Original paint layer? - paint expert advice appreciated
Hi all,
I just bought a Marinoni track bike that has a bunch of layers of paint. A bit of sanding and scraping around lugs and bottom brackets have revealed a couple colors, which I think are easy to eliminate.
I'm curious if anyone can help determine which layer is primer/sealer and if the original color was white or a base for a higher luster top coat.
The layering goes - dull reddish brown (I assume this is the original primer and sealer?) White. Either a base coat or original color which is quite possible. Purple frame with yellow head tube and fork. Purple seems to be the hardest thing layer of paint. It seems more like automotive paint than the Blue or top layer. It could have been a respray over white paint. There is over spray on bearings. This is definitely not original. Then the final sad layer of purple and pink fade.
What do people people original color scheme was:
All White
Sparkly purple with a yellow fork and head tube (likely seat tube stripe)
All White
Randomhead
Liked 3,714 Times
I think the red was the primer. It's a bit weird. It shows up on the fork too.
Likes For unterhausen:
framebuilder
The red is going to be the primer. We used a lot of redish/brownish primer years ago. It sticks and sands well. The white is going to be the sealer. A sealer serves several purposes. It provides an even background color. It is easy to get a few sand throughs on the primer. These can be noticeable through the top coat color. It also makes the top coat color "pop". Most colors have some kind of translucence and is influenced by what is beneath it. And finally a sealer provides better adhesion between the primer and top color making it less likely to chip. Chipping between the primer and color is common. To be effective the top color has to be applied within a certain time window of when the sealer was sprayed.
I'm guessing that the original color was right over the white sealer and any colors beyond that were resprays (either pro or rattle canned) over the original paint color.
Likes For Doug Fattic:
Thanks Doug!
I was wondering if that may be the case. On top of the white on the frame is a quite thin and study coat of metallic purple where it wasn't sanded thoroughly (lugs etc). Fork and head tube a solid yellow. I'm guessing that may have been the original paint scheme then.
