Weinmann 610 Center Pull Brakes
Quoted: 702 Post(s)
Liked 672 Times
I'm restoring a 1977 Raleigh Super Grand Prix and thought I'd share some of the process. Most would toss these brakes in the parts bin and install something either new or at least in cleaner condition. I've restored over a dozen pairs of Weinmann CP's and it's very easy and satisfying.
Quoted: 702 Post(s)
Liked 672 Times
As you can see, they are quite crusty...........
Likes For branko_76:
Quoted: 702 Post(s)
Liked 672 Times
Complete disassembly and cleanup with a maroon scotch pad, I suppose a green pad would work as well........
Quoted: 702 Post(s)
Liked 672 Times
Next I use some NEVR-DULL metal polish
Quoted: 702 Post(s)
Liked 672 Times
Then they get buffed with a Micro-Fiber cloth
Quoted: 702 Post(s)
Liked 672 Times
Some grease at the pivots......
Quoted: 702 Post(s)
Liked 672 Times
ambulatory senior
Quoted: 1955 Post(s)
Liked 3,661 Times
The 750s are great for 650b conversions. Grossly underated brakes.
Likes For 52telecaster:
Quoted: 4512 Post(s)
Liked 6,382 Times
@branko_76
So, the emblems got binned?
I've never binned any of these, just recently cleaned up a couple of sets and 7 sets of Schwinn Built and Approved steel and alloy calipers as well.
Also just acquired a gross of calipers that I had to buy to get the one single caliper I really wanted and needed. Couple of sets of these in there too as well as several others. They will get stashed for later and some of the others will get processed soon for use as needed.
I do still need a set or two with good "Schwinn Approved" emblems for current projects.
Likes For merziac:
resykler
Bikes: Bianchi Eros, Bianchi Reparto Corsa, Mongoose IBOC Campagnolo, Schwinn Super Sport, Mairag 4 Star, Canondale Criterium, Centurion Accordo RS, Specialized Hard Rock 1st Gen, Bianchi Special '81
Quoted: 101 Post(s)
Liked 59 Times
I am a fan aswell. These are on my Motobecane Grand Touring '83.
Likes For brixxton:
Quoted: 472 Post(s)
Liked 1,028 Times
I agree and have also cleaned a few of these. Easy to take apart and get into the nooks and crannies. I have a very soft wire wheel, about 3” that I chuck onto the ShopSmith in horizontal mode, low speed. Lightly clean off the sponge and oxidation without scratching the alloy. Then a wee bit lightly on a buffing wheel then Mothers polish. I go a bit lighter on the grease than you did but they alway operate like new when done. Worth the time.
Likes For Prowler:
Quoted: 1829 Post(s)
Liked 3,376 Times
Agreed. The Weinmann centerpulls are good brakes and easy to clean up. Easy to polish and shine quite nicely!
I'm a little surprised to see that grease was applied to the slot on the rear arm. The slot works with a pin on the front arm to keep the brakes centered. There should be a plastic cap on the pin, and that plastic cap acts to allow the pin to slide easily in the slot. The grease shouldn't be needed, and will likely just collect dirt and crud that will act as an abrasive.
I've been impressed with how long the plastic bushings on the pivots last. I had a Raleigh Gran Sport that I rode for 14 years, and never saw any noticeable wear on the plastic bushings.
Steve in Peoria
Steve in Peoria
Likes For steelbikeguy:
Quoted: 455 Post(s)
Liked 112 Times
I built a new mixte frame for my wife and used these!
Likes For Tandem Tom:
Quoted: 1949 Post(s)
Liked 2,010 Times
I figure if they were standard equipment on the Paramount, they are very good brakes. I’ve been tempted to put Mafac Racers on my Grand Jubile but — Paramount!
Likes For Classtime:
Quoted: 823 Post(s)
Liked 1,395 Times
Playing in the Clunker Challenges over the last few years has given me a new appreciation for Weinmann Vainquer 999 centerpulls, decent to better quality 27 x 1 1/4 tires at 70 psi, Normandy Sport hubs and Weinmann 27-in rims. For just going out for a nice ramble on the bike, they're all absolutely fine, and sometimes precisely the equipment that sort of ride needs. In the late 70s I was sooooo eager to "upgrade" to a bike with sidepulls, because centerpulls were so passe. Then one day I looked around the bike cave and realized I had Weinmann centerpulls on FIVE different bikes in there ... what's really fun is to run these calipers with modern stainless cables and Teflon-lined housings and good aero levers. The set I'm running with Tektros on my '73 Raleigh Competition is an amazingly smooth and powerful brakeset!
Quoted: 5888 Post(s)
Liked 3,471 Times
Agreed that these are nice brakes and are very serviceable. Kool stop brake pads are a nice upgrade.
Likes For bikemig:
Quoted: 702 Post(s)
Liked 672 Times
Quoted: 702 Post(s)
Liked 672 Times
I did the rear caliper with just the scotch pad and metal polish to show that they can be easily restored without machinery.
Quoted: 702 Post(s)
Liked 672 Times
Steve in Peoria
Steve in Peoria
Quoted: 1857 Post(s)
Liked 664 Times
One thing I found very useful in brake caliper refurb is to put a dab of grease between each of the ends of the spring and the little aluminum features they will contact. Some small motion and sliding occurs at those points. It really helps add a little more smoothness.
Likes For Road Fan:
Quoted: 702 Post(s)
Liked 672 Times
Quoted: 702 Post(s)
Liked 672 Times
ShopSmith 10ER set to the lowest speed with a soft wire wheel....
https://www.bikeforums.net/classic-v...erailleur.html
Quoted: 809 Post(s)
Liked 1,023 Times
There was a time long ago when center-pull brakes were considered better than side pull. For example in the Schwinn line up, the Varsity got side pull and the Continental and bikes above it got center pulls. Most pros in the 60's and into the 70's were using center pull.
Here is my Continental with the original brake on the front. The Schwinn Approved didn't peel off, it faded away. That is ok with me.
Later on side pull brakes became the preferred caliper.
Shifting is fun!
Bikes: Yes, please.
Quoted: 2198 Post(s)
Liked 4,601 Times
Who's tossing Weinmann brakes? Not me.
Likes For non-fixie:
Quoted: 702 Post(s)
Liked 672 Times
