Upgrading from 105 5600 to Ultegra
Hi all. Apologies if this has been answered but thought I’d get some of your opinions.
I current have a 105 5600 10 speed on my Orca and was wondering if it is possible to swap out the crank for a Ultegra 6700 10 speed? Would the 10 speed Shimanos generally be all interchangeable for the cranks?
In terms of a bigger picture I am looking at one day giving the bike a new group set for something new… Would it be better getting the 6800 Ultegra 11 speed or the newer R7000 105?
Thanks!
Thanks!
Expired Member
Quoted: 3674 Post(s)
Liked 5,435 Times
Yes, you can directly swap a 6700 crank for a 5600. Not much point unless you need a new crank. As for the new group, 7000 would be a better choice than 6800, IMO. They made significant improvements with the second generation 11 speed. Also, 7000 is current, will be much easier to find a new group than 6800.
Quoted: 6970 Post(s)
Liked 10,967 Times
Swapping out a 105 crankset for an Ultegra crankset is pretty pointless.
Likes For Koyote:
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 270 Post(s)
Liked 447 Times
Unless the 105 crank is damaged or you want compact it’s not worth it. I changed to a 105 long cage for more cassette range recently. May be could have put a Wolf thing on the short cage Ultegra. Best thing is save and get a disk brake bike. Keep what you got for a spare bike.
Quoted: 6195 Post(s)
Liked 4,810 Times
As for putting an entire new 11 speed group on the bike, you just need to decide if weight savings of Ultegra over 105 is worth the additional cost to you. I run both groups and sometimes will mix them up. My main bike right now has a 105 drive side crank/spider with Ultegra 52/36 rings and a Ultegra left crank.
The story behind that is a little more than I'd like to type at the moment.
Liked 10,967 Times
Quoted: 3240 Post(s)
Liked 2,086 Times
Should Be More Popular
Quoted: 22599 Post(s)
Liked 8,926 Times
Likes For datlas:
Liked 4,810 Times
Likes For Iride01:
