After-Market Thru Axles (Levers)
Quoted: 286 Post(s)
Liked 261 Times
My bike came with thru axles that use a 6mm hex wrench to take off. I’m going to run multiple wheelsets, swapping them often, and was thinking it would be easier to have the type that have a lever (like a QR). But I’m struggling to find at online retailers (in Canada). Mine are 12x100, 12x142, 1.5mm thread pitch. Any suggestions?
Quoted: 427 Post(s)
Liked 339 Times
It probably would be easier to get a set of DT Swiss TA handles with a hex on the end. You can just leave them attached all of the time if you want to. That way you do not have to buy whole axles.
Likes For dwmckee:
Expired Member
Quoted: 3674 Post(s)
Liked 5,431 Times
I suggest you stay with the hex. There are a variety of TAs with levers attached and some of them are fiddly. I had one that was such a pain I ditched it for a RAP with just the hex. If you feel compelled to change, make sure you are satisfied with how the new one works before you buy.
Likes For shelbyfv:
Quoted: 714 Post(s)
Liked 800 Times
Paragon Machine Works https://www.paragonmachineworks.com/...polydrops.html and DT Swiss make the best thru axles with adjustable handles.
Thru axles are not as easy as just knowing the thread pitch and the axle standard, such as 100x12 and 142x12 with 1.5mm pitch. You need to know the overall length of the axle from the head to the end of the axle and the length of the threaded section, as well. Those marking should be on the axle.
Likes For dsaul:
Quoted: 6963 Post(s)
Liked 10,963 Times
Quoted: 286 Post(s)
Liked 261 Times
What had frustrated me with the existing ones was that when I inserted the hex key into the ‘head’ side and turn CCW to loosen, the head didn’t easily accept the hex key, had to jiggle it and then it engaged (has to insert it past that head, it wasn’t intuitive). That head, when the TA is removed spins freely. I don’t get that head end.
So I just removed them by inserting the hex key into the ‘other’ end and loosened CW, then tightens them CCW. That was much easier.
Is that how this style of TA is supposed to work?
The head end on the left by the specs
The other end that was easy to remove with a hex key (righty/loosy, lefty/tighy)
Quoted: 714 Post(s)
Liked 800 Times
I don't know about that particular brand of axle, but some of them are made to have a removeable handle that can stay attached to the axle. In order to keep the handle from falling out, they have some type of retention system inside the hex. Sometimes that is just an O-ring inside the hex that makes it difficult to get the handle/wrench in and out.
