650c wheeled road bike
Cantilever believer
Quoted: 537 Post(s)
Liked 1,845 Times
One of the riders in my group rides 650C / 571 - she's four foot something teeny and rides a 43 frame (the size of which doesn't seem to work well with anything bigger than 571s). I'm always on the lookout for tires for her as she rides a lot and 571 performance quality tires are sometimes not the easiest ones to source.
I don't see any purpose for those wheels except on a bike built for them. Don't even think 1080 reach brakes would be enough. But then again, maybe another (cough) thread has ideas for mounting much smaller wheels on a given frame?
Likes For Herzlos:
Bikes: Way too many
Quoted: 900 Post(s)
Liked 607 Times
If you're moving on a bike the wheels are virtually invisible. If you're stopped, then everyone will see how bodged it is, unless you manage to find a suitable tri bike.
Habitual User
Quoted: 4957 Post(s)
Liked 8,099 Times
Likes For Eric F:
Old fart
Quoted: 3591 Post(s)
Liked 3,401 Times
N.B. Wheelchair supply houses that cater to wheelchair racers often carry a surprising range of high quality tires for unusual rim diameters.
Likes For JohnDThompson:
Quoted: 8287 Post(s)
Liked 9,064 Times
The main problems with 700C wheels on a small frame are pedal overlap with the front wheel and the very short head tube allowing the frame to twist in a disconcerting manner. Both these problems are mitigated with smaller diameter wheels. The main downside to 650C wheels is availability of tires. They are available, but often need to be special ordered and are priced accordingly.
Likes For big john:
framebuilder
She had a custom steel Curtlo with 700 wheels before she got the little wheeled Moots. I guess the toe overlap didn't bother her but when she got the smaller wheels she felt the handling suffered and the tire availability wasn't as good. Plus she couldn't score a tube from anyone on a group ride. Then there is the wonky gearing. None of these things are a deal breaker for some people, I'm sure.
Also a frame properly designed for 650C wheels does not suffer from poorer handling. I know because I built my own go-fast bike with 650C and enjoy its advantages - especially on fast trining rides. I can tuck in slightly closer to the wheel I'm sitting on and like their faster acceleration.
If your short friend did a proper bicycle fitting and her frame was designed around that fitting, she would have massive toe overlap with 700C wheels. Massive. The way production companies get around that problem is by designing frames with very steep seat angles combined with very swallow head angles. That combination means she is probably sitting way too far forward compared to where it would be best for her. And vary shallow head angles are best for utility bikes with upright handlebars.
650c wheels also makes small frames look more normal. Short women hate having their bikes look like kids bikes. Because on a 650C frame the down tube will be 1" lower from the top tube, the frame won't have that squished together look that emphasizes its smallness.
I will concede that she will have to buy and carry her own spare tubes (when riding her 650C) instead of being able to bum free ones off of riding friends.
Likes For Doug Fattic:
Liked 9,064 Times
A bicycle with 650C wheels does not have ''wonky greeting". For most normal people not riding in fast pace lines, 650C wheels puts their gearing in a more suitable place. The difference is roughly the same as going 1 tooth smaller in the back. For example a 53 X 13 on a 650C bike is about the same as using a 53 X 14 on a 700C bike.
If your short friend did a proper bicycle fitting and her frame was designed around that fitting, she would have massive toe overlap with 700C wheels. Massive. The way production companies get around that problem is by designing frames with very steep seat angles combined with very swallow head angles. That combination means she is probably sitting way too far forward compared to where it would be best for her. And vary shallow head angles are best for utility bikes with upright handlebars..
And, yes, a lot of fast pacelines and some cat 4 racing. It's all academic now because she doesn't ride anymore, as far as I know.
Likes For big john:
Bikes: Shmikes
Quoted: 10176 Post(s)
Liked 5,873 Times
650s are also used for fat tire/fender conversions of racing frames. You can get long-reach brakes for that purpose, but for those wheels it may not be worth it.
Expired Member
Quoted: 3680 Post(s)
Liked 5,444 Times
Yep but those are 650b. 650c is a different size and unfortunately there aren't long reach brakes that will work.
Likes For LarryMelman:
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
LarrySellerz is what makes BF worth visiting.
