Replacing Shimano 3x9 MTB bottom bracket and - best options?
What might be the liighest weight and best quality options that are currently available to replace this bottom bracket and the crank (Shimano SM-BB51 bottom bracket + Deore FC-M591 3x9 crankset) which was original on the bike in 2012? The bike uses 135mm QR dropouts and has hydraulic disc brakes.
3x9 replacement would be most direct but am not opposed to going to 1x10, 1x11 or 2x if it’s straightforward enough.
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
Shimano Deore XT FC-M760 would be a step up, I think, but a new one would be rare and expensive. Here's a used one:
https://www.ebay.com/itm/15459203949...oAAOSw4dhhLmnt
Above one looks ok except for the small chainring.
Or you can a new crankset very similar to the one you have now:
https://www.ebay.com/itm/33411801466...oAAOSw5wphHTVE
(I don't know what the difference between an FC-M590 and an FC-M591 is.)
Thanks / what would the most appropriate current products that I can buy new from official sources like an online retailer or bike shop rather than EBay ?
Liked 2,011 Times
3x9 is old, so there are no new high end light weight instances that I know of. It's either new mid-low end or used higher end (or real expensive new-old-stock high end).
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
Likes For Unca_Sam:
Quoted: 6196 Post(s)
Liked 4,811 Times
If you change to 2x or 1x then other stuff will need to be changed. You can put any crank in there you want that has a BB with 1.37 x 24 TPI which is also sometimes referred to as BSA or English threaded. You just need to also know the width of the BB shell on the frame which should be either 68 mm or 73 mm.
Pretty much everyone makes cranks to fit a BSA threaded shell so you should be able to find something. Try to keep it appropriate to the genre of the bike, in your case a mtn bike and what ever the number of speed on the rear is. But sometimes you can get away with cranks that are for a other speeds. IE. 10 speed crank with 11 speed rear.
Is this BB worn out? You could just replace it and keep the current cranks. Or are you wanting to change something up about the cranks too?
Quoted: 2604 Post(s)
Liked 1,933 Times
FWIW, I wouldn't mess around changing gearing systems (like 2x10 or 1x11) unless you want to buy a new bike.
The dropped
Liked 1,014 Times
Just another note. You have a Hollowtech II external BB. This is still Shimano's current offering, so if there are problems with the unit, you can simply put in a new one. If it's still smooth, Deore-tier cranks on up will slide right in. It looks like Altus cranks and lower are a mix of square taper, octalink (!), and Hollowtech II.
I'm not clear on what's wrong with the current crank/BB. Worn chainrings can be replaced with exact matches, and the BB is still current.
Quoted: 839 Post(s)
Liked 1,064 Times
If you're just replacing the BB due to not running smooth try flushing and re-lubing the bearings. Just use a thin blade to carefully pull off the bearing seals and you'll have access to the bearings. You can even do this without removing the BB but I recommend you do so you can add a little grease to the threads to prevent corrosion while you're at it.
Shimano Deore Front Chainwheel FC-M591 Exploded Parts Diagram
Might be able to locate NOS with the Shimano part number...
