Quick PSA-
of Clan Nrubso
Bikes: Cannondale F400, Surly LHT,Motobecane Le Champion Ti, Novara Veloce
Quick PSA-
Just a quick PSA that I think especially applies to us Clydes/Athenas since I am always amazed at the abuse I can throw at a bike chain...
I broke my Surly's chain tonight; no big deal, starting from a light, didn't get hurt. What shocked the hell out of me was when I got home and found this...
^^^that's the break that got my attention. But then I noticed-
(Insert Ron Popiel voice here>) "But wait, there's more..."
to the right of the big break,
and...
Bare with me if I doubled up on any of the pics as I know I also left some pics out (how much busted chain can you really bare to look at?), but in the end I counted TWELVE broken links on this chain.
Fatties unite, and let's all check our chains before someone loses some teeth.
and...
got the climbing bug
Bikes: one for everything
Quoted: 634 Post(s)
Liked 920 Times
how many miles are on that chain? I love the sram chains on my MTB, KMC makes some good stuff too that last a bit longer for roadie use
Rule #10 // It never gets easier, you just go faster.
Bikes: Flat bar road bike, trail bike and MTB
How many miles you got on that chain, if I may ask?
BierHaus Bertolette Road Bike, built 2007
BierHaus SRT Trail Bike, built 2010
Fuji Mt. Pro - 2007
Fuji Mt. Pro - 2007
Bikes: Lemond Chambery/Cannondale R-900/Trek 8000 MTB/Burley Duet tandem
Wow, that is pretty bad. There was a period where SRAM had some chains that were breaking very often. Read the reviews in on the chain about a year back, not very good. Some said their chains broke on the first and second rides. MTB. I'm running a PC51 on my roadie and don't see any problem. Hopefully it was bad lot.
But I did just inspect mine after your post.
How old is your chain?
of Clan Nrubso
I don't know the exact mileage on the chain, it's been replaced a several times and there are about 5500 miles on the bike. I'm thinking at most 1100 miles on it, but I could be off by a couple hundred either way. I live in a hilly area which is notoriously hard on chains, but I'm pretty good about shifting down and not hammering on that bike (flexy frame, hammering doesn't help).
of Clan Nrubso
Beanz, I think that chain was new last fall. I tend to change my chains in the fall wether they appear to need it or not; an ounce of prevention type thing. My roadie bike has ten speed Sram, thinner chain and it gets changed more frequently because I do hammer on that bike.
But I have kept a good eye on my chain after reading the sad reviews.
of Clan Nrubso
of Clan Nrubso
Could be a bad lot from Sram, not disparaging them, dig there stuff and all. Could be the ever prevalent rain,road grime, sandy-grit-stuff mix that I tend to be forever wiping off my chain. Maybe it's the cleaning method (I use diluted Simple Green and a tooth brush then a few rinse cycles in isopropyl alcohol). Just shocked the heck out of me to find so many breaks at once.
Cat 5 field stuffer
Bikes: Wabi Lightning RE, Wabi Classic
Quoted: 5 Post(s)
Liked 7 Times
I clean mine, on a road bike, about the same way. I've taken to cleaning and lubing more often, about every 200 miles, than I used to. I lube mine link by link so I'm looking at it fairly close. I hope I'd see damage if there is any. At least I keep telling myself that.
I used simple green long ago. I had stuff break on me, front der, spokes, and other stuff. I read somewhere that others had the same problem with sg. I quit using it and haven't had any similar problems. I've read sg can be real tough on stuff.
I only use citrus based degreasers now. I us a chain cleaner machine every so often and also lube link by link. Or I just wipe with a DW40 saturated rag, allow to dry then relube depending on how dirty the chain seems. I do keep it clean and lubed and away from wet weather.
There are a couple threads around about the negative effects of Simple Green. If my recollection serves, mostly about not leaving chains to soak in the stuff.
Birth Certificate, Passport, Marriage License Driver's License and Residency Permit all say I'm a Fred. I guess there's no denying it.
Quoted: 32 Post(s)
Chains tend to do this when you mash a lot, especially from the start. Its the torch (sp?) we have, especially when starting.
Spin more. And when you are about ready to stop or slow down, change to an easier gear so when you start back up you are spinning and not mashing.
Bikes: 2012 Marin Larkspur CS Series.
Quoted: 18462 Post(s)
Liked 15,725 Times
2nd Amendment Cyclist
Bikes: Schwinn 2010 World Street, Handsome Speedy w/ SRAM Apex
I had a KMC on my road bike until it died on me. Replaced it with an SRAM chain.
Chain failures seem to be caused by a few things. Bad install of the master link; screwing up a link when shortening or lengthening the chain (leaving a link too tight). Improper cleaning and re-lubing.
When I clean my chain, I use Dawn dish soap, and scrub the heck out of the chain, cassette, and crank rings. Then I rinse, and liberally apply chain lube, and wipe the chain clean as I spin the cranks and change gears to get lube on all the cassettes and front rings. Repeat the lube/wipe process until the only thing coming off the rag is lube instead of dirt and grime.
If I haven't cleaned the chain in a while, it can be a LONG process to get all the grime out of the links.
Cyclist CFI
Bikes: 2004 Specialized Roubaix Elite, 2016 Boardman SLR 9.8
Strangely short life. I just checked and I've got 5300 miles on my 9-speed dura ace chain since I changed it last October. I clean on the bike with citrus and lube every week or two. No answers but another data point.
Clyde & 50+
Clyde & 50+
of Clan Nrubso
Have you ever tried putting the chain in a jar with some ipa and shaking it up a bit after you've cleaned it? For me this was a carry over from my military days, but was still amused at how much more black grease and grime comes out from deep down inside the chain. I think that the alcohol penetrates down in and displaces degreaser/grime that is otherwise missed.
Regardless I am going to switch back to the citrus stuff I used in the past just in case it is SG related. Or maybe I'll give Dawn a shot; I've heard of other people swearing by the stuff.
Bikes: 2003 Cannondale Jekyll 1000, 2014 Fuji Finest 1.5 (wife), 2008 Fuji Finest 1.0 (Daughter), 2012 Fuji Cross 2.0 (son), 2011 Cannondale Road Tandem 2
Quoted: 57 Post(s)
Liked 27 Times
When I went to bike school the teacher said do not clean your chain with any cleaner unless you absolutely have to. Instead, wipe your chain down with a dry lube. It cleans the chain but does not remove lube from the inside of the links and the excess can be easily wiped off. I now just use lube to clean my chain.
