Deciding between 2 cheap Torque Wrenches: Beam type or Clicker?
Hi all,
I want to get a cheap Torque wrench to be able to tighten the bolts on my carbon bike to the proper torque. I don't want to spend close to $100 for a tool that I'm going to use a couple times a year.
I was reading reviews, and heard surprisingly good things about this little tool: Icetoolz Ocarina. I believe it is a "beam style" torque wrench in a slightly different format. It looks kind of silly and cheap, but apparantly it is very accurate, and super cheap.
https://www.amazon.com/gp/product/B0...=AUO9W8MUC55QD
The others I was looking at are by Venzo:
https://www.amazon.com/Venzo-Premium...+torque+wrench
Those are the cheap "click" style wrenches. They seem more durable and well made, but I have heard horror stories of cheap click style wrenches being miscalibrated, and destroying carbon parts. Exactly the OPPOSITE of what I'm trying to achieve.
At least with the beam type, you still have the "feel" of a normal allen key, and you see the dial move while tightening. With the click style, you have to keep tightening, and there is no indication of where you are until it 'clicks'.
Which one do you guys think I should get? I'm leaning towards the Icetoolz Ocarina, because I am really scared of the cheap click type not being properly calibrated. I've never heard horror stories about the beam type?
EDIT:Another one I stumbled upon is this adjustable one from CDI: https://www.jensonusa.com/CDI-Torqcon...-Torque-Wrench
People seem to like it, and it is pretty affordable. I know Park Tool makes a similar one, the ATD-1, but that only goes from 4-6Nm, and for some of my bolts I need 8Nm, this one does 2-8Nm.
Any other recommendations in the $40-$50 range are also appreciated.
Thanks!
Thanks!
Quoted: 569 Post(s)
Liked 588 Times
Any cheap torque wrench should be calibrated. I only have experience with a neighbors Harbour Freight but it was so bad he took it back and was advised by the manager to come back when they get a new batch in. The new one was a tiny bit low reading and we checked it again a month or so ago, so maybe a year later, and it is still where it was. He says he always returns it to zero which is necessary.
Quoted: 2604 Post(s)
Liked 1,933 Times
I'm a beam type fan just because it's simple. It'll come with an accuracy of +/-X% (where X is the unknown), but it'll stay pretty close to that for a long time. Click type torque wrenches have more fiddly hidden little parts to go wrong.
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
I actually snipe ebay for good tools, cheap. I'd get something pretty foolproof, like a beam type, from a good brand like Sturtevant -Richmont or Proto. Snap-On is overpriced, even on ebay. Hard to knock the beam types out of calibration. But if you want one quickly and don't want to have to figure out which ebay offering has what you want, Harbor freight has a 1/8 drive click wrench for 20 bucks. Make sure that the one you buy has the range of torques your bike needs.
Not to hijack the thread but does anybody have any experience with the performance brand wrench?
Spin Doctor Torque Wrench Set
Quoted: 344 Post(s)
Liked 20 Times
Cheers
Bikes: Who cares?
Quoted: 15 Post(s)
Go with the click type, the beams you have to look at to see the torque value. The click, well they click when you reach the set torque. I often torque two or three times just to make sure, and makes it easily repeatable.
Quoted: 2026 Post(s)
Liked 1,096 Times
That's only a problem when you can't easily see the wrench. There is nothing on a bicycle that keeps the wrench out of sight. Beam types are cheaper for a given quality, more rugged and won't go out of calibration without it being obvious.
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,182 Times
In my younger days when I was building a lot of motors, all I could afford was a beam TW, it always seemed a little hit or miss.
I moved on to the click type and have been happy.... with smaller loads I think the click is more accurate. Beams can either not load enough or go past the mark.
I like hearing the click.
JM2C'S
JM2C'S
Voltaire
Voltaire
Beam types are a little less user friendly. You need to look at the readout plus what you're doing simultaneously. Dial/click types are a little easier to use but must be zeroed out between uses.
All torque wrenches are their best in the middle of their range and less accurate at the extremes. Get the torque wrench where the middle of the range falls where you're most likely to use it.
I wound up getting a Topeak d-torq. Different than a dial or beam in that it uses an electronic transducer. You set the desired torque on the digital gauge. The wrench beeps when you reach set torque and beeps again if you exceed. Very user friendly and doesn't need to be zeroed out between uses. Of course it costs more than the dial or beam type, but it gets a fair amount of use on my workbench.
Quoted: 1609 Post(s)
Liked 2,216 Times
It is not only important to get the right range but measure towards the middle of the range, if you have a choice. Often the extremes of the range provide a false indication as the measurement is not always linear. If the manufacturer compensated with the scale, then it would be more acceptable.
