Electrolysis on aluminimium/ alloy parts?
Old 09-03-20, 10:55 AM
tonyfourdogs
tonyfourdogs's Avatar
Bikes: Marin Palisades Trail (1991)
Quoted: 86 Post(s)
Liked 3 Times in 3 Posts
Ello again
I have done a quick search on this topic, so forgive me if I'm duplicating another thread here, but I couldn't find the info I was looking for. I've decided that electrolysis is the way forward for me when it comes to rust removal. Cheap, cheerful and no horrible chemicals my dogs could accidentally encounter and poison themselves with. For steel parts, it seems very straightforward. But what I can't find the answer to is this: components that are a mix of steel and alloy, e.g. derailleurs. Will electrolysis damage alloys or anodised parts? Is it safe to electrocute my derailleurs?
Thanks
tonyfourdogs is offline
Old 09-03-20, 03:32 PM
old's'cool
curmudgineer
old's'cool's Avatar
Bikes: 2 many 2 fit here
Quoted: 263 Post(s)
Liked 112 Times in 70 Posts
Well, when you put an electrolyte in contact with two dissimilar metals, one will eat the other. Adding an external EMF source will probably accelerate the process.
old's'cool is offline
Likes For old's'cool:
Old 09-03-20, 03:34 PM
old's'cool
curmudgineer
old's'cool's Avatar
Quoted: 263 Post(s)
...Depending on which way the current is flowing (between the two metals), you might also weld them together.
Old 09-03-20, 04:07 PM
ZudeJammer
ZudeJammer's Avatar
Bikes: Fuji Touring Series V 1985, Motobecane Grand Touring 1982, Specialized Stumpjumper 1993, Raleigh International 1972, Raleigh Grand Prix 1972, Kuwahara Count 1983, Trek Cirrus 1987, Shogun 2001 1983, Cannondale SM700 1990
Quoted: 90 Post(s)
Liked 174 Times in 96 Posts
are you going to rainbow anodize it so it comes out like the oil slick color?
ZudeJammer is offline
Old 09-03-20, 05:13 PM
79pmooney
79pmooney's Avatar
Quoted: 4806 Post(s)
Liked 3,929 Times in 2,554 Posts
This has been hashed and re-hashed in the marine field forever. There is a galvanic table. All metals are on it. Electric flow caused by the dissimilar galvanic property and the presence of an electrolyte means ions travel from the "lesser" metal to the more noble metal. See the table on https://en.wikipedia.org/wiki/Galvanic_corrosion. (Actually, search further for more complete tables. You will see steels and stainless steel over a wide range, What alloy you are talking about matters.
OP, it sounds like you are willing to do an experiment as to what items on your bike will go away when you apply electricity and electrolyte. Those of us who have sailed salt water find that heeding the wisdom of those before is often far less costly. Just for fun, the classic and revered Campy NR rear derailleur had aluminum, at least one steel and brass or bronze in it. Apply galvanic corrosion and one (or more) of those is going away.
I suggest you do this on a bike you care nothing for and report back.
Ben
79pmooney is online now
Old 09-04-20, 12:19 AM
tonyfourdogs
Quoted: 86 Post(s)
haha thanks for your replies folks. I had no idea it would be such a disastrous experiment! Since I now 'know' the outcome, I think I'll save even my most sickly derailleurs the indignity of this cruel curiosity.
It's a good job I asked first, eh?
Old 09-04-20, 11:19 AM
steelbikeguy
steelbikeguy's Avatar
Quoted: 1829 Post(s)
Liked 3,376 Times in 1,580 Posts
I'm not familiar with this proposed method of rust removal, but it does sound a bit like electroplating as a way to add metal to something.....
https://en.wikipedia.org/wiki/Electroplating
.... but it does involve nasty chemicals and other dangerous stuff. Prior to electroplating, you'd have to remove the rust to get down to a conductive surface.
Can't blame you for hoping for a bit of a miracle, though.
Steve in Peoria
steelbikeguy is offline
Old 09-04-20, 12:34 PM
jonwvara
jonwvara's Avatar
Quoted: 765 Post(s)
Liked 660 Times in 351 Posts
Soak them in Evaporust. That's one of the many great things about it--you can soak pieces, like derailleurs, that contain both steel and aluminum. Unlike oxalic acid or an electrolysis bath, it only reacts with rust.
www.redclovercomponents.com
--Ogden Nash
jonwvara is offline