Keep up the good work
Likes For Kapusta:
Rider. Wanderer. Creator.
Bikes: Bike Friday Pocket Rocket, Cinelli Hobootleg, Zizzo Liberte
Quoted: 394 Post(s)
Liked 783 Times
The issues being described are not endemic to 650c bikes.
I’m a little Surly
Quoted: 699 Post(s)
Liked 1,294 Times
650c is 571
700c is 622
I think we probably need a sticky somewhere on the forum so we all have clarity on wheel sizes, for example there are 3-4 26” wheel sizes only one is the common 559.
Likes For Germany_chris:
framebuilder
I can only relate what she told me about the handling and feel of the bike. After riding the Moots for a while she preferred the ride of the Curtlo. At least she wished the Moots felt more like the Curtlo. I don't know what geometry was used on either bike.
Some short people can benefit using even smaller diameter MTB 559 size tires. There are slim tire widths available in that size. These used to be common but now have mostly been replaced with 650B (or 27.5" - same thing) tires. I just had a 5' 5" guy in his 60's take my framebuilding class. It was really important to him to have toe clearance. In his case 559 tire was his best option because he was no longer able to lean over on his bicycle like he could when he was younger and had a slimmer body. I made frames for both my 5'5" wife and 5'4" daughter using 650C wheels and they really like how they ride.
Mad bike riding scientist
Quoted: 6222 Post(s)
Liked 4,222 Times
Stuart Black
Stuart Black
Likes For cyccommute:
Liked 9,064 Times
The joke was if you got behind her you could feel the draft on your legs but that was about it. She was so low it made her cornering amazing.
Didn't a winner of RAAM use 650c wheels one year? I rode a bit with her at the Solvang Century when the winners of RAAM would show up to help promote the event. She was so low and her back was flat like a table. Cathy something, I think. I cold look it up, I guess.
All of the smaller women in my club are using 700c wheels. There have been a few on 650 set ups but it's rare. There have been a couple of Terry Symmetry bikes in the past.
Likes For big john:
Liked 4,222 Times
But the problems go even further than that. Controls aren’t made for small hands. Brake levers are too far away. Shifters require too much strength for smaller hands and the paddles are in the wrong place. Bike weight is an issue. There are loads of “regular” sized carbon bikes for large riders that weigh in at 14 lbs but not many small bikes that go much less than 25lb. Trek’s carbon bikes smallest size are 44cm. They might fit someone who is 5’ or less tall but they won’t fit all that well. Would you ride a bike that is one to two sizes (or more) bigger than what you ride now? Would you ride around on a 1/4 your body weight?
One thing I learned last summer on our tandem was that her cranks were not just the wrong size but that they could injure her severely. I hadn’t even thought of the problem with her using 175mm arms. We did a two day event in Nebraska that was a 50 mile ride to a town south of Lincoln. At the end of the first day, her knees were in agony and we still have 50 miles to go to get back. When we got back home, I started doing research and found that this is a common problem for stokers. It got a set of cranks from my co-op and redrilled them for 140mm crank length. They work much better for her now.
But all of this is common for those of us with pixies in our houses because while women in general are ignored by the bicycle industry, small women are particularly ignored.
Stuart Black
Stuart Black
Quoted: 1401 Post(s)
Liked 1,886 Times
( btw - the bottom bike is extra sweet )
Liked 1,886 Times
had a friend that built a number of custom frames / bikes (lugged steel) for small women triathletes
to my knowledge all those bikes used 700c wheels
can’t recall the reasons - but I’m sure one reason was wheelset / tire / tube availability
( many of those tri’s went thru a lot of tires etc - significant amount of training / miles )
and not a good idea to see them travel to Wisconsin ... Tennessee ... Hawaii ... wherever ... with a bike they could struggle to get a tube or tire
Liked 4,222 Times
So you are aware of how hard it is to find an M770 crank in 165mm length? And, honestly, those are at least 2cm too long for her.
I have two more sets on Schwinn’s tiniest Homegrown mountain bikes.
Stuart Black
Stuart Black
Liked 1,886 Times
( close - March 30 )
https://www.ebay.com/itm/134510411753
