Better sealant than Stans for road tubeless?
Bikes: 1988 Bottecchia Professional (for Eroica), 2011 Ridley Noah ISP (retired), 2020 Soma Fog Cutter (daily commuter), 2021 Ridley Kanzo Adventure (gravel), 2022 Tideace Aero (main road bike).
Quoted: 77 Post(s)
Liked 76 Times
Quick background - Light Bicycle rims with Pirelli P-Zero tires and regular Stans. After about 1,100 miles the tires started taking a bunch of micro cuts which sealed up just fine. Then I finally took a bigger cut of about 2-3mm which resulted in a geyser of sealant spewing all over. I managed to keep enough pressure on the cut with the hole pressed to the road and it eventually sealed and I was able to add air and finish the ride. The next day the same hole opened up again.
It seems like regular Stans just can't handle the high pressure of road tires. Are there better options?
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
A cut of that size might be better repaired with a plug than sealant alone. I've used Stan's and Orange Seal, and have found no difference in their performance.
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
There are more aggressive sealants with chunks of stuff in them that plug bigger holes but they can also plug up valves.
Stan's Race sealant is one, but there are other brands too.
Quoted: 643 Post(s)
Liked 1,526 Times
I've only been tubeless for about a year and a half but I did a lot of reading prior and the experienced tubeless roadies mostly preferred Orange Seal (regular) to others and many said Stan's was not good for road tire pressures. A couple of weeks after I went tubeless I hit something that was bad enough to spew sealant (as evidenced by having to peel it bits of it off the back of the seatpost and my tailight) but it quickly sealed and I finished the ride without even knowing it happened. So, a satisfied Orange user here.
My anecdotal 2 cents worth.
Likes For Ogsarg:
Quoted: 77 Post(s)
Liked 76 Times
I tried to plug it, but couldn't get the sticky bacon strip threaded into that little needle without mangling it. Better technique may be needed!
Quoted: 714 Post(s)
Liked 800 Times
In my experience, Orange Seal original formula is better than Stans in almost every way. It seals bigger holes and it doesn't develop the the little "Stanimals" of balled up of latex inside the tire. I tried the Orange Seal Endurance formula and it did not perform very well at sealing holes.
Quoted: 222 Post(s)
Liked 304 Times
2-3 mm is a large cut and I don't think most standard sealants would hold over time. At least at road bike pressures. On the side of the road, a plug would be in order. But back at home, for a stubborn hole that won't stay sealed, I'll pop the tire off and apply a common tube patch to the inside wall of the tire. Always seems to work well.
As for Stan's vs Orange Seal, I found Stan's sealed punctures well, but did not seal leaky tire sidewalls well. Obviously, this could be very dependent on the tire and my number of tires I've used is limited. It's not uncommon for new tubeless tires to have leaky sidewalls. I had some tires that Stan's never completely sealed the sidewalls of the new tires. Orange seal has worked well for me in this regard. So, I just use Orange seal.
As for bacon strip plugs, I've found these less than ideal. I've had the plug work itself out of the tire just finishing the ride. I really like Dyna Plugs. These are preloaded with a metal tip that stays inside the tire. Basically it is impossible for the plug to back out. They are also super fast to insert since they are preloaded and ready to immediately push in. They also don't dry out like bacon strips do, or at least take a lot longer to do that.
Likes For Mtracer:
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times
+1 on Orange Seal Regular over Stan’s.
Used Stan’s in GP5000 TL but it failed to seal sidewalls on new unridden GP5000 S TR
Had to switch to Orange Rregular to stop excessive air loss overnight
Barry
Barry
Likes For Barry2:
Quoted: 878 Post(s)
Liked 726 Times
In 3 years I've only used Orange Seal Endurance, which sealed the one puncture I've gotten albeit not as quickly as I expect OS Regular might've. Endurance lasts much longer in my tires than I expected so maybe I'll switch to Regular if I ever use up my Endurance bottle.
Buddy was on Stan's which made a huge mess and didn't seal at all and he was going to give up on tubeless until I told him about OS. He told me he'd since punctured and had it seal, so no more drama after the switch.
Guest
Liked 3,270 Times
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,994 Times
Your name is Dunlop and you are not using tubes At least they are pneumatic tires...LOL.
Probably all the sealant is the best stuff or absolute crap depending on who you talk with. Though if I were spec'ing it for myself I would probably go Orange Seal because it is MUSA but the Effetto Mariposa Veggetex stuff made from old olive oil pits seems kinda neat as a potentially less eco-destroying solution
Quoted: 77 Post(s)
Liked 76 Times
Get better plugs! Dynaplug® Tubeless Tire Puncture Repair Tools and Accessories
Likes For keithdunlop:
Quoted: 112 Post(s)
Liked 25 Times
I started using Stan's sealant on road tires in 2012. It sealed very well, but I had severe corrosion issues with the Shimano tubeless rims. Both Shimano and Stan's blamed each other. It was so bad I had to replace the rims. Furthermore, the residue was very difficult to clean from the tires and rims.
I been using Effetto Mariposa caffelatex in my road tires for a year without any problems of corrosion, no sealing holes issues, and it is much easier to clean.
On my Mtn bike tires I had been using Effetto Mariposa caffelatex, but tried Stan's race sealant. The problem with that is that you cannot add sealant through the removable core valve, and have to break the tire to rim seal.
