Finally grabbed a Schwinn Le Tour 1980 12 Speed
If the tires are old and dried out, I would replace them with new.
The trailer will add weight which will work against the brakes. How old are those brake pads? If you are going to pull this trailer in wet or rainy weather Kool Stop brake pads will greatly improve stopping.
If you are in a hilly area, you may find the gearing a bit high for uphill work. The trailer will make that worse, if it is heavy.
Yeah definitely replacing tires and brakes. Brakes are just as old as the tires
I’d definitely follow the tire/tube (& perhaps brake pad) recommendations already suggested!
RE: the trailer question, in my opinion (it’s worth what you pay for it), pulling a trailer with that bike might not be the best option. I’d suggest your wife’s bike ! As mentioned, the gearing isn’t low enough. Just about any hill would be a challenge. It wasn’t (despite its name) truly designed to be a loaded touring bike (again, my opinion). To be sure, it will be a great bike for cruising around on Connecticut back roads if there aren’t too many hills. If pulling a trailer is a necessity, I’d consider getting a bike better suited to the task.
Likes For sovende:
ambulatory senior
Quoted: 1955 Post(s)
Liked 3,661 Times
I had an 89 letour. Excellent framesets. True temper is nice steel.
Likes For 52telecaster:
