Crankset FC781 48-36-26 : possible to replace 48T with 38T
Bikes: Custom built LHT & Troll
Quoted: 846 Post(s)
Liked 149 Times
My touring bike is equipped with Shimano's trekking group. The crankset is nominally a triple 48-36-26 (104/64 BCD) and the cassette an 11-34 XT. As I rarely push gear-inches above 90 and definitely do not like the 13T-11T step, I've replaced the smaller 11-19 XT sprockets with Miche's 15T-19T, which gives a reasonable range (495%) and narrow gaps (5%) for gear-inches above 50 or so (see here).
Finding replacement parts is becoming somewhat challenging, so I am considering reverting to a stock XT 11-34 cassette, which could work great in half-step mode, if I were to swap the 48T chainring for a 38T.
Is this possible? Other thoughts?
[EDIT - initial post didn't link correctly to the proper page. My current gear range is [url=https://www.ritzelrechner.de/?GR=DERS&KB=22,36,48&RZ=15,16,17,18,19,21,23,26,30,34&UF=2075&TF=90&SL=2.6&UN=KMH)]this. Replacing the larger chainring and cassette would give this)
Mother Nature's Son
Quoted: 853 Post(s)
Liked 1,437 Times
I do not understand why you would want to drop to a 38 when you have a 36 middle. I understand you are not pushing big gear inches, but the 38 makes the gearing awfully low. I also am not familiar with 104/64 front, ergo, I do not know what rings might be available. Maybe look for a 44 tooth big ring. Sometimes you just have to play around to find what is going to work best for you.
Quoted: 6196 Post(s)
Liked 4,810 Times
Is this your front crank, an FC-T781 ?
https://bike.shimano.com/en-EU/produ...0/FC-T781.html
If so you can change to 2x easily enough. Though I'd expect you to get a new 2x crank, 2x front DR and 2x front shifter or STI.
Or did I read your title wrong and you are just wanting to replace the big ring for smaller?
Quoted: 1944 Post(s)
Liked 2,164 Times
I agree that a 38-36-26 doesn’t make much sense. If a 38t is the correct large ring, drop the 36t and replace it with a 38t. Run it as a double.
John
John
Really Old Senior Member
It will REALLY SUCK as far as functionality.
The FDER will be "looking" for a big ring that isn't there.
I converted my bikes to a 22-32-44 w/ a more roadish cassette.
I changed the large ring to 36T on one bike and 38T on the other.
The 38T ring shifts reasonably well, but does have a little "lag".
The 36T ring results in MUCH crappier shifting than the 38T.
My advice is to stay at LEAST 6T larger than the middle.
You can get an idea how ugly....
On my hybrid, I'd run 12-23 or 13-25's and my smaller wheeled 86/7 Rockhopper/grocery getter a 12-27 cassettes. I'm pretty flat terrain wise though.
Quoted: 846 Post(s)
Liked 149 Times
Quoted: 2026 Post(s)
Liked 1,096 Times
The 38/36 shift is going to be a problem. Your front derailleur's inner cage plate will hiit the 36T if the cage is set properly above the 38T chainring and if the derailleur is set to clear the 36T, it will be way to far above the 38T to shift at all well. Unfortunately, half-step gearing pretty much went away as cassette cogs exceeded 6 or 7-speeds
Quoted: 846 Post(s)
Liked 149 Times
HillRider thanks for your input. This being said, I don't understand why that is going to be a problem. I mean, the 26T (I've actually swapped a 22T) is much lower than the FD's cage, yet it shifts very well. I (naively) thought that lowering the FD, perhaps with a wee bit of excess clearance WRT the larger chainring, would work well... funny as something that looks simple on the surface turns out to be difficult to implement
The smallest ring is moot since you won't get past the middle.
The "slope" the FDER travels is going to remain the same no matter what you do to ring sizes.
IF it currently just clears the middle ring, how can it clear the middle ring if you lower it 4-6T more?
Quoted: 846 Post(s)
Liked 149 Times
Bill Kapaun Yes, I see what you mean. What isn't really obvious to me is why exactly would I want to lower the front derailleur??
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
Liked 2,164 Times
I'm running my mtb's with 34-24 chainrings and the FD's are more than 25mm above the middle ring. It is basically set where it would be if I had an outer ring.
It is a bit of a catch 22. It shifts fine as the inner derailleur cage is aligned at the correct place to move the chain from inner to middle; the FD doesn't know there isn't an outer ring. I did install a bash guard in the outer position as a precaution against throwing the chain off the middle ring. That is the catch 22 part. I'm not convinced I wouldn't drop a chain over rough terrain with the gap between ring and FD cage so great.
I would guess a 36 to 38 outer would require a wide gap for the middle to outer. Chainrings with ramps and pins would help, but I would think the inner cage needs to be set correctly for upshifting from the the inner and middle chainrings.
John
John
I responded why you can't.
Likes For Bill Kapaun:
Old fart
Quoted: 3590 Post(s)
Liked 3,400 Times
Seems like a lot of work for not much gain.
Old fart
Liked 3,400 Times
Performance can suffer if the front derailleur is positioned too high. It can either have a hard time lifting the chain to the outer ring or throw the chain completely past the outer ring and into the void, or both. This is particularly an issue with indexed front shifting. Best performance is when the outer plate of the derailleur sits only a few millimeters above the teeth of the outer ring.
All my touring has been with 52/46 in the front and 5 cogs at 14-28 in the rear. If the 46/28 would have been to high a gear then I would have replaced the 28 with a 30 tooth cog. All one really needs is a granny gear that is low enough that you can go up any grade you will encounter. Unlike racing there is no need for even intervals with the rear cassette or freewheel. More than 80% of the time I am using the 52T chainring. With more speeds available at the rear I would first go to 11T and have a taller gear for the downgrades. I pick up a lot of time by pedaling down the grades and it provides more speed for pushing up small hills on rolling terrain.
My maximum tour load is 25 lbs and when I started credit card touring and staying at hotels and inns and eating at restaurants my load dropped below 15 lbs on the rear. Even easier to carry fewer tools and replacement parts with so many excellent bike shops all over the place.
