beautiful pug
Bikes: Nishiki Saga, Nishiki Olympic
beautiful pug
https://seattle.craigslist.org/see/bik/1022565609.html
Peugeot 63cm ultegra 9spd - $350 (belltown)
Reply to: sale-1022565609@craigslist.org [?]
Date: 2009-02-05, 3:25PM PST
Peugeot PGN10. This is a full Reynolds 501 frame and forks. No rust, shiny paint, the chrome forks are flawless but the paint does have a few scratches as would be expected. The wheels are a pair of Mavic MA3's with a 9spd 11-27 cassette. Ultegra 9spd derailleurs. Compact crankset, 34/50, stripped and polished. Shifters are the newest model Tiagra, brand new with all new cables. New tires. 100mm 3ttt stem and new Easton EA50 bars, 44cm. Rides great, shifts smooths.
and once again the picture will not cut and paste on here for me not sure why not.
Forum Moderator
Quoted: 3093 Post(s)
Liked 6,607 Times
thanks Bill, not sure why I can't copy the pics but I just can't seem to get that part taken care of.
So thank you for once again helping me out... it's all about the team work, right.
Forum Moderator
Liked 6,607 Times
Isn't that like the one that miamijim received with the dented top tube?
edit: Alas, it is bigger.
I believe it is that is why I went ahead and posted it here, perhaps he can get easthill to get it and ship it to him, that way there will be no dents in it this time. I knew someone had a need in here.
Quoted: 413 Post(s)
Liked 109 Times
Thanks for the headsup. It is very similar but is too big!!! I need a 54, possibly a 55, depending on the Peugeot model.
There's one very subtly difference between the 2 bikes posted. The Seattle bike uses a set screw behind the seat tube to 'fix' the seat post whereas the one I purchased uses an internaly expanding wedge.
Again,
Thanks for the heads up,
Jim
Again,
Jim
but the size doesn't work so all else is a mute point right.... just keeping an eye out to help others on here when I can.
Hey Josh good to see you around here again.
always wondered if those bikes had reynolds tubing in the stays---and not just in the main tubes. I believe the reynolds frame stickers on those models indicated (in french) "501 main tubes" or "501 three tubes" Whereas, some 531 reynolds stickers on other bikes read: "main tubes, fork blades, and stays" or, in the case of 531, the 531 may be written Diagonally---indicating a full 531 frame...
Quoted: 413 Post(s)
Liked 109 Times
Some of the Schwinns which have recently passed through my hands are good examples of this. My current Schwinn, a Circuit, is 3 tubes Columbus with Tange stays and fork blades.
The PGN10, Peugeots lugged Reynolds 501 bike has a full 501 tubeset including the rear stays and fork blades.
Peugeots PH501 models, those with the DBS, or 'lugless' joints have 501 main tubes and fork blades with 'non-specific' stays (more than likely 103 tubing). Some of the initial PH501 models had 103 blades as well.
Zorro, jan has seen it... I got a PM telling me how to load the pics... but I still can't do it. I am not able to copy the image off craigs list there is no root for it or anything. Oh well folks here can keep helping me out and thanks to all who do.
ok this is a test to see if I can do it the way everyone has PM'ed me and told me to do it... lets see if I can learn after all. LOL
https://farm4.static.flickr.com/3408/...dc23f4fe_o.jpg
Forum Moderator
Liked 6,607 Times
Quoted: 413 Post(s)
Liked 109 Times
Brenda...as far as I can tell Flickr sucks in regards to hosting photos for pasting on other sites. Try Photobucket.....each picture is assigned 4 url's/links. Copy paste the bottom link/url. No need for tags.
oh well I am not going to worry about it anymore, I just don't seem to get it and it is not really that important.... you all can continue to help me out by pasting it in when I can't.... ooohhhh geeezzzzz this is complicated. It used to be I could just cut and paster, perhaps it is just the flickr problems, the image I was trying to get here would have been a cut and paste off of craigs list not one of my images. For mine I alsways use photobucket.... oh well.... live and learn.
Have a great night and thanks to all who have tried to help me learn.
Becki
Becki
Forum Moderator
Liked 6,607 Times
What web browser are you using?
I have vista and I am using IE so that should not be the problem, not a problem here, just will not worry about it anymore.
Bikes: 07 Vanilla, 98 IRD road frame built up with 25th Ann DA, Surly cross check with 105 comp, 78 Raleigh Comp GS, 85 Centurionelli
Quoted: 87 Post(s)
Liked 923 Times
I use FLickr and it's actually pretty damn good for this. When you click the "all sizes" button you get scaled images so you can post a size approprite for your forum, and the link is right at the bottom. I've never had any problems with it, and the storage of images is unlimited with their cheap "pro" account.
