Gravel Saddle recommendation
Let some air out of your tires. Just 2 PSi can make a big difference in rear-end comfort on gravel. Helps with the hands and the feet too.
I have Giant Revolt Advanced, which came with a Giant Approach saddle. I actually really like the saddle for roads, and also have the same saddle on my road bike.
However, for medical reasons (dermatitis), I've been instructed by my doctor to not use bike shorts, or any tight-fitting clothing. I'm able to do this without much pain for the most part, especially on road. I've gone on some 1.5 hr rides so far and it seems my sitbone area is tough enough to not really have issues without the padded shorts.
However, on the bumpier gravel stuff, it's a bit concerning as if I accidentally forget to stand up on the bike before hitting something rough, it could jam the hard saddle into my nether-regions. Also, I'm wondering if 3+ hr rides even on road will be a different story as well.
That being said, I'm looking for a "slightly softer" saddle. I don't want one of those huge padded ones which restrict inner thigh movement, but something that is 1 or 2 steps above the Approach in padding might be nice to try.
Any other recommendations appreciated.
I run the full range of the fizik argo saddles across my small fleet of bikes. On my gravel bike, I have the terra argo. Road bike the vento argo and tempo argo on my TT bike. It's a shape that seems to work well for me.
Quoted: 427 Post(s)
Liked 339 Times
Bikes: 1984 homemade 531SL road bike; 1988 Ritchey TimberComp; 1997 Nashbar tandem; 1998 Kona Explosif; Specialized Epic, Scott CR1 Pro; Salsa Beargrease; Curtlo custom Tandem, Curtlo custom S3 steel gravel bike.
Quoted: 67 Post(s)
Liked 49 Times
Agree with the comments that saddle preference is highly personal and very difficult to predict based on anything other than a long ride. I'm someone who has not usually been very picky about saddles. Having said that I recently bought a Berk Dila carbon saddle because I am building a weight-weenie gravel bike and want components made in small shops rather than big factories in Taiwan. The Berk saddle is just amazingly comfortable and felt like I added a suspension seatpost - which I do not have.
I'll second the recommendation to take a look at SQ Labs saddles. I just got their 610 Ergolux Active 2.0 and took it out for 88 miles on it's first ride and it felt great, no soreness afterwards and I'm about 200 lbs so not particularly light. The Ergolux models have a little thicker padding than other models, but I think it's the overall design that seems to reduce pressure points. Saddles are certainly very personal so it's hard to give someone else anything more than a suggestion to try. I also have a Brooks Cambium C-17 that generally gets rave reviews and while it's also very good, I find the SQ Labs 610 to be noticeably more comfortable for me.
This is going to sound weird but a while back I bought a Cobb Randee on a whim for the road bike and now swap it back and forth between Bianchi and Fargo. Ugliest saddle I've ever sat but man it's great for the longer hauls. I had to adjust it quite a bit and then adjust my approach to saddle use but once dialed in it becomes one of those saddles you forget is under you.
Bikes: Dahon Jetstream p8 (sold), customized Dahon Helios x10, customzed Dahon Smooth Hound x11,customized Dahon Hammerhead 8.0 d7, Planet X Free Ranger (mullet setup 1x11), Planet X Giovanissimi 20 (1x9), Frog 52 (1x9) and Frog 48 1s
Quoted: 264 Post(s)
Liked 240 Times
I have been riding the fizik TERRA ARGO X5 (steel rails) on my gravel bike for just over 1 year and it is good with bibshorts. Per fizik customer service advice, I went for the 160mm, the larger one for comfort.
On the minivelo, I have a Fabric scoop elite gel 155 and it is comfortable without bibshorts...
On the folding bike, I have a Fabric Line Pro 142 at it was a mistake... I can ride it with bibshort but went commuting loaded with laptop backpack etc., it is not great after 1hr.