Not the case for bicycle, but I would not be able to read a beam TW with a torque reading above 150 ft-lb. I would be shaking so much that I would not have an idea where on the scale the torque actually is! 250 works well for a click TW
Quoted: 630 Post(s)
Liked 369 Times
I have this one:
https://www.amazon.com/2-10NM-Bicycl...+torque+wrench
It is super tiny but it does the job. I would recommend a clicker for higher torque applications. Getting up to 10 nm is quite a challenge on the little guy though. The icetools one looks cool but might not work in certain rare situations. There was barely enough space to tighten the clamping bolts that clamp brifters to the handlebars (~7 nm) with the hoods on.
Bikes: Bianchi San Mateo and a few others
Quoted: 634 Post(s)
Liked 13 Times
Beam wrenches are cheap and reliable, and they don't ever need to be recalibrated, but you need to be able to read their scale head-on. On a bike, that's usually not a problem. But if you ever find yourself needing to use a torque wrench on a fastener where you don't have head-on visibility to the wrench, you'll appreciate having a clicker. The down side to a clicker is that you should get it recalibrated periodically.
It's not a torque wrench, but rather a torque limiting device that will ratchet once at the torque setting. It will not allow you to torque above whatever you set it at. The bad is that it only works in one direction. Neutral is it is a disposable device and I think considered worn out after so many thousand clicks - the mechanism will click at lower and lower torque as it wears out. For a home user, probably you'll get a decade of use out of it.
Bikes: Bianchi Ti Megatube; Colnago Competition; Planet-X EC-130E; Klein Pulse; Amp Research B4; Litespeed Catalyst; Trek Y11
Quoted: 605 Post(s)
Liked 480 Times
I have a click type (Draper), but I'd buy a beam type to use with the bike simply because you can't torque a left-hand thread Ultra-Torque bottom bracket cup with a click type torque wrench - gotta use a beam type torque wrench for left-hand thread.
Performance is reselling a Chinese product that is available on Amazon for $30 less. I think I got mine at 30% off and still paid a $10 premium to support my brick and motor Performance store. But their mechanic had just given me a portion of carbon assembly paste (they were out of stock on their tube of the stuff), so I felt OK paying the premium.
I've also got a much larger Harbor Freight torque wrench that I used today to bolt on a crank, and I can definitely say the click type was an advantage while trying to get up to 25-30 ft-lbs, iirc, while that crank wanted to spin and I was bending over the frame and bike stand. I would not have been able to see the beam. The square taper crank is kind of an odd joint to get up to proper torque anyway because it takes some force to move the crank arms up the taper. I thought surely I was over-tightening but I was just forcing the arm up the taper.
Oh yeah, I also slack off the torque setting when I put it away.
Really Old Senior Member
EDIT:Another one I stumbled upon is this adjustable one from CDI: CDI Torqcontrol Adjustable Torque Wrench > Accessories > Tools > Torque Wrenches | Jenson USA
Thanks!
Thanks!
You basically want to keep your torque readings in the middle 2/3 of the scale.
Avoid the extremes. Accuracy starts to deteriorate. Sometimes rapidly.
Bikes: 2016 Novara - Safari
Quoted: 384 Post(s)
Unless you plan on getting a certified clicker, and keeping its re-calibration schedule, you'd likely be better off with the beam-type.
Sapient
Great article on the subject. FWIW- we use the CDI adjustable, the Lifeline Pro, and the Topeak D-Torq at the shop.
Best torque wrench for bicycle grouptest - BikeRadar USA
Quoted: 3352 Post(s)
Liked 1,056 Times
I don't plan on getting it professionally recalibrated, and I am very worried about breaking my carbon stuff if it goes out of alignment, so the Ocarina seems to be the better option. The Bikeradar review had the Ocarina very accurate out of the box, so that should be good.
The main drawback seems to be reading the dial, but I cant think of any application on my bike where I would have trouble reading it.
Thanks!
Quoted: 83 Post(s)
Nothing wrong with your choice, but you really don't need to worry so much. The margin on torque "specs" for the stuff you're doing is pretty big. In the case of things like stem bolts, the spec is for the lowest value (with margin) that will keep the stem or bars from slipping, not the highest value that you can use without crushing the tube. Using a torque wrench is a good thing, but even if it's calibration is off by 20% the worst problem you'll have is not getting things quite tight enough.
So until now I have been extremely cautious and just tightening them enough for the seatpost not to slip. But I knew I eventually should get a torque wrench.
