Three Speed Parts: What Are These Called and Where Can I Buy Them?
Quoted: 37 Post(s)
Liked 77 Times
I'm working on several three-speed projects at the moment, three Raleigh Sports and one Hercules. I find myself missing some small parts from these 50-year-old bikes and I don't know what to call them or where to buy them. My most significant need is for the small plastic insert that is used in the shifting cable. The housing runs from the shifter to this stop and is bare wire afterwards. I don't know what to call the plastic ferrule (the middle piece in this photo) or, more importantly, where to get one. It fits into the cable stop on the left. I also need to find one or two of the clips that hold the rear brake cable housing to the top tube; it's on the right in the photo.
I would be thankful if someone can tell me what to call these thingamabobs and where I can acquire them. Cheers!
Bikes: 1963? Anquetil , 1973 PX10,1979 PX10,1984 PX10, VITUS 979 PX10DU,1970S ALAN,1985 PSV10,1980s PY10FC,1978 bERTIN,ALAN carbon
Quoted: 283 Post(s)
Liked 641 Times
The white bit and clip is called a fulcrum clip by sturmey archer .
There are different sizes for different tube diams
eg
SA P/N HSJ513
eg
SA P/N HSJ513
https://www.flickr.com/photos/70488435@N03/
Likes For 1simplexnut:
Quoted: 3855 Post(s)
Liked 6,980 Times
Fulcrum sleeve. Find a metal one if you can; the plastic ones eventually disintegrate.
Palmer
Quoted: 1706 Post(s)
Liked 1,900 Times
As stated above, the plastic insert is called a Fulcrum Sleeve (Sturmey's only part w/o a part number?). Here's the whole family of thingamabobs:
https://www.sturmey-archer.com/en/pr...ke-and-fulcrum
Google brings up multiple sources.
EDIT: It's Sturmey p/n HSJ515
Likes For tcs:
Quoted: 37 Post(s)
Liked 77 Times
Thanks!
I really appreciate knowing that I'm looking for a fulcrum sleeve, it's much easier than asking for "that plastic thing that goes along the shifting cable of a three-speed bike".
Likes For Nokton:
Phyllo-buster
Quoted: 2300 Post(s)
Liked 2,067 Times
I can help you out with some of this. Pm'd
Likes For clubman:
I don't know.
Quoted: 343 Post(s)
Liked 920 Times
BF at it's finest.
Likes For RB1-luvr:
Count Orlok Member
Someone used to sell metal ones; I'll see if he still has some.
Likes For gna:
Liked 6,980 Times
Here's a metal one on eBay that'll set you back about $12 shipped: https://www.ebay.com/itm/304704306674
Likes For nlerner:
blahblahblah chrome moly
Quoted: 1230 Post(s)
Liked 2,751 Times
The way the fulcrum is slotted and removable from the clip allows you to install the old gear cables that came fixed length, with lead ends on both ends. Nowadays people are more likely to us the kind where you cut the cable and housing to length, and the adjuster that threads onto the indicator chain has a cable anchor (hole through a bolt). If using that kind, then you don't need a Sturmey fulcrum, you can use any housing stop, whether clamp-on or braze-on, slotted or unslotted.
Of course you may want to keep your gruppo "tutto Sturmey" anyway, nothing wrong with that. That's what I usually do — even though I like to cut my housing to length, I still use a real S-A fulcrum clipped to the toptube, and a real S-A steel pulley (or 2) near the seat cluster to direct the cable(s) down the seatstay(s). (2 cables in the case of my S-5 hub.)
Mark B
Mark B
Likes For bulgie:
Count Orlok Member
John Sharratt, the STO of the Lake Pepin 3-Speed Tour, says he has plenty of the metal fulcrum sleeves and pulleys. He had a machine shop make them a few years ago. Email him for more info: https://3speedtour.com/questions%3F
(The parts link on his website doesn't seem to be active).
Likes For gna:
Old fart
Quoted: 3619 Post(s)
Liked 3,460 Times
Likes For JohnDThompson:
Count Orlok Member
I took them to the machine shop at work, and the guys made a fulcrum sleeve and pully out of some scrap stainless for me. I had them on a Triumph I gave to my brother.
Likes For gna:
Phyllo-buster
Liked 2,067 Times
I didn't clean these.
Likes For clubman:
