles.
XU
XU
Many many people use it and have used it for years.[/QUOTE]
Not a myth - I had a woodworking project about 10 years ago and was making cutting boards. The only types of oil you are allowed to use on them without the wood going rancid were mineral oil or walnut oil.
I just finished rehabbing an old Sprint seat (ideale made I think) and it was bone dry. I soaked it for 2 hours, wrapped it in a towel for another 2 hours, and tied it up with straps before the two day dry. Then I coated it with baseball glove oil. After a week, I put a small amount of proofide on both sides, and put it in the sun. and was amazed that old dry saddle had come back to life.
For future projects with everything else bicycle related, refer to Sheldon Brown’s website for info on saddle renewal- he always knows! There are many different ideas, and several tips about potions to use.
Likes For blairfredrick:
