People moving your bike w/o your permission
I'm pissed someone keep move my bike around.
I don't use the bike rack because I don't want my bike scratched up or bent,
and there's no rule against parking my bike on the side of an office building.
I have been puzzled why someone keeps moving my bike around.
Then, dawn on me, that whenever I park my bike infront of a particular window,
my bike gets moved while I'm inside building working.
One day I was locking up my bike in front of this particular window (a pretty good spot because it's covered, protected by awning) because my usual spot was taken up by two other bikes, and I look up and saw thru the window a older guy sitting inside the building staring me down with an old nasty look.
I guess he's the one been moving my bike around.
I guess he doesn't like having a bike in front of his window blocks his view of the outside, maybe.
What should one do? Find another spot to park (give in to his bullying) for sake of harmony?
Or confront him, stand my ground, because I have the right to park there?
Don't make me sing!
Bikes: 2013 Specialized Crosstrail Elite, 1986 Centurion Elite RS, Diamondback hardtail MTB, '70s Fuji Special Road Racer, 2012 Raleigh Revenio 2.0, 1992 Trek 1000
Quoted: 308 Post(s)
One day I was locking up my bike in front of this particular window (a pretty good spot because it's covered, protected by awning) because my usual spot was taken up by two other bikes, and I look up and saw thru the window a older guy sitting inside the building staring at me with a nasty look.
I guess a bike in front of his window blocks his view of the outside, maybe.
What should one do? Find another spot to park (give in to his bullying)?
may be time to post an image of the parking situation..
Here We have a good number of bike racks around town, to lock your bike up to it securely
They're set in concrete, with anchor bolts,
If they can move your bike, the locking scheme you use is likely inadequate..
(didn't you get a folding bike?, you can bring those in, Others do , Bromptons can fit under desks.)
Bikes: 2016 Novara Mazama
Quoted: 3640 Post(s)
Liked 81 Times
Hard to know without knowing the whole situation. What are you locking your bike to? How far is your bike getting moved? Are you blocking the view of a window that need to be kept clear? You say "an office building" not "my office building", are you just leaving your bike on a building you have no connection with? If they offer bike parking that you refuse to use, isn't it entirely possible that they don't want your bike parked where you deem it to be a good spot, despite your insistence that it is totally OK?
If your bike is regularly getting moved, I'd venture a guess that someone else doesn't think it is an appropriate place. Whether that person has the authority to make that decision or not, I have no clue, and no one else here does either.
Quoted: 18424 Post(s)
Liked 15,582 Times
Your bike it not locked to anything?
Half way there
Quoted: 987 Post(s)
Liked 880 Times
I don't understand the logic that you are worried about damage at a bike rack, but feel that damage is unlikely in other places.
Also, you have no rights other than what the law and the property owner allow you. Absence of a rule (or the absence of your knowledge of a rule) does not constitute a right.
My advice is to: 1) Verify the municipal code that you are not prohibited from parking where you do. 2) Assuming that it is legal, then ask the property management if it is ok. 3) Assuming that it is ok with them, talk to the gentleman whom you suspect.
Or you could save yourself some trouble and park it in the facility provided (which is what the property owner will probably tell you).
I don't lock it...nothing to lock it to. It's a cheap Dahon...I don't need to lock it.
No post near the building or anything (except the bike rack, which is usually very full).
Because it's a slick office building.
I'm in campus-type professional environment. Well paid workers. No theft.
Well the view here is very nice...I can understand why the guy would be annoyed that a bike is partially blocking his view of the pond and manicured lawn...but he should be working not looking out the window.
Sort of like this. See there're lots of places to park bike next to the windows.
In my case, there are awning-like things over the windows...so I luv to park next to the windows...I don't like the bike racks, they're exposed to the sun and rain, and crowded...don't want to get my derauillers bent.
Liked 15,582 Times
Now you have me totally confused:
"I have been puzzled why someone keeps moving my bike around.
One day I was locking up my bike in front of this particular window"
And why do you call him a bully when you admit that you have to proof he's the one?
Finally, if you are leaving the bike in the path of a walkway, the property management might not want it possibly interfering with access by the disabled. You sound like a master speculator. What is your basis for claiming there is not "rul" about parking your bike where you are when it gets moved?
Liked 15,582 Times
Liked 81 Times
Are you leaning it up against the window? Is it blocking a walkway? Those canopies are generally for people walking into the building.
From what you are describing, I'd never consider that an acceptable bike parking spot. It may well be Facilities moving it, to prevent damage to the building or facilitate access. They may not want you in the landscaping. After seeing that picture, I'd actually venture a guess that it is not the man you saw who is doing it.
I'm not the only one. There;re at least a dozen bike outside right now parked in front of windows.
Liked 15,582 Times
Are you intentionally coming off as dense? The issue is about the one particular spot you claim your bike is moved from. Perhaps leaving a bike in that particular spot could hinder access by the disabled or hinder egress in the event of an emergency. Since I cannot see that particular spot I cannot tell. And you still haven't explained what proof you have that it's the individual you mentioned. Or have you made all this up for attention?
Liked 15,582 Times
Quoted: 176 Post(s)
Liked 25 Times
Don't know about this one ,,,,, if you don't lock it you don't mind losing it so why are you so concerned about it getting scratched and bent as you put it,,,, don't make sense,,,,
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1297 Post(s)
Liked 940 Times
If he has no authority, then he needs to be put in his place. Talk to your boss.
Bikes: 2015 Giant Escape 2,
Quoted: 52 Post(s)
That being said, he shouild hgave asked you to park elsewhere instead of moving it himself.
Bikes: Bianchi Ti Megatube; Colnago Competition; Planet-X EC-130E; Klein Pulse; Amp Research B4; Litespeed Catalyst; Trek Y11
Quoted: 605 Post(s)
Liked 480 Times
If you're parking your bike not in a designated place for bikes, all bets are off. You should be happy it was simply moved, unharmed, to a nearby location. I'm surprised it hasn't been chucked into the street...
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
I don't understand why people get angry instead of discussing things face to face.
Say hello, introduce yourself, shake his hand, ask him if he moves your bike or if he knows who does it and take it from there. It doesn't have to be a war. Just two people having a conversation, that's all.
If the guy gets angry or escalates then walk away and figure out what your next step is. He could be your next best friend or have a cute sister who rides bikes too. Who knows?
-Tim-
-Tim-
Liked 15,582 Times
Galveston County Texas
Bikes: 02 GTO, 2011 Magnum
Quoted: 1350 Post(s)
Liked 1,245 Times
-Tim-
-Tim-
Talk with the Security Dept. You may be violating an Insurance code.
Fred "The Real Fred"
But one of 'em I paid $1600, so I get annoyed when someone decide to push my expensive investment into a bike rack full of dirty rusty huffy and Next cruisers.
I always lock up the wheel on my favorite, just in case like I said an cycle savvy interns wants to take a test drive.
But I don't like it if someone moves even my crappy stuff without my permmission.
Standard Member
Liked 940 Times
Why does mtb need to be in authority to talk to someone in charge? I don't get your point.
