BikesDirect
Slacker
Bikes: 1986 Peugeot Orient Express, 1987 Trek 560 Pro, 1983 SR Semi Pro, 2010 Motobecane Le Champion Titanium, 2011 Trek Fuel EX8
Quoted: 97 Post(s)
Liked 6 Times
You can find many threads here by searching.
Liked 6 Times
Good service and quality of bike for the money. I recently replaced the stock saddle and will do so with other parts (i.e. drop bars, brakes, wheels/tires, etc.).
Great State of Varmint
Liked 15 Times
I'll say this - add at least $100 to the price to have it built-up by a competent bike-mechanic. Then add the cost of all tune-ups and parts that break the first year - and all the next years, too. No warranty that does you any good comes with a mail-order bike. I strongly urge you to reconsider and buy from a store-front bicycle store/shop.
If you just put it together ("It don' look two hard 2 mee...") without knowing all there is to know about how and why - you will have a serious problem on your hands - and under your butt.
Bikes: Habanero Titanium Team Nuevo
Quoted: 399 Post(s)
Liked 185 Times
I bought a bike from them and if you have some skills to turn a few tools then they are fine. If you do not have any skills with bikes then you should get someone to put the bike togther for you. I did it in about 40 minutes and at the time 2 years ago I did not know a lot but it was easy. Do not be mislead they are not the local bike shop if you have problems but I would not hestitate to buy a bike from them again. If they were a shameful business as some say they would not have made it this far. Just make sure you know what you are doing otherwise go to the local bike shop.
After buying two BD bikes, I eventually found out that I'm much happier with my LBS bikes. Both BD bikes are now hanging in the rafters, one will be made into a future cargo bike, and the other bike's fate has yet to be decided.
Can you explain why you feel this way / what makes the LBS bikes preferable? I own a bikesdirect fixie that's now on loan, and I'm not sure I'd ever buy a road bike from them because I'd rather spend another $100-$200 to have somebody make sure I was fit properly, but I want to hear why BD bikes end up in the rafters.
good friends dont
Bikes: Zullo Custom Track
Pro Paper Plane Pilot
Although I've not bought anything from BD let alone a bike, but I find it ironic considering that there are numerous cyclists on this forum that change our parts (handlebars, brakes, cranks, wheels etc...) would be cautious about assembling a bike from BD. I mean these bikes are likely come mostly assembled anyways. All one has to do is put the pedals, handlebars and wheels together. Nothing rocket science about it. Tuning derailleurs or adjusting brake cable? Again not difficult with the rather helpful posters in the Bicycle Mechanic section and websites like bicycletutor.com. If you are first timer into cycling, sure walk into an LBS and get their service which is great.
Liked 6 Times
Liked 15 Times
You realize, of course, that you just set yourself up for something to break?
I'd want a mechanic to examine the bottom-bracket, hubs, and headset for proper lubrication. Not just spin on the pedals and put on the wheels.
You are assuming the minimum wage summer jobby kid would actually take the bicycle apart and go through every nook and bearings. Right. You do know that bicycles arrive at LBS mostly assembled to right? Perhaps if you spend $$$$ on a carbon bike you may get a more experienced tech to go through it. But don't expect that kind of detail on regular bikes. There's a thread about how much a the wages of a bike mechanic vs. T&L to ensure profitability.
E—Bike Newbie
- Is this gonna be your very first bike purchase, or have you owned several?
- What sort of budget have you set?
- How long have you been riding or are you just starting out?
- Are you competent to set up the mechanicals of the bike?
- What type of usage and distances are you looking at?
These sorts of things can possibly influence your decision whether to buy on-line or not. The more experienced you are with bikes and cycling, then the more likely I'd be to recommend buying on-line. I's also dependent to a certain degree on what type of bike you're thinking about; a $350 hybrid or a $3500 carbon racer. El-cheapo's okay online, but upper end? Mmmm...
However, if you're a novice, then I'd say a visit to your LBS is the best (only?) plan.
Cheers.
Arsehole
When assembling a BikesDirect bike, we stripped it. Completely. Then we built it up properly. We earned the $40-$60 we charged to build them.
If I were buying a BD bike I'd be doing so knowing that there are potential problem areas. I'd assume that the shifting would need tweaking, I'd check all the cables, I'd check the bottom bracket and headset to make sure it spins smoothly. I'd probably do a full check of every bolt. If I saw any problems with the rotating parts I might take it to a shop, but more likely I'd disassemble it myself and redo it.
The average inexperienced person would not do any of this and have problems.
The Fat Guy In The Back
Bikes: '81 Panasonic Sport, '02 Giant Boulder SE, '08 Felt S32, '10 Diamondback Insight RS, '10 Windsor Clockwork, '15 Kestrel Evoke 3.0, '19 Salsa Mukluk
Quoted: 320 Post(s)
Liked 177 Times
Kudos for doing it right, but I believe you are the exception rather than the rule. I would wager most shops would do the same assembly they do for every other bike they receive, which generally doesn't mean disassembling everything.
Visit me at the Tundra Man Workshop
Good for you sir! Go search for that thread on bike mechanics and what they make. There were a few mechanics that chimed in to provide inside perspective.
Arsehole
The only people I've ever worked with who made less than $10/hour were indeed high school kids. We let them sweep up, vacuum the showroom, take out the trash, and work as sales people. We also taught them how to work on bikes - on their own bikes. "Kids" weren't allowed to assemble bikes until they had gained a sufficient level of experience and maturity to perform a task that might put someone's life in danger - like a bike assembly.
Obviously, I'm sure this isn't the case in all bike shops. I can think of one shop in Indy that is very lax in this regard. But it has been my experience that many bike shops hire older, more experienced mechanics and the "kids" are more like assistants. Sadly, based on economics, I'm sure that there are many unqualified people assembling bikes. Look at Wal-Mart, for example. Or some of the people who assemble new bikes at the factories.
Quoted: 261 Post(s)
Liked 11 Times
Here in the New York Metro, the mechanics tend to be hispanic or Mexican. They are hired at minimum wage or less but the tend to do OK and some are better than others. Because of the high rents, Mexican labor is used even extensively at expensive resturants.
The best mechanics tend to have more than 20 years experience working on bikes. To get this type of experience, you'll have to find some old timer who's been in the business since the early 80's or 70's.
Liked 15 Times
I may well be that head-mechanic relatively soon. Until then, I'll continue doing custom work here and there - and do it right.
Whoa! I just visited BD and boy, I can see why it is such a viable place to buy bicycles and DIY assembly. I can get a Tiagra gruppo roadie starting $599 brand new! or an entry level Sora for under $400!
