Is a SRAM AXS mullet worth +$1k over GRX 1x mech?
Sunshine
Quoted: 10963 Post(s)
Liked 7,490 Times
Bikes: Dahon Jetstream p8 (sold), customized Dahon Helios x10, customzed Dahon Smooth Hound x11,customized Dahon Hammerhead 8.0 d7, Planet X Free Ranger (mullet setup 1x11), Planet X Giovanissimi 20 (1x9), Frog 52 (1x9) and Frog 48 1s
Quoted: 264 Post(s)
Liked 240 Times
So,while I don't mind SRAM which I have on the gravel, I prefer shimano because better and more precise and generally easier... Any electronic stuff is cool as you can miss match road shifter with MTB transmission and vice versa...
But, as somebody else said, it needs to be charged every so often. having to change my powermeter and light/radar is irritating enough and they often fail because I didn't recharge between small rides... just because of that, I'd rather go all mechanical, no "fly by wire"... bikes are in theory mechanical machines...
Now I understand that if you go mechanical, you will be have a "hyper mullet", you will not just mix road and MTB bits, you will mix manufacturer ranges of road and mtb bits: shimano grx gear actuator, sram chain, e13 cassette and some chainring/crankset?
Likes For Fentuz:
Likes For GrainBrain:
I’m a little Surly
Quoted: 699 Post(s)
Liked 1,294 Times
I’d go SRAM because Shimano hoods don’t agree with my hands
Likes For Germany_chris:
Quoted: 60 Post(s)
Liked 33 Times
- GRX shifters/brakes
- XT crank with Wolftooth chainring (compatible with 11 speed and Eagle)
- GRX rear derailleur with goat link as needed
- EThirteen cassette 9-46
- SRAM eagle chain
Likes For FrankTuna:
Quoted: 264 Post(s)
Liked 240 Times
46 should work without goatlink (may need longer B screw).
the only issue is that if you damage the deraiilleur, you may not be able to use the warranty
Likes For Fentuz:
Likes For sarhog:
Quoted: 264 Post(s)
Liked 240 Times
Likes For Fentuz:
Quoted: 446 Post(s)
Liked 1,045 Times
Mechanical set up would be:
- SRAM eagle chain
Also I'd probably vote going mechanical. $1000 saved could go into other aspects of your bike especially wheels and/or lightweight components.
Quoted: 60 Post(s)
Liked 33 Times
I'm curious, so the EThirteen cassette would need a SRAM XD or XDR hub correct? Having a 10/9t cog would make me consider going 1x to get a bit more high gear.
Bikes: 1984 homemade 531SL road bike; 1988 Ritchey TimberComp; 1997 Nashbar tandem; 1998 Kona Explosif; Specialized Epic, Scott CR1 Pro; Salsa Beargrease; Curtlo custom Tandem, Curtlo custom S3 steel gravel bike.
Quoted: 67 Post(s)
Liked 49 Times
As an FYI - 3T makes a 9-32 11 speed cassette. Actually 2 of them - one has 9 and 10 as the small cogs and the 32 is a bailout; the other has 9 and 11 as the small cogs so the 9 is "overdrive". My next gravel setup will be 40/26 White Industries crank and 9-32 overdrive cassette. Gives me all the range I have on my current 46/30 and 11-36 and overall better spacing of gears.
Quoted: 264 Post(s)
Liked 240 Times
Can use XDR with a spacer/shim for 9-46. I believe the shim need to be wrapped around the XDR thread to take up the slack and allow adequate "pinching"
Quoted: 264 Post(s)
Liked 240 Times
I run 36x 9-46 which is equivalent to 40x 10-52 /40x10-50 (well to be accurate, it would be 40x 10-51).
When I run the 700c, I have 36x11-46 so with the 9-46, I could run 30x9-46 and keep the same "road" gearing but easy the "off-road" set up. I did not do it because I don't really want to spend too much time on cog 9T but I may consider a 32 ring for Welsh mountain adventures... This would be similar to classic XC GI setup.
