48/32 FSA Vero Chainrings
pan y agua
Quoted: 1451 Post(s)
Liked 731 Times
Is there any reason these wouldn’t work on an FSA SLK carbon tandem crank?
they’re 4 bolt 110 bcd, so they look like they’d fit. And FSA says they’re compatible with all 10 speed drivetrains, and 11 speed Shimano. Anybody tried it
https://shop.fullspeedahead.com/en/p...-pro-chainring
You could get lost and die.
You could hit a tree and die.
[QUOTE=merlinextraligh;22870687]Is there any reason these wouldn’t work on an FSA SLK carbon tandem crank?
Isn't your SLK crankset an asymetric 110 bolt pattern? I could be wrong but these chainrings appear to be symetric. Probably best just to contact FSA support, though. They've been very helpful in the past.
Quoted: 13 Post(s)
You might want to consider whether 48/32 chainrings are optimal. See the discussion by Rene Herse about their 48/33 chainrings at https://www.renehersecycles.com/48-3...-herse-cranks/. I didn't completely follow their reasoning, but give it significant weight.
