Why tubeless over tubulars?
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
Now that I have finally joined the ranks of tubeless riders, I started to think back to my racing days when I would race on tubulars and train on clinchers. Tubulars seemed to roll more smoothly and corner more confidently (or maybe it was just a placebo). So is there any downside to just putting the tire sealant into tubular tires as compared to tubeless? If not, I know what kind of wheels I'm getting next!
It's like riding a bicycle
Bikes: Pinarello Gavia TSX; Bianchi Intenso
Quoted: 167 Post(s)
Liked 92 Times
This summer I went back to using my old sewup wheels from racing days and bought some 25c Continental Gatorskin Sprinters. I had always raced on the regular 22mm Sprinters, and I found this wider version to feel great even though they were Gatorskins. I used these wheels on a vintage Pinarello Gavia TSX with Campy Ergo 8sp.
I decided to try Conti’s Revo Sealant (4ml) in the rear tire. I have no indication that the sealant came into play, as there are no outward signs of a repaired puncture. I did suck out the remaining sealant for the winter and I am not sure I would go back to the Revo as it seemed to fail inside tubed clinchers that I also tried it with. May try Cafe Latex or OrangeSeal next summer.
Likes For gkamieneski:
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,981 Times
The choice of tubulars vs tubeless should be made on other factors than sealant use.
I suspect tubulars don't respond as well to sealant as tubeless do, but certainly better than tubulars without sealant.
If you're going tubular because you want to, adding sealant isn't much of a down side at all.
Likes For DiabloScott:
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
I thought Cafeelatex in tubulars was a given.
Genesis 49:16-17
Genesis 49:16-17
Likes For Darth Lefty:
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
So it sounds like you're saying the sealant wouldn't heal holes as quickly or readily?
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
I raced in the 90's and don't recall anyone using or talking about any sealant back then. In the later half of the decade, Slime made a sealant that was used by a few commuters and recreational riders in their inner tubes, but it was regarded as too heavy for racing and training applications. I also think I heard of some people carrying something like Fix-a-Flat, but just to finish the ride and not as a long term solution. Now that people are riding tubeless and claiming to almost never get a flat with the caveat that the rare flat will almost guarantee you get stranded, it sounds like doing the same with tubulars would be a viable and similar option.
Quoted: 2432 Post(s)
Liked 638 Times
I ride tubulars and always carry a small 2oz bottle of Stan's in my jersey pocket. My last puncture was about 15,000 miles ago, I hardly ever get a flat with tubulars. It took me a couple of minutes to squirt half the bottle into the tire. It sealed so well I could go a week without having to top off the air pressure. Of course you can just put it in a new tire and always ride with sealant in it but I don't puncture often enough to want to do that.
I don't get punctures with tubed or tubeless, where I ride. No punctures in over 16,000 miles. Pinch flats from hitting rocks is a possibility that I cured with 28mm tubeless. If your frame can clear 28mm tires, that's the ticket to a better ride with low rolling resistance. My rims have an internal width of 19mm, but 21-25mm will allow even lower pressures. Read about Zipp's latest hookless rims and tire pressure recommendations at zipp.com.
Likes For DaveSSS:
Quoted: 4806 Post(s)
Liked 3,929 Times
I have no insight regarding sealants in tubulars. Never used it while riding them. I am hanging out here to absorb the current thinking because I am going back. Eight years ago I had the crash that decided it. Had a clincher blow and come off. Never want to do that again and that was just a rear at ~22mph. I cannot get that out of my mind going downhill. By contrast, I've blown tubulars as 40+ and they were so uneventful I cannot remember whether it was front or rear.
Being a belt and suspenders guy (and not having a spouse, willing or otherwise), I will carry at least one spare and a patch kit. I see no reason not to go back the the Tubasti I used for everything but my race wheels. (I trained, commuted and club raced on the stuff. Never cleaned the rims other than taking off high areas. Spares were stuck on well enough to club race when I got home.)
