Worst Sturmey AW I've ever seen
Quoted: 964 Post(s)
Liked 1,451 Times
It's got a '76 date on it. Very neglected Raleigh Sports. Thought I would be able to get it going with a quick rebuild, but it wasn't so.
Obviously it needs a new axle.
One question: Are the gears supposed to fit loosely on the pins like that? Or is that wear as well?
I think @nlerner is going to help me with parts, so I should be ok as soon as I slip on some gloves to measure the axle so I make sure I can get the proper length!
Planet Earth
Bikes: 1951 Raleigh Lenton Sports, 1970 Raleigh Super Course, 1994 Serrota Colorado Ti
Quoted: 7 Post(s)
Liked 31 Times
That's brutal. Oil and rust make for a pretty stellar grinding compound.
Likes For PlymouthJLA:
Quoted: 3810 Post(s)
Liked 6,699 Times
Likes For nlerner:
ambulatory senior
Quoted: 1955 Post(s)
Liked 3,661 Times
Never saw one that bad!
Quoted: 809 Post(s)
Liked 1,023 Times
I did a double look at that sun gear pinned to the axle. At first, I saw that the gear was warn, but that second look allowed me to see the original height of the gear on either side of the where the four pinon gears were running. Someone kept riding that bike despite such extensive wear. I've got to image that the gears would skip and disengage when pedaling hard.
Likes For Velo Mule:
Planet Earth
Quoted: 7 Post(s)
Liked 31 Times
That looks like it has been dragged through more than a few swamps.
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,395 Times
-Kurt
Quoted: 3464 Post(s)
Liked 2,829 Times
Might be time for a donor hub.
even if rebuilt, no out of the saddle pedaling I think would be safe
Likes For repechage:
Quoted: 964 Post(s)
Liked 1,451 Times
I think the owner had taken off the cable and indicator and was just running it as a one speed, and then abandoned it upon graduation. Not a horrible fate, I guess?
Likes For scarlson:
Quoted: 964 Post(s)
Liked 1,451 Times
Miraculously, I think this one only needs those gears/axle and pawl spring that nlerner posted. I still have to assess the teeth on the ring gear, which may be worn but probably will be fine.
But yes, I am regretting having cut apart the three-speed EA3 wheel from a '70s Columbia Sports (kinda lousy even when new) just a few months ago. The Raleigh rim and spokes are better quality, and the Columbia build quality is crap, but this one has seen a lot of crap. I could have swapped, one and done, and instead I'm rebuilding. I promised the bike to a good friend's boyfriend for short money, so I've got to deliver. (so they can ride together, cuuuuute )
Likes For scarlson:
Liked 4,395 Times
When I got the bike (rescued from Harvard's annual abandoned bike purge - even the charities wouldn't take it), I noticed it didn't have a gear cable or indicator chain. I assumed they had been pilfered or cannibalized to keep another on the road. Not that uncommon. But with no cable in, it should have been in high, but it was clearly in middle gear. So I grabbed a spare cable and indicator and hooked her up and then this happened: in low, there was no drive, just clanking and grinding; in high, same as middle but noisier, and middle was, well, middle - direct drive. So I thought maybe pawls were stuck in low and I didn't know what the heck about high because high usually works if middle works. And then I found this!
I've seen more than a few disconnected or missing indicator chains, but can't seem to fathom how removal of the indicator could have helped anything that much. At the end of the day,
Oh well, we'll just blame it on nlerner. There isn't a Sports in Cambridge that he hasn't sold at least once, right Neal?
-Kurt
P.S.: You should never feel bad about parting out a Columbia Sports. Ever.
On the road
Bikes: Old Schwinns and old Raleighs
Quoted: 373 Post(s)
Liked 852 Times
The only thing you can't replace on these is the hubshell. That is fine. And the ratchet teeth also seem fine. You can push (or screw depending on the year) the left (low gear) ratchet out of the hub if you need/want to replace it. It's really nice because you don't have to rebuild the wheel.
Classic American and British Roadsters, Utility Bikes, and Sporting Bikes (1935-1979):
https://bikeshedva.blogspot.com/
Quoted: 964 Post(s)
Liked 1,451 Times
I'll take a picture when I next see it. The paint is that brown color so it pretty much just looks like rust anyway.
That's not entirely true. You are right for low and high, but in middle gear, the clutch drives the ring gear carrier which drives the hubshell via the pawls, so the sun and planets are just along for the ride, chattering and grinding as they go in this case.
Maybe this is why Neal is being so generous with parts!
Good to hear that from someone else. They really do not seem like good things.
I've seen more than a few disconnected or missing indicator chains, but can't seem to fathom how removal of the indicator could have helped anything that much. At the end of the day, regardless of what gear it's in, the power gets transferred to the now-wrecked sun pinion...which no longer does what a sun pinion is supposed to do. I can only imagine the play in the planetary pinion shafts allowed them to jam against the axle as if they were roller clutches in a Shimano Nexus hub, engaging it at times.
Likes For scarlson:
Liked 4,395 Times
There are Huffy and Murrays of this period that look better than the average Columbia Sports (or Tourist - let's not forget they appropriated that name too).
-Kurt
Quoted: 964 Post(s)
Liked 1,451 Times
Yeah, even the way the spokes were waaay too small for the holes in the hub. That's why I cut apart that wheel! It was fairly awful.
Liked 4,395 Times
Likes For cudak888:
