Polygon Heist X2 vs Norco Storm 4
Hi there,
I've been looking into mountain bikes, and after comparing 6 different models, I narrowed down two that I like:
Here's the thing -- the Polygon is going for $500, while the Norco is $800. I don't know much about either brand, so my question is -- do you feel the Norco is worth the $300 price premium?
Thanks for the feedback.
- Polygon Heist X2
- Norco Storm 4
Clark W. Griswold
Quoted: 4424 Post(s)
Liked 4,069 Times
The Polygon has slightly better low end drivetrain components but is a hybrid the Norco has potentially better low end brakes and a probably equally low end but higher travel fork neither I would want for mountain biking but they both look like a bit like mountain bikes with the Norco being slightly closer since it has a 100mm fork vs a 700 low travel fork.
Norco seems to be lacking in the entry level hardtail but Polygon does it with the Xtrada7 https://www.polygonbikes.com/xtrada-7/ it has Deore 12 speed and an air fork. It is decent modern parts and a bike worth upgrading down the trail if you wanted to but a good solid entry level bike and keep it as is you could. When I say entry level I do mean it, I don't find the really low end components and cheap coil shocks to be helpful for a beginner they are initially cheap but tend to need more service and replacement more often and aren't going to be as responsive and comfortable to ride so fine for someone not riding much at all and not hitting actual trails.
An entry level bike should have decent enough components to work well and be reliable but also ride semi decently and potentially have some room for upgrade or at least not be sub-par out of the gate. You want to inspire confidence and hold up decently well. Deore is a solid workhorse nothing fancy but it doesn't need to be, The fork is a basic air fork but it is an air fork and going to allow you to set it up for your riding or weight unlike a coil shock that you would get on the other bikes and similar lower end bikes. There are some high end coil shocks but you will rarely if ever see one spec'd on a good bike and you will know it aside from that they aren't so good.
Likes For veganbikes:
Hey, thanks for the feedback and the Xtrada suggestion. My apologies, but I should have stated in my initial post that I don't plan on riding any hardcore trails; mainly limestone and light gravel trails, while also being able to ride the bike around town if I wanted to (although I have a separate road bike).
Clark W. Griswold
Liked 4,069 Times