Likes For 79pmooney:
Quoted: 6963 Post(s)
Liked 10,964 Times
Quoted: 850 Post(s)
Liked 344 Times
Since then, I've upgraded to carbon rims with TL tires. They have REALLY strong bead shelves. The tires simply *do not* come off, intentionally or otherwise. I would be very comfortable riding these flat, besides the rim damage issue. I actually sliced my front tire coming down the snake (LA). I let the tire barely seal, pumped it up, then sent it. No worries.
Likes For smashndash:
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
I didn’t say puncture. I said flat (like if the hole won’t seal), and even that is just what I’ve been told from people who had a hell of a time stuffing a tube inside. I’ve heard about some kind of plugs, but can’t rely on those until I get some.
Quoted: 1814 Post(s)
Liked 923 Times
Over time, some sealants can make a clog at the base of the valve, degrade latex tubes, and make deflated tube stick to itself, causing it to burst when reinflated.
Liked 10,964 Times
Likes For Koyote:
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
It wasn’t a statement of my own. It’s what I heard others (who ride tubeless) say, and the whole reason I posted it here is to hear differing opinions. Feel free to let me know how easy or difficult it is for YOU to fix a tubeless flat. It would very likely calm my concerns.
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
Are you speaking of latex tubes inside sew-ups? I can’t imagine it sticking to itself, but degrading would be a concern. Plus, does “over time” mean months, or years when the tread wears out anyway?
Liked 10,964 Times
It is precisely the same process as fixing a flat with a regular old clincher tire, except that a little sealant might dribble onto your hands in the process. Anything that would destroy a tubeless tire (and leave you stranded) would destroy any other type of tire - a standard clincher or tubeless tire included.
Likes For Koyote:
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
I still wonder if the sealant would do the same thing for tubulars though as I would highly prefer to ride on those.
After I had my tubeless tires in use for several months, I let the air out and removed one bead to be sure that I could do it out on the road. I carry a spare tube and some nitrile gloves to keep the sealant off my hands. I've never had a flat in 35 years that a new tube wouldn't fix, but there's a first time for everything. I've hit 56 mph several times and regularly hit 50 mph. I don't worry about my tires coming off.
Quoted: 2495 Post(s)
Liked 738 Times
To be brutally honest, the o.p. is asking the wrong question. It isn't really "why tubeless over tubular?", it really should be "why use either one anymore?!". I simply cannot see the need, in 2021, for tubular OR tubeless tires when standard clincher tires can sustain 120+psi for the racing contingent and are also available in 'plus sizes' for the gravel addicts. I would much rather use a Kevlar or Urethane tire liner than Slime. The tire liner will be much lighter than the liquid sealant and it makes much less mess and does not gum up valve mechanisms. It was a mistake, I think, to try and adopt the automotive tire infrastructure of tubeless tire technology for bicycles! It simply does not scale down well enough. Tubulars are simply obsolete and while they fulfilled a real need back in the day, that time has passed.
Likes For Leisesturm:
Habitual User
Quoted: 4946 Post(s)
Liked 8,087 Times
I'm less excited about tubeless that I used to be, but continue to run it.
Likes For Eric F:
Quoted: 1819 Post(s)
Liked 1,694 Times
There are tubulars made by Tufo that are actually tubeless. Using them with sealant would be just as effective as using sealant in a tubeless clincher
Likes For alcjphil:
Liked 923 Times
Yes, latex tubes in sew ups. The others are things I've seen in used tires & probably not an issue for actively ridden wheels,
but the sticking-to-itself can happen sooner, but maybe newer, better sealants are not prone to this.
An example:
Likes For woodcraft:
Quoted: 2338 Post(s)
Liked 2,822 Times
there is also vittoria pit stop, aersol can of sealer/inflator (have one but havenot tried)
pretty easy to carry a spare tubie and 2 if you are really paranoid
I like the jannd bag for carrying tubies and othe stuff
Likes For squirtdad:
